Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Cold air induction on an S/c motor....
  2. New single Turbocharged SBC 3rd gen Im working on pics w/in
  3. Horsepower is flatlined from 4,800-5,500. Need opinions
  4. Problems with Blow Off Valve
  5. Any of You ATI P-1SC guys have a 12# pulley laying around?
  6. Turbo Ideas Please.....
  7. BLOWN V-6 vs. LT1
  8. Individual parts vs. Kit
  9. Intercooler Question...
  10. Denso plug/ electrode mod ?
  11. Supercharged LT1 Rebuild
  12. Supercharged Virgin - durability?
  13. easiest supercharger
  14. Bottom-end build on smallblock V8?
  15. TT setup
  16. machining hub for key
  17. starting an engine that's been sitting
  18. Pro Turbo Kits
  19. Mounting a BIG intercooler on a 4th gen?
  20. Why not 355?
  21. How do build a reliable S/C LS-1
  22. WHy can imports handle more boost
  23. Went To The Dyno Yesterday And......
  24. Crank pulley sizes for a Vortech setup.
  25. Source for mild steel header parts?
  26. ???????help
  27. 9.006@159mph = fastest and quickest LT1!!!!!
  28. One of the BEST ATI Dealer/Distributor just got better
  29. twinturbo ss
  30. ATI SuperDamper and Supercharger Pullies
  31. after/intercooler help
  32. Tensioner issues = munching belts
  33. STock LT1 with a Turbo, 552 rwhp 630 rwtq video inside...
  34. The LS1 ATI kits have just got better!
  35. help me with my new blower setup (converting from NA+N2O)
  36. ati prices dropping!?!?
  37. pics of my twin turbo iroc
  38. Electrical Problem...Please Help!!
  39. Adjustable boost with S/C?
  40. T3/T4 Turbo? LOL
  41. Paging SleeperZ about the PT88 LT1 that goes 8's
  42. turbo or supercharger...
  43. My PTK setup is almost done...update for those who care
  44. Vortech YS fit/application question
  45. Who make the best boost-a-pump
  46. Quick Procharger Pulley question
  47. Spark Plug question...
  48. whats a good turbo cam?
  49. Anyone powershift into 5th?
  50. Used Procharger/superchargers
  51. any1 got vid's of supercharged lt1s on net?
  52. boost on stock 3.8
  53. 18+psi BOV
  54. Here's another place to get stainless header pipe
  55. supercharger ?
  56. Vortec bracket
  57. Supercharger and Daily Driver Wheres the Limit?
  58. Need K&N for procharger
  59. N-E 1 notice a difference in HP between Borla Plates (10+psi)
  60. T88 turbo kit..
  61. vortech head unit
  62. anyone wanna trade for my 224/236 cam?
  63. Good head unit?
  64. in need of a new clutch pressure plate flywheel etc..any sugggestions
  65. PTK cross-tube question
  66. Do u guys think could work?
  67. Is the STS kit emissions legal
  68. turbo spool quicker unhooked?
  69. 383/D1SC pulley experts please help
  70. Accel shorty plug??
  71. Need help with supercharging issues.
  72. modding plugs
  73. LOOK At this sleeper turbo set up!!
  74. How much boost should I run and at what compression?
  75. Where to buy low z injectors?
  76. anyone use cometic MLS gaskets?
  77. o ring the block or felpros with good head bolts?
  78. help me pick a custom cam for my new setup (thinking about a high lift cam)
  79. supercharger
  80. how low of a c/r can i make with 52cc heads?
  81. NEWBE STS Turbo Question
  82. Boost guage doesn't move, and Fuel cuts out.
  83. supercharged lt1
  84. supercharged lt1
  85. If I have no vacum lines, where do i hook up my boost/vacum gauge???
  86. How much boost can I safely get with 10.0 : 1 compression??
  87. first time at the track for MSM69Z28
  88. I LOVE my P1SC
  89. Where are you guys mounting your gauges at?
  90. Mr Gasket #5716 "Ultra Seal" Head Gaskets
  91. Will this get me past 500 rwhp...
  92. Traction ctrl removal
  93. single intercooler
  94. superfueler question...
  95. selling my msd 6al BTM
  96. Z28tt Progress Pictures!
  97. Procharger 3 Core Measurements.
  98. Just got in new maf
  99. Looking into...
  100. Cam for blower motors
  101. ATI D-1SC custom 8 rib kit for sale.....
  102. Air/Fuel ratio
  103. Twin turbo exhaust housing A/R
  104. 9psi
  105. 3rd gen T72 Turbo kit update
  106. p1sc need help
  107. Purchase a supercharger and receive 10% off your next purchase!
  108. Alittle over 400hp from the Suburban
  109. 6 or 8psi on a P1SC??
  110. Idle problem/ low end miss
  111. How loud does a 4" mufflex get on a blown setup
  112. Where to purchase parts for air/water intercooler?
  113. Unconventional Turbo Setup?
  114. small block headers compatible w/ LT1 heads?
  115. Supercharged AND Turbocharged?
  116. When is step up to billet recommended
  117. how to reclock an S trim ?
  118. Ordered a new cam today
  119. Woaho!
  120. IC: Efficiency Vs Flow
  121. Need help
  122. where to get an lt1 turbo kit?
  123. Engine Runs horrible
  124. Pulleying up... do I need a new bypass valve?
  125. Should I upgrade from an S trim to a T trim?
  126. Blower pulleys = what works?
  127. Boost and Spray??
  128. BTM required with boost?
  129. Turbo questions
  130. 224/236 vs. 227/239
  131. Does the STS Kit come with a BOV?
  132. Weiand/B&M 142/144 blowers???
  133. electric supercharger???
  134. Tires spinning, or clutch slipping.
  135. SFMU or Tune the OBDI or get a FAST?
  136. So what can you tell me about turbo cams?
  137. Lets say i had a turbo. What else would
  138. exhaust size ?
  139. How does this cam sound for a turbo?
  140. Runs bad in the rain
  141. Blown LT1/LT4 Engine Management Forums
  142. new supercharger, odd problems...
  143. Question about Turbos
  144. buying a LT1 turbo kit
  145. Need help! Crank spacer stuck!
  146. How does stroking an engine affect boost limits and detonation
  147. Do I have to remove my blower/brackets to install my cam??
  148. 3rd gen LT1 w/ATI procharger
  149. upping boost, fuel system questions
  150. ACCEL gen VII blower tunes
  151. Just bought Procharger!! :)
  152. Anyone have any big injectors for sale?
  153. Comp Cams tells me this cam for my setup???
  154. Wich pulley size for my 383 ( P1-SC)
  155. how much hp with 50#ers ?
  156. which bypass valve to run with 20 psi T trim ?
  157. stock LT1 + turbocharger
  158. Vortech & Procharger ?'s
  159. pics of a screw type
  160. single or twin
  161. I neeed 100LB injectors or close
  162. any downside to running bigger injectors than u need ? (96#)
  163. Ati P600b
  164. Exactly what Turbo would be good for an LT1
  165. Which rear end gear ratio with high boost ?
  166. how much boost is the stock vortech bypass valve good for ?
  167. Does anyone sell just the headers for a turbo kit?
  168. Preference for a turbo setup
  169. Procharger and head\cam selection
  170. Need to learn about forced induction
  171. SC belt measuring ???
  172. would a mustang T trim HU fit my brackets ?
  173. Where'd this extra pound come from?
  174. Best supercharger
  175. Alright teach me about forced induction!
  176. d1-belt problem-help
  177. anyone dealt with...
  178. boost and rpms
  179. boost and rpm
  180. Ls1 turbo options?
  181. Twin screw like this for the f-body.. very good option!!!
  182. if anyone is looking for a gen7 dfi kit...
  183. Boost is falling off.
  184. Any way to get a centrifugal s/c to build boost more quickly?
  185. all my FI stuff is for sale, tons of it
  186. Help
  187. Anyone try Megasquirt?
  188. 8 rib pulleys for sale, 7.85" crank, and blower pulleys
  189. New Turbo Company building custom kits
  190. Good Deal??
  191. Reliability of a SC LT1
  192. price of a T04
  193. Which Turbo Kit Would YOU go with?
  194. best clutch for daily driven turbo LT1?
  195. supercharger install
  196. supercharger
  197. ZZ4 Crate w/ Blower
  198. Water/alcohol Injection is for you!
  199. Pics. of Procharged 454 in my 80 Z28
  200. Is there a way to size a TB for a blown application?
  201. Alright then how much boost for a daily driver?
  202. New to FI
  203. Rear mounted turbo?
  204. help me with shopping list, building turbo LT1
  205. Add mild cam to low boost stock motor or leave stock cam in while replacing lifters?
  206. Fuel System Recommendations
  207. Supercharging a stock LT1...
  208. Tire Smoking ATI Supercharger specials!!!
  209. How to build your own turbo kit?
  210. powerdyne?
  211. LT Hookers versus AS&M Shorties with FI
  212. Walbro 255 intank
  213. What fuel injectors 5-600 RWHP?
  214. Miss above 4,000 rpm's
  215. People with over 9psi at 3k-4k what plug?
  216. Turbolocity Twin Turbo Kit
  217. Turbo update
  218. any progress with a ptk tubo kit
  219. various mods vs. forced induction
  220. FS: Vortech T-trim
  221. Basic turbo question????
  222. quick Procharger question
  223. Turbocharged vs. Supercharged
  224. S-Trim 383 Pulley Sizing Question
  225. The beast is out of its cage ... :)
  226. NGK TR6 what gap?
  227. Questions on my Components for my S-Trim install?
  228. f1 sc
  229. lt1 with V2
  230. procharger
  231. Newbie To boost, got some simple questions
  232. What are these ports?
  233. Opinions on blower cam
  234. Good Crate for Blower?
  235. What oil to run in blown motor in CA??
  236. Plug Suggestion for AFRs and Power Adder
  237. 611 rwhp 695 rwtq D-1SC w/cogs
  238. LS1 vs LT1
  239. Turbo/Compression Q's
  240. 2 Bar Map + stock pcm - seems to work fine
  241. Fabbing headers... what gauge tubing?
  242. Boost Calculatiosn Figuring out how much hp 14psi
  243. 355 questions
  244. turbo, 1.6 intake/1.5 exhaust Rockers
  245. supercharged
  246. o-ringing the heads
  247. ATI Procharger K&N Filter location
  248. Got my new 383/AFR/T-trim/aftercooler running
  249. I think I found a LT1 to rebuild for FI, but I have some questions.
  250. STS Rear mount turbo oil pump.
