Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. about how many miles will a supercharger last?
  2. 454 Power handling capabilities
  3. lt1 vortech guys, I need pics
  4. Are MSD 50#'s really that bad?
  5. building 12 sec street
  6. need a F.A.S.T. tune for my twin turbo setup
  7. intercoolers twin or single 3core
  8. 224/236 cam and brakes?
  9. stock heads
  10. Realistically, how reliable are turbos on LS1s?
  11. A little help
  12. Would 3.73's mess my traction up totally?
  13. Best SC (Procharger) setup for 383 LT1
  14. Where can I get a keyed hub?!
  15. ATL 3 core specs???
  16. Couple Questions About Using Nitrous for Cooling Effect
  17. Whats the Most HP NE 1 has made w Stock heads
  18. Thoughts on Iridium Plugs
  19. where to buy brad brand tubes ???
  20. Dilemna
  21. some pictures of my setup so far
  22. makeing no boost
  23. mass air meter
  24. twin turbo?
  25. forced induction help please
  26. New Turbo LT1 track results.
  27. sts ls1 dynoed today
  28. What size belt for a T-trim 7"x 2.65"??
  29. NGK TR6 spark plug gap with ATI procharger
  30. Air Filter
  31. making an intercooler
  32. Boost on a BBC
  33. HP #s with ATI D1SC
  34. $$ required for turbo project
  35. Suggested injector size w/ P1SC
  36. Help! Ati seals bad, again
  37. 8 inch 10 rib setup for a Vortech???
  38. 12.72 quarter mile at 112 mph.
  39. good site w/ blower engines?
  40. Turbo, SuperCharger, or Heads & Cam ???
  41. STS LS1 Dyno #'s
  42. STS Turbo LS1 Dyno
  43. 50# injectors w/ ATI D1SC OBDII 2 OBDI
  44. Autolite 104 gapped at 42.
  45. boost gauge
  46. Traction Control / D1SC
  47. how to connect exhaust outlet to this turbo, pic inside
  48. need help with twin turbo pressure ratio on dyno program!
  49. First WOT blasts with new cam...
  50. The crank pulley comes off.
  51. Forced Induction And Intake Port Volume Q..
  52. Turbo size
  53. Rear mount Turbo
  54. Can someone explain to me why porting heads is good for turbo setup??
  55. getting past 6psi
  56. Supercharged Riviera with minimal mods makes almost 400 lbs flywheel torque
  57. roots type blower on f-body???
  58. roots style blower on ls-1 T/A ???
  59. INTAKE recommedation
  60. MAF Relocation help
  61. 383 exhaust resonating ?
  62. 94-97 vortech s/c with a/c on ebay $850!
  63. Heads have to come off for repair, port or not port while at it?
  64. Any thoughts on sheetmetal intake for FI cars?
  65. sts turbo lt1
  66. Safe to run 5PSI of boost?
  67. Broke my new 383!!!
  68. LT1/4 intake restriction(hogan)
  69. Who’s rear mount turbo setup is this? *video*
  70. to the dyno, james
  71. Cubic inches for a turbo setup
  72. Hey vortech guys - pulley sizes!!
  73. ATI's new complete kit for the LS1
  74. New ATI part numbers for the LT1
  75. Turbo headers for gen I sbc? Specifically a 3rd gen?
  76. Buying a used SC?
  77. opinions on scat's rotating assembly, look inside
  78. LT1 Edit or Tunercat?
  79. Turbo Questions
  80. paxton head change
  81. turbo headers for 3rd gen sbc
  82. boost gauge
  83. Finished up photos of latest thirdgen single turbo car
  84. Bro Needs to sell his Vortech LT1 Kit-$2300
  85. LS1 Vortech
  86. Vortech Aftercooler...???
  87. what happens if the oil oulet is level or slightly lower than oil pan??
  88. Cold Weather...FI Guys gotta Luv it!
  89. vortech aftercooler on ati d1sc
  90. Install New Throttle Body
  91. FI or NA?? anyone ever been in this situation??
  92. Intimd8 Rich Krause: Maxing out the S-trim on pump gas
  93. need a better maf for turbo? other costs
  94. Is a Switched Supercharger Possible?
  95. Paxton; are the horror stories true?
  96. Best place to purchase an ATI Procharger?
  97. Aggiez28's dyno video
  98. New to supercharging
  99. monoblade porting
  100. Oil Leak on Vortech - Blower guys help!!!
  101. has anyone supercharged a 3.8L?
  102. exhaust system advice???
  103. Vacum set up with a Weiand 144 CID???
  104. Stealth Ram or Modified LT1 intake for Turbo set-up?
  105. cheap way to make good induction?
  106. Whats going on
  107. Anyone using a GN intercooler
  108. What's up with our engines?
  109. Fuel Question
  110. Motor break in with procharger?
  111. Ginea Pig for Muffex hard intake
  112. anyone using 30 SVO?
  113. need a blower cam for LT1
  114. SD Concepts Tensioner Pics
  115. How much power are you guys making?
  116. compression and boost
  117. Used supercharger...things to look out for when buying one.
  118. Rebuild question
  119. LS1 ignition on LT1
  120. restrictors in the oil feed line needed??
  121. Internal Wastegate
  122. Procharger D3-M head unit for sale
  123. sts on tpi
  124. oil pump or smaller feed line for turbo?
  125. Boost-a-pump question
  126. FI or NA for street car?
  127. STS turbo kits?
  128. Roots Type Question
  129. Parts of a Turbo
  130. What do you think of this kit??
  131. 16 Gauge 1 5/8" Mild Steel U's or 90°
  132. Clutch for Supercharged motor?
  133. Front oil seal leak, what's the secret??
  134. Serious turbo FMU/SAFC questions
  135. Supercharger tune ?
  136. Paxton Supercharger
  137. ATI Procharger belt sizes
  138. paxton opinions and advice needed
  139. LT1 Turbo setup! Is this for real???
  140. Stock LS1 potential with turbo + n2o
  141. Could I run a 4.5 psi Powedyne with my mods?
  142. Max Intercooler CFM
  143. anyone run a 3"y pipe and mufflex 4" cat back for 500rwhp+
  144. Turbo 1 5/8" vs. 1 3/4" primaries
  145. Vortech Exchange Program
  146. $2,500 Fair price for PS1c twin i/c????
  147. Fuel Pump Question
  148. Remote Turbo Mounting
  149. cause of broken crank keyway?
  150. vortec SQ VS ati SC
  151. Pulley size p1sc
  152. Stupid Question
  153. Weiand 177/142 blower questions
  154. Anyone with ATI/ASP cog set up w/in
  155. ati procharger 3rd genners step inside please :)
  156. 6psi intercooled and full timing?
  157. times with a Vortech?
  158. crane Hi-6TR Timing Retard Controller help
  159. Can I use any boost on a 10.4:1 CR forged bottom end?
  160. Pro Turbo Kits
  161. Compression question
  162. vortech lt1kit
  163. Keyed crankpulley
  164. Only Making 8-9lbs Of Boost On A 2.75 Pulley....
  165. Suggestions on bearing and rings for a blown motor
  166. Somebody finally grew a set of balls with an LT1 F-body!!!
  167. cog set up for d1sc
  168. Turbo on e-bay for $30!!!
  169. Just an Idea
  170. Twin or single turbo?
  171. Slp Mass Air And Maybe A Throttle Body Is It Worth It.....
  172. Rod length & stroke on a turbocharged engine (question)
  173. cc306 on a 114 lobe
  174. intercooled eaton M112 setup concept.. Version 1.0
  175. Anyone runing a Vortech elbow or trick flow
  176. Interesting concept on oil return
  177. Comp Cams recomended me to this cam
  178. Stock LT1 Heads
  179. Starting problem with 84lb/hr injectors
  180. spark plugs
  181. RACE PREPS 330CFMs heads vs T-trim over S-trim
  182. Suggestions for a mild boost 383 lt1 buildup...
  183. for those worried about piping length on an STS turbo
  184. damn you turbonetics...
  185. Has anyone encountered this????
  186. does intercooling keep away detonation beter than mynthaol/water or are they equal
  187. Who do you recomend for a custom solid roller turbo cam?
  188. 8.6:1 OR 9.2:1 CR??? on a blown 355
  189. Oil pressure going down under boost
  190. Innovatives camaro vid
  191. Crate Engines
  192. Hellfire rings?
  193. Approximate HP numbers w/ ATI D1SC setup up
  194. vortech with no FMU
  195. Choosing wastegate spring with variable boost controller
  196. turbo build up
  197. ATI D1SC Twin-Intercooled setup possibly for sale
  198. S tirm Vortec on LS1
  199. What makes an S/C whine?
  200. $2850 fair for D1SC ?
  201. Pro-Turbo Kits... questions
  202. Considering using an LT1 block for my turbo build. Have questions.
  203. Info on Innovative GT80-R trim??
  204. Turbo guys here... Oil out exuast? STS?
  205. Help on readying car for supercharged 383
  206. At what boost level are 6" rods going to be too long?
  207. chalenging someone to design lt1 turbo kit.
  208. Dyno results from new exhaust.
  209. Popping when letting off gas!
  210. tial wastegate help.
  211. Problem starting and with idle after adding Procharger
  212. vortech ?
  213. Has anyone attempted to put a whipple truck kit on a f body?
  214. solid intake for lt1 vortech
  215. Help me decide on one of these cams for my turbo car
  216. PTK or Turbo Tech??
  217. 60-1 questions
  218. Supercharge,Turbo or niether?
  219. Vortech Intall Instructions???/
  220. How much does stroking really help in FI???
  221. stock fuel pressure regulator
  222. Got a little smoke from under the hood...
  223. Intercooler
  224. S-trim to T-trim upgrade?
  225. stock compression
  226. Help on choosing pulley size and reading/dealing with a compressor map...
  227. STS Turbo to be CARB approved
  228. In-depth cam discussion for FI - valve timing events
  229. Anyone familiar with Pro Turbo Kits?
  230. Piston rings for a supercharger?
  231. IC after S/C?
  232. blowers vs. turbos...why are more and more people switching to/going the turbo route?
  233. New type of intercooler
  234. 3800 S/c Bov
  235. longtubes vs shorty's
  236. Post your Water/Alky Injection pics/installs
  237. Stock LT1 with ATI Procharger P600B and inline fuel pump.
  238. Overspeeding Vortech blowers safe?
  239. Bumper Support
  240. Stock MAF on "pressure" side?
  241. Who's going over 135mph trap speeds
  242. Paging INTMD8
  243. F1 users
  244. cam, comp for supercharger
  245. Concerned about cam choice on my 383
  246. Superfueler for sale.
  247. Question regarding turbo install
  248. Got some decent results finally
  249. aerodyne aerocharger (VATN)
  250. Turbo-guys... what do you do for tunning?
