- ? about T-Rex Aux FP
- New Blowthru Forum Site
- Cam GP Decision
- Best heads
- Video of Roots car
- Twin turbo header pics
- any LT1 guys running a force fed fabrications kit??
- 20psi with S trim?
- Looking for an Incon TT kit?
- misfire, diff. from open to closed loop
- blower specific balancer
- how much psi can a t-34 put out?
- How does a boost controller work
- Centrifugal Superchargers for carburetors
- Need Intercooler
- 348ci LS1 + YS Trim = 705rwhp!!!!!
- T88 Turbo kit for sale!!
- Turbo questions
- whats the max hp 50# injectors will support?
- LT1 heads? combustion chamber size
- Turbo oil return? VC or oil pan?
- Guys with 2 core IC (inside please).
- How many of you have tried this?
- Ignition ?
- Header selection for a forced induction application?
- ATI Procharger
- Twin T04B ?
- Wastegate on a Blower?
- Turbo Oil lines
- why does a turbo spool faster with more load
- Help! Need Turbo sizing assistance!
- 8 rib ATI kits - quick update (LS1)
- RSKrause Going from low lift 224xe cam to high lift? any real gain?
- People with a LT1 Vortech supercharger
- Best head options for FI setup
- 774/774 dyno sheet
- M6 conversion or a STOUT A4?
- TB question?
- LT1 head gaskets for boost
- A few questions
- balancer suggestions
- Vortech or Procharger
- Anyone got a 4" or larger ATI pulley and/or an ATI head unit for sale?
- Scavaging Pump for a Turbo
- Superchager help!
- newbie turbo question
- kinda dumb guy here
- Vortech YS trim/Spearco intercooler forsale
- What did you run on your stock bottom end?
- LT1 Twin Turbo Kit For Sale
- Why 1 5/8"
- Cam selection on a ATI P1-sc 12#-14# forged 355ci
- rskrause and others - crank choice questions?
- Rob Raymer's QMP formula
- sc car in over my head????
- Carroll supercharging long gone... where to get parts?
- twin TO4B turbos, what kind of numbers can it produce
- Lifted heads on Dyno!! Help
- Turbo header pipe (where to get it?)
- Turbocharger cams?
- Powerdyne blower?
- MAF Limitation? Other MAF possibilities?
- Methanol/water Injection
- What spark plugs should I use?
- How much HP will this
- Cam in the FS section
- are ls1 and lt1 fmu's the same thing???
- How much HP would a twin T3 setup support?
- Trick Flow Heads?
- t-76 turbocharger
- Options for a forged LT-1
- Single turbo system For Sale
- Charged Air TT setup
- forced induction=shorter engine life?
- sc lt1 dyno sheets?
- Loud or quiet
- Powerdyne...How much boost
- 383 turbo LT1
- Will this pass emmissions?
- Check this out ...Quad turbo setup !
- Tpi Turbo Questions
- turbo for a mustang on a trans am?
- Mas air meter placement with blower?
- STS LT1 Turbo update
- Paxston Supercharger
- Shortblock FINALLY done, need advice/recommendations...LONG!!!
- Importance of intake piping and couple other Q's
- Maybe im missing something?
- ATI Procharger Question???
- Food for thought
- FS: Spearco front mount
- gale banks TT kit for chevy 350
- voretch belt size 6.66 + 3.33
- estimated hp for stock lt1 @ 6lbs
- low impendance injectors
- Boost Pressure change with Ported Heads
- LS1 Cylinder head drawings for exh ports and bolts
- Anyone run this Pulley on a powerdyne?
- What cylinders run the leanest under boost?
- Turbo KIA
- Which cam for SC 383
- Anybody looking for 72 lb/hr injectors??
- February Vortech supercharger sale!!!
- How much boost?
- Turbos and head porting ?'s
- Paging engineermike
- Got some porting questions
- timing retard with powerdyne?
- Turbochargedpower releasing kit this month
- Turbo/Subercharger
- Realistic cost of a single T76 turbo setup?
- vortec g-trim install time?
- ATI Procharger install list... for 100% stock vechical...
- Step inside to get your ATI 8 rib supercharger!
- Aftercooler water tank?
- made it to the track
- Rebuild time; will the stock crank handle this?
- Bottom end build time
- Our shop car. Innovative mid frame 88 and 427ci
- who has the
- Numbers with Powerdyne
- pros cons of owning sc car
- Which is the better blower cam...
- Front mount question.
- IAT sensor question
- Ideal compression for a turbo'd 355
- 396 compression
- 3.4L V6 Turbo or Super.....
- What parts should I use?
- Any vortech aftercooler guys using LTCC?
- Rear Mounted Turbo
- Turbo Cams?
- Input on my setup
- Head gasket with blower...
- quick question on my blow off valve
- JetHot LongTube headers(with emissons) and a Supercharger...which one will fit?
- what is the REAL importance cylinder heads with a turbo?
- CAS Twin Turbo ls1 camaro kit for sale
- Won't pull past 4k rpm!
- Calculating comp ratio ?
- What to gap 104s to?
- 383 with Blower guys...what pistons do you use?
- MSD 6BTM For sale
- How much Boost on Edelbrock Crate Engine??
- Could a bad MAF massager cause a high idle?
- Anyone done a TT Big Block?
- Guys w/ 10+ psi, What Header gasket R U using?
- Requesting Information on HP Level
- Air Temps - SC vs. Turbo
- Surging at low RPM/Light Throttle
- difference with these to y pipes (mufflex and ls1 speed)
- what kind of crank pulley/ balancer are you guys running?
- 3800 supercharger
- Video/Sound clip of P1 procharger??
- Any reason I couldn't paint/powdercoat my supercharger?
- Turbonetics T-61 T-Series Turbocharger .......starting at 850 dollars
- What Size Injectors?
- Opinions on the limits of this set up
- New Hand held wideband system
- Turbo Theory. What moves the turbine?
- thought I'd share some new pics with you guys
- Accelleronics Injector Inmpedance Converter For Sale
- Compressor maps D1sc , P1sc....
- High boost pulley question
- STUMPED having issues with my turbo car
- Just got a rajay draw through turbo setup
- Turbo LT1?
- Twin header update pics
- Which ATI ProCharger to get?
- Turbo Technology Ls1 Race System
- ignition advance
- 18 gauge mild steel header tubing, what should I do?
- What do you pay for VP C 16
- Turbo Oiling Question
- Largest ProCharger/Vortech On An LT1/LT4?
- Fuel pump questions
- S/C L98?? What would it run?
- Supercharging 91 Z28 L98? Anyone got one? Got Questions.
- Help: Making 5psi less than normal (turbo).
- WTB front mount intercooler
- ATI LT1 install rerouting oil cooler hose
- where can i get a racegate spring?
- Does your car react hard to spark retard?
- 72#ers for sale
- Header Help
- Crane 99845-16 H-ll valve springs
- New to superchargers
- single turbo kit
- air filter collapsing with ati
- fuel pump
- Part # needed for JE rings
- How much RWHP with a T-trim
- Guys running YS Trims.....
- interesting tubo build up
- twin turbos, headers
- what kind of plugs with SC??
- bigger injectors, and SC and no tune...for now
- 700rwhp with a T-trim possible?
- Electric Clutch to disengage blower when not needed?
- Best place to get piping, hose and clamps?
- YS-Trim for sale........
- MAF location with supercharger
- I think I solved my problem
- cant run headers with a paxton??
- How much valve over lap with turbo?
- Twin turbo ls1 setup questions
- Stock Engine LS1: 775 RWHP/865RWTQ
- Turbo Sizing on a stock LT1...
- want to FI a stock daily driver...info please
- Brad Bran hard intake tube
- Wheres the sticky in here??
- aftermarket fuel system pickup question(walbro)
- Will carb/brake cleaner hurt my blower?
- FMU to 42lbers.. PCM tune? help please..
- Who here has a turbocharged First Gen?
- Right Fuel Pressure
- Best price on procharger?
- Problems with MSD BTM, and a question about it.....
- Poor boys buildup
- What Blower is right for me?
- Thinking about TORNADO FUEL SAVER? READ THIS!
- Getting a Procharger.. need some help
- Granatelli MAF
- Cogs, T-trim, Longetivity
- Stumbling
- check out my other turbos for sale
- How much turbo shaft play means a rebuild?
- Have to rebuild anyway, 355 or 383 w/Powerdyne (Vortech maybe later)
- SQ/t-trim
- Powerdyne Reliability
- goodbye paxton, hello vortech!
- Porting throttle body to 60mm?
- how much power to expect from supercharged 383 lt1
- Aftermarket MAF
- Supercharging on 114k Mi. Motor Dangerous?
- Paging SleeperZ some q's
- Whats the best supercharger for my setup
- extremely rich at idle, fine off idle and after
- car looses power at 5000 rpm after installing procharger
- Yes or No to a 4.5 supercharger
- which is better?
- Need Help with Linkage on a Roots blower
- Paxton install on 3rd gen
- calculating boost
- Blow off Valve upgrade?
- I've been quiet....
- 150 MPH in the 1/4 AND streetable. Possible?
- Twin intercooling?
- Turboed 3.8 dyno numbers
- Too much compression for a SC?
