- Turbo or Supercharger?
- EGT gauge..
- LT1 Twin Turbos?
- Fuel cell for liquid-air intercooler.
- ProCharger and Callies update (post some info here about your blower drive)
- south east tuners?
- Dino oil vs synth and turbo timers..
- Lucas 42lb install prob - racetronix
- Why don't more of us use WATER/ALKY injection?
- FYI--For those of you thinking about an ATI Procharger with intercooler
- Heat exchangers and aftercooler pumps
- 650-700rwhp...who's there??
- Need a DP for a Turbo Tech kit
- xe 224/236 s/c cam on a 114lsa
- 500 rwhp without intercooler posible?
- LT1 Twin Turbo Lives!!!
- Powerdyne 4.5# and LT1
- More results from the turbo car
- Advice Needed on Fuel set up for 500+ RWHP
- New Supercharger Advice
- would it be safe to spray 50-100 shot if u have a superchargeR?
- Duttweiler Cam Specs ???
- SERIOUS company looking for feedback to produce the ultimate F-body turbo kits!
- Wastegate questions
- Twins are almost ready!
- FS: ATI procharger 6 rib 10 psi pulley
- ?s about ATI and programming
- procharger install
- SC vs. N/A
- Info on LS1 Turbo/Twin Turbo
- Piston Ring Gap ?
- 6# Powerdyne Pulley Upgrade
- Flow tested some AFR 190's and 210's
- high comp/turbo ?
- Powerdyne 6#Users, what plug?
- ATI dealer? customer service? I NEEEED PARTS!
- What's the fastest 8# car is the country worth?
- 1rst drive on the new motor was today!
- Tricks to removing pulley on S-Trim?
- AFR Heads and what plugs?
- what turbo
- Can somebody explain detail how to punch/tap the oil pan for the Vortech oil drain???
- ProCharged w/ knock
- another update
- need timing controller for Jacob's Pro Team
- 60-1 turbo specs
- Hey rkrause and ??? ...............
- LT1 twin turbo location?
- how much gain from ati procharger
- anyone running march power and crank series pulleys with a p1sc or d1.
- has anyone ever bought ATI products from lonnie pavtis
- Walbro 340 Install
- How about this fuel system?
- FMIC location in a 1995 camaro
- how many of you are interested in TURBOLOCITY'S kit they want to make?
- Worth porting/polishing LT1 intake with Turbo?
- intercooler piping
- wastegate question
- simple turbo manifold idea
- need a link to turbotech's site...
- Need opinions: adding top-end to 8# ATI + stock bottom end
- Compressor map for D1SC?
- Fuel system upgrade?
- Air-water Intercooler forsale
- what is CAS wesite? i cant seem to find it
- Post Pics of Supercharger on LS1
- Will I lose boost?
- New Turbo cam specs....
- Track Video of my car.
- Vortech Bypass Valve Characteristics... need help
- Piston Questions
- Injector change with Powerdyne??
- NX Ntercooler kit
- Videos
- Viton valve seals, how to
- Fuel System
- Moron needs ati install pics
- Is it true you dont need a aftermarket fuel pump with teh ATI kit?
- FS: 55lb injectors & Aeromotive Fuel system
- What Gear?
- I need the oil inlet fitting for an S-trim
- Possible solution to Crankcase Pressure Problem
- T-70 on a 355 ???
- want to see pics of a CAS TWIN TURBO set up on a lt1
- detonation ??
- Not really tech, but maybe I could get some opinions on what sounds better...
- which of these intercoolers are better
- Dyno Numbers
- ATI Crank Pulley ridge?
- fmu questions
- procharger
- The little rubber isolators for the T-REX for mounting...
- Supercharger Install
- I Want To Charge Up!!
- Can you mount a turbo vertically?
- Free boost gauge with Vortech or ATI purchase!
- procharger d1-x question
- can anyone answer this question????
- just bought a turbo
- Mounted turbo pics within
- water cooled turbos
- max boost
- New ATI Questions
- whats a p600b polished head unit worth?
- ls1 supercharger purchase help
- Good place to get PCM custom tuned?
- Turbo routing?
- Can I tap a power source for the T-Rex from the fuel relays???
- Questions about Adjustable Fuel Pressure Reg on boost?
- Simple Intake Tubing Question for Vortech owners...
- How to align pulleys?
- Good Price??
- Pops when stomping the throttle
- HD clamp sets available for LT1 w/ blower?
- muffler
- wtb: procharger d1 blower pulley
- Where can i buy a good turbo kit for my truck????
- 38# injectors enough to ditch FMU? LT1 Questions.
- some baseline dyno numbers
- The way ATI SHOULD have done the intake.
- ATI p600b guys
- Anyone running Aeromotive 13110 reg. before rail?
- quietest supercharger
- A few words about cmotorsports
- ATI F1R blower
- how does auto trnas shify with boost
- Turbotech guys, I need some help
- oil blowing out of by-pass valve
- How much boost will this give me?
- forged cranks
- F-bud needs help putting ATI 3-core on S-Trim, need pic's/advice please (Rich K.?)
- Crank and Supercharger pullies FS
- larger throttle body
- 15# Pulley for ATI P600B?
- Solid intake tube for ATI LT1 kits?
- Cam Question
- Urgent Response Needed!!!
- Crane TRC-2 Timing Retard Control Module for sale
- I think I found the limit of stock LT1 head gaskets:)
- T-Rex install - How many ppl actually put the "heat fitting" in a 400F oven???
- Pretty Sure I blew my engine - Any rebuild suggestions?
- Will JB Weld hold my Vortech oil drain fitting properly???
- final details getting wrapped up :D
- Anyone need some 2-1/2" stainless tubing?
- LT1 Twin Turbo Kits?
- Vortech YS-trim
- what are the cons/pros of self contained vs tapped engine superchargers
- Setting up my gauges for SC...
- gear setup
- will a P600b support 600rwhp?
- What gauges for an S/C car... Boost/AF or Boost/FP???
- wastegate help...
- whats your opion on these egt gages???
- Fuel pump install
- brand new HKS 60mm wastegate for sale
- How much $$ for Vortech Aftercooler?
- Valve Springs
- How to set up my superfueler
- To be, Or not to be Self Contained
- Autometer FP Gauge 3363 Question
- new to superchargers, info please
- bov question
- liquid air/aftercooler question
- All things being equal, which is better?
- theory behind reverse split cams
- head gasket recommendations
- Any problems with Procharger blowers?
- Pro Turbo Kits LT1 Camaro Turbo kit
- Bigger throttle body
- Turbo Update
- Suggestions for boost rookie with a P-1SC on a TPI
- Paging 1LEThumper
- how much hp can stock lt1 pistons handle
- Tuning w/o Supercharger
- F1 supercharger for sale (LS1)
- Fuelpump ?
- Single turbo project underway.
- Lots of boost
- Ok...Stupid Question Time
- How much boost do you go up from 6# with a power pipe/solid intake tube???
- Vortech Carburated Blower!
- 306 with a Procharger
- New to turbos, pros & cons, cheapest?
- FMU help-please!
- Vac. Restrictor for FMU?
- 4" cobra head FS
- Exhaust suggestions
- Push rod length
- Maf Relocation
- Powerdyne Disassembly??
- Possible to divert exhaust through one half of divided housing for faster spool?
- Anybody using an Ultradyne blower cam???
- Cant get more than 6# boost
- Felpro Head Gasket?
- Just finished Vortech install!! Couple questions please!
- super charge 383/355?
- Hay Rich I need info
- powerdyne add claims boost as low as 1800 rpm is this right
- How does...
- What does your o2 read
- Qs for ls1 guys using turbo techs kit with T-76
- What does the red light on my Crane HI-6R mean if it lights up?
- Where do I mount the Vortech MAP sensor and where does it get vacumn???
- BTM owners
- Tensioner Problem
- Gen 6 DFI vs. LT1_Edit
- A cure for belt slippage issues with ProChargers
- Max power on the street??
- Link to turbo kit for LS1
- Ditch the inline since I have an intank pump now?
- Somebody explain what happens when I turn up the timing retard???
- Please confirm correct sizes!
- BOV can be run without BYPASS!
- How are intercooler cores flow tested?
- How do I set the Crane Hi-6R TRC2 timing knob???
- FMU deletion
- Help with ignition?
- Compression ratio?
- FI SBC buildup (long)
- Advise please D1SC 8# kit coming
- Where to mount the BTM?
- sc question?
- Turbo Setups
- upgrade to V2-SQ?
- Supercharger on stock 97 LT1, safe????
- Ordering gauges... boost and fuel pressure OR boost and A/F
- upgrading an intercooler,worth the money?
- Will I lose airflow if I convert to a Front Mount Intercooler?
- Question for WideBand O2 Users
- Blower Cam Installed
- Crank case pressure and blowers
- Anyone familiar with Warner/IHI turbos?
- Looking 4 Belt PN# for Powerdyne LT1
- ProCharger or Vortech?
- single pattern cams for forced induction
- newbie type questions.
- attn: Brady_96Z
- what size pulley do you use on your D1?
- Anybody using an INTERcooler with a Vortech blower?
- Electric Supercharger for LT1's ?????
- Speed density and supercharging...
- ATI P1-SC Unit Comparison.
- wtb: bypass valve or blow off valve (u say potato i say patata)
- How much does 1 pound of boost raise the CR?
- AVC-R install
- Fuel System
- Tempature question on intake air?
- Quick Q about blower kits
- Reverse Rotation Procharger?
- Need tuning advice...
