Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. can we say traction?
  2. B16 sc civic
  3. What's your best R/T?
  4. Flowmaster Vs. Borla
  5. So what are all the Big Dogs up to?
  6. Hoosier Tires!!!
  7. 15 x 8 Draglites - what backspacing and bolt pattern?
  8. First Pass on new combo & BOOM
  9. Problem With HAL Shocks Unloading
  10. If I ran a 8.00 before, what do you think I can run now?
  11. Using bald street tires as slicks...
  12. 1/2 inch play in Dshaft after moser 12 bolt install, to little?
  13. Went to the track again last night, got no traction and some bad caliper rattle! help
  14. 94.57 mph in the 1/8
  15. HAL QA1 install
  16. Ok so who is going to win??
  17. A3 users, what TC are you running?
  18. big cams, big tubes, and knock sensors????
  19. Is there a way to figure out track elevation?...
  20. LT1 in the 9s....NA!!!!!!!!!!
  21. First time at the track!
  22. HELP!! I split all 4 cylinders on one side of my 383 LT1
  23. Where to buy light weight carpet?
  24. Going to the Track on tuesday. Any predictions??
  25. East coast fBody Nationals/Looking for pics
  26. 2 questions here
  27. My First Run on a Track
  28. Need to get into 13.9 13.8 help !!!!!
  29. Springs...Shocks...
  30. Mr Gasket drag 2000
  31. Not an LT1 question, but need some opinions on what size slicks to run??
  32. cheap wheels to use with 26 x 10.5 x 15 ET Streets on 4th gen?
  33. Who runs a 17" Drag Radial?
  34. Whats the problem w/ my times????
  35. Just got back from the track. New times with Hot Cam
  36. Paging all Michigan drag racers and close by!
  37. Are Wolfe crotchstrap bars supposed to come powdercoated?
  38. what's a transbrake?
  39. Gains w/ skinnies compared to Chrome GM ZR1's..
  40. what clutch you guys use?
  41. Installed Trans Go .. Have questions .(long).
  42. Need help clearancing for 28" tires
  43. Follow up post....went to drag strip for first time...
  44. anyone going to Grand Bend for NMCA/NSCA shootout?
  45. Solid Roller again..
  46. Anyone know the formula for altitude correcting et & mph?
  47. First Time at the Track
  48. V6 springs?????
  49. Tonights times what ya think?
  50. Double Clutching????
  51. Why was my rear end shifting on the line...( / )
  52. New track times, how do I improve 60ft???
  53. Any one know a Web-link to a Practice Tree?
  54. Finally got decent numbers!!!
  55. Anyone using a line lock?
  56. Small Slicks adn Et's??????
  57. Horspower Estimate from 1/4 MPH?
  58. What 60' times should I be running?
  59. I weighed the Stock Torque Arm and Spohn Torque Arm.
  60. 1/8 times
  61. Indiana racers-Muncie Dragway this comming Wed.
  62. Rear Race Sway Bar, which one?
  63. First time at the track! (in nearly 3 years)
  64. .500 Pro Tree pondering's...
  65. Finally...First pass on 383
  66. Driveshaft safety loop question
  67. how many tenths would i drop if i used bfg drag radials?? how about nittos??at track
  68. ws6 vs a Lightning???
  69. Weight Reduction
  70. RACING TIPS
  71. Would v6 springs and bfg's help me?
  72. I Finally Did it!!! Hit the 12's tonight!!!
  73. Going to the 1/8 for first time in 2 years!
  74. Roll cage!!! I want one! please help me choose
  75. New lightweight G2 rear suspenion pieces for the weight-conscious!
  76. Best suspension pieces for a 10 second car?
  77. Well, went to the 1/8 tonight and didn't get where I wanted to be. Need advice!
  78. How much will and exhaust cutout help my 1/4?
  79. Want to have some fun...
  80. Lighter OEM Chrome Wheels
  81. 1st 3 runs ever i need criticism and advice
  82. 1st time Drag Racing, went to Bristol DRway, TIMES SUCKED, NEED ADVICE!
  83. 16 yr. old's first time at the track!
  84. Got some new times (happy but also kinda bummed)
  85. First #'s with my 94 A4 stock Z...is something wrong?
  86. Cecil County Bracket Finals
  87. gearvenders overdrive and a few A3???s
  88. Going to the track with my new engine
  89. Can a poly torque arm bushing and tranny mount lower E.T.?
  90. 92 Firehawk vs 97 SSLT4 vs 02 Firehawk
  91. High MPH on ET and lousy times - need help!
  92. front tire ???
  93. Going to the track on friday-first time with the T/A
  94. locker for 10 bolt ???
  95. Dyno Next week
  96. New Times!!! are these good?
  97. Burnouts
  98. when to shift
  99. times on the bottle
  100. S&W torque arm?
  101. yet another question
  102. Needing criticism and advice for the worst ever modded Lt1 times :(
  103. First time going to track with manual.. need a few pointers
  104. When to replace clutch, not sure if needed.
  105. flash or stall?
  106. bogart drag rims mounted on a Z
  107. How do you Front Swaybar?
  108. Best tires
  109. First time @ track ever (Milan, MI)
  110. Michigan dragracers and closeby - INSIDE!
  111. Drum brakes with Draglites
  112. What should I Dyno at?
  113. New Times ??
  114. LAUNCHING!!!!??????
  115. ever drag at Raceway Park, NJ in englishtown!?
  116. Longer wheel studs
  117. 1st time at track with manual.. im happy.
  118. Import vs Domestic Shootout!
  119. powershifting an LT1
  120. Loading on a trailer
  121. what steering wheel to use?
  122. 4th gear t56 with 94 console
  123. My $5 timing advance kit actually helped!
  124. Helemt open or closed face?
  125. M6 Bracket racers?
  126. Steel Street Twin + 4.10s + DRs = spin
  127. clutch
  128. 6.6 @ 105.11- 1/8mile, what does that translate into the full 1/4
  129. Nittos Stick on street but can't get hooked on the strip..burnouts?
  130. guys runnin lockers..inside please.
  131. Car back together and raced a 502 Nova!
  132. Will LCA's help me?
  133. Finally broke into the tens...... now it's time for a rebuild...
  134. What kind of 1/4 time would this be
  135. Madmans got power
  136. Anybody here fried MSD boxes before??
  137. How do you measure backspacing on a wheel?
  138. What Backspacing for 15x8 welds?
  139. Heat the tires?
  140. Who is happy with their DS loop?
  141. Gaging interest in 8.5" ten bolts for F-Bodies...
  142. Anyway to make a 2nd gen rear work with a torque arm?r
  143. Good street/strip tire?
  144. My 1st time at the track.........
  145. How much does a TH400 weigh?
  146. First trip to track - horrendous times - Please help
  147. trap speed
  148. 123mph trap speeds. What rwhp does this equate to?
  149. To AC or not to AC...that is the question........
  150. pinion angle figures- leaking moser pinion seal
  151. looking for a little mph understanding????
  152. First time at the track
  153. Hooking...........!!!!!!!!!!
  154. How much does a Spohn Driveshaft weigh?
  155. Hoping for new best in this heat...
  156. Proportioning valve bypass, to stalling converter at the track.
  157. Anybody in CA....
  158. Shooting For The 9's, Details Inside
  159. George Baxter's email?
  160. Just got back from RT. 66
  161. Help! What will i run with this mods?? anyone??
  162. anyone running a 4-link???? Or thought about it?
  163. Dropping front sway bar??
  164. Practice Tree Software
  165. Anyone like open loop, for drag racing?
  166. 3600+lbs + T56 + N2O=10.14 @ 135.11mph, 1.40 60'... almost there :)
  167. V6 rear springs...worth it???
  168. Strut Tower Brace for Drag Racing?
  169. Th 350 torque converter suggestions
  170. LCA Relocation Brackets??
  171. New times for the 91 RS!
  172. Pics of new rear Draglites.
  173. Anyone going to the US Nationals
  174. auto launches
  175. will 16x9.5 et streets fit under fenders?
  176. New best time
  177. Traction issues solved and set new best (barely)
  178. Opinions on 1/8 mile times (slow?) please ? MOD list
  179. Milan Dragway this Tuesday!!!
  180. how are you guys shifting your tranny ?
  181. The convertible is almost ready........
  182. Springs...
  183. finally had a good launch...
  184. Going to track for 1st time, need helpful hints!!!
  185. Need Stock Eliminator websites
  186. 245 vs. 275 drag radials
  187. Will 4.10's improve my time?
  188. Quest For The 9's Falls Dead This Year
  189. To stay on the street or not to stay street ...that is the ??
  190. For all in the NW (WA area)
  191. Stuck in mid 13's..(:
  192. '93 Z28 1/8th mile times
  193. New best and finally a good 60ft.
  194. How do I make my car do this?
  195. Automatic Tranny at a track
  196. S&W Roll Bars & Cages on Sale
  197. This may sound stupuid but......
  198. What times should I run in the 1/8 and 1/4
  199. Finally did it 11.61@117mph!
  200. OPINIONS on my new Best 1/4 ET
  201. Questions about Summit's economical race seats?
  202. Harness rewebbing???
  203. How much has summer heat affected your performance?
  204. Your best launch PSI with Nittos....
  205. Norwalk, September 27th 50 car T&T
  206. are there any national fbody drag racing events upcoming?
  207. My awsome new 1/4 time!
  208. Removing the sway bar?
  209. What should I run w/ new setup????
  210. Street Tires?
  211. New cage pics.....
  212. Went to the track again.
  213. How to do a burnout in an A4
  214. Has anyone used the tire "softener" treatments
  215. I have pics of the race this Sunday
  216. shift
  217. Launching on my new 2800 Converter.. few ??'s...
  218. 6-speed-vs-TH 350
  219. First runs with 02 SS...
  220. Track times Just after hitting 150,000 miles!!
  221. Broke my T56 last night
  222. SHIFTING
  223. rollbars need to be welded in to be legal for track?
  224. Need help, hard launches are destroying my car.
  225. length for A3 driveshaft
  226. Tire pressure for et streets
  227. Turbo 400 going in, need driveshaft info..
  228. TH-350 and TH-400 Users Lend Me Your Ear
  229. How much.....
  230. Mcleod is in 497 miles away from racing ;) anyone goin' to Grand Bend this weekend?
  231. Slushbox techniques
  232. Roll Cage
  233. 12 bolt cheap rear question
  234. Slow traps question
  235. Any benefit with 4.30 gears in a LT1?
  236. rear spring ? stock or pro kit for drag racing
  237. Question about slicks
  238. Wheel Well Clearancing
  239. Where to set tire and airbag pressure?
  240. Car Trailer for sale - NJ
  241. New Personal Best at Stanton,MI last night
  242. ?? questions about drag radials and a little more
  243. Paging: all those who have swapped in a th350
  244. Going to the track tonight, anything I can do to improve performance?
  245. Attention Michigan Drag racers and near by....
  246. Need brake pads that will hold the car at 2000 RPM staged...
  247. New best with 02 SS...
  248. New best! (video inside)
  249. Island Dragway
  250. 1/8 mile questions.. my BS alert went off
