Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Nitrous and alky
  2. Powerdyne internal belt?
  3. "Melrose t-top" valve covers hit shaft rockers
  4. Turbo kits for big block 69 Camaro?
  5. Cometic or Wire-Lock Head Gaskets?
  6. Car runs crappy on 9 lbs. of boost
  7. Stock heads with turbo?
  8. shaft rocker valve cover search continues
  9. Spark plugs and gaps.....lets hear it...
  10. Weiand 140
  11. Need help choosing turbo kits
  12. shopping for blower
  13. Paging Scz28!
  14. What is your set up (turbo guys)
  15. whats the diff between turbo, ,and superchargers
  16. Turbo charger help
  17. P1SC Question
  18. Cams for Turbos
  19. Need help with crankcase pressure?
  20. Twin turbo headers
  21. ATI PRO CHARGER on 89 IROC
  22. New plugs and still have a random HARD miss....
  23. Why are there so many fast turbo stangs but not f-body's
  24. extra intercooler
  25. Camshaft Question
  26. Short block assembly or stroker..
  27. How does a FMU recalibrator work?
  28. Will not pull past 4000 RPM
  29. Oil pressure problem
  30. vortech superchargers
  31. What to do for a new fuel system????...
  32. Just another reminder to those who are CONSIDERING a twin turbo kit....read inside!
  33. Holy oil temp!! Turbo guys
  34. Boost off the line
  35. Twin vs single turbo- where, when and why
  36. What are my options for inter/after cooling my s-trim setup???
  37. Pulling my hair out trying to find gates blower belt! Where to buy?
  38. lifting the heads?
  39. Adjusting BOV
  40. Program for new supercharged motor
  41. Twin Turbo setup
  42. How loud are T-Trims?
  43. header efficency
  44. anyone running an F1 procharger on thier LT1
  45. Holley roots type
  46. What the hell is going on with these pistons
  47. Going supercharged
  48. Do you need a large Turbo?
  49. 385 stroker, Rod hitting oil pan ?
  50. Supercharger w/ a nice whine to it
  51. Difference in trims?
  52. a few pics of my custom Formula single turbo kit....
  53. Help me pick my next mod
  54. One mean turbo
  55. how to hook up Racegate
  56. New to FI would like some suggestions
  57. Need Help...
  58. T-Trim Only making 5lb Boost
  59. Spun bearing = confusion 355/383/396?
  60. Nitrous with blower...
  61. Which Fuel Injectors?
  62. 711rwhp 745rwtq
  63. some rambling if you're bored..
  64. Cam Selection
  65. Stupid Question
  66. good blower for a daily driver?
  67. T trim does appear to have belt slip now
  68. Hard intake tube for P1SC?
  69. Ive got BOOST but NO inlet tubing
  70. Where do you get Vortech Cog info at ?
  71. weird ignition problem
  72. motor
  73. Thermostat ?
  74. looking into getting started
  75. is it just me, or do these hooker LT's hang mighty low?
  76. AFR's Hydra-Rev Kit. Anyone use it?
  77. what is a good price for a used powerdyne???
  78. Intercooler sizing
  79. Optimal timing with water/alky?
  80. Cam advice?????
  81. vortech vs procharger mounting differences ??..
  82. 210cc vs 220cc for my app
  83. Adding a turbo?
  84. Gear ratio opinions?
  85. Turbo parts?
  86. Summer supercharger sale!
  87. 600rwhp?????
  88. Whatsup with the Powerdyne Cobra Head solid intake tube???
  89. Who needs a Turbo for a project? for sale.
  90. ATI bracket drawing
  91. gn motor in a 4th gen f body
  92. 67-69 Ss
  93. Water pump problem - Vortech Aftercooler
  94. What short block for FI
  95. Whats my S/C Z worth??
  96. Problem with Crane?
  97. Anyone looking for a pair of t-66's?
  98. O-ring
  99. Who makes the best ignition?
  100. Pontiac folks with Procharger...need help with filter getting wet
  101. cog belt setup for prochargers...
  102. people using Turbo Tech kit and headers.
  103. Installing a P-1SC any hints.....
  104. Spark plug Q I can't find in search
  105. Where to buy a power pipe?
  106. At what point is it necessary to upgrade?
  107. Why higher LSA on cams for SC engines?
  108. Finally got some chassis dyno numbers for the ProCharged 540
  109. Did i do this right?
  110. Vaccum pumps, ......agian
  111. LS1 twin turbo
  112. Tranny Cooler & Intercoolers Fitment
  113. Low lift vs high lift?
  114. Sidepipes and Knock Sensor
  115. trouble with fmu
  116. Boost on hyp. pistons
  117. 2 Many Blowers!
  118. SuperCharger??
  119. rotate my racegate 1/4 turn?
  120. Torque Converter Brand for Hi-po Setups?
  121. Could using a FMU and an Inline Pump w/o a S/C Cause stumbling under loads
  122. Running take piping: ABS is completely in the way... need help
  123. anyone install intercooler under driver side headlite?
  124. Pulley combo's...
  125. electric water pump ok for FI lt1?
  126. All the pics i can get for FMIC setups plase
  127. Turbotech kit with solid Moroso motor mounts
  128. ATI install and pulley questions
  129. New motor smokes... alot...
  130. where do i get a cog setup for my procharger?
  131. fuel pump
  132. How much horsepower can a stock LS1 block handle?
  133. aftermarket computer
  134. Turbo Tech kit....is this alot of HP??
  135. Vortech E-trim Has anyone used it?
  136. How effective would this single turbo be?
  137. Engine problems...need help
  138. 10 PSI , intercooled, stock bottom LT1 on ebay
  139. 2 grand nat turbos on LT1?
  140. T76 Q-trim for turbo sale
  141. Maxed Maf?
  142. What would cause this????
  143. new procharger question
  144. Cam question?
  145. PVC pipe after the s'charger? (pressurized)
  146. Vortech Aftercooler
  147. AC Delco R42LTS Spark Plug ???
  148. T88 or 91mm+382Ab LS1+?
  149. How much horsepower can a stock block handle if?
  150. Looking for a Turbo Tech LT1 turbo manifold.
  151. Need some advice and suggestions from you guys
  152. Hot cam vs. Xe 218/230 114 vs 224/236 114
  153. Any of you running 3 plug ranges colder?
  154. anybody successfully used SC and small shot of nitrous?
  155. How loud is a D1?
  156. Can you run water injection instead of an inter/after cooler???
  157. turbo technology oil drain-back problem
  158. CC306 too much for blower?
  159. Powerdyne ?
  160. street/drag superchager
  161. TPI 383 ATI build up recommendations
  162. Turbo and timing, reliability ???'s (intense)
  163. 8# ATI reliable on LS1 Engine?
  164. Low Imp Injectors
  165. SC'd 3800 question
  166. turbo system done for $812.00
  167. stops pulling at 4000 rpm's
  168. What compression would you run??
  169. Ls1 cranks
  170. 8 PSI supercharger on a stock 97z28
  171. Good enough cam for now?
  172. Greddy Type-S BOV
  173. Forced Induction
  174. Engine Buildup Help!!
  175. S- trim
  176. forged speed pro's
  177. Forced Induction cam?
  178. 450rwhp then boom!!!!!
  179. Boost goes up to 3# then goes away...WTF?
  180. Intercoolers: Air-to-air vs. Water-to-air
  181. Guages install
  182. Boom #9
  183. Screw ball bearing turbos
  184. Need Turbo advice.. lots of questions for u pros
  185. Difference between D1 and D1SC
  186. Need part # for ATI belt with 8# pulley
  187. Attn: yellow Z28
  188. SD sping loaded tensioner
  189. D1 pulley question
  190. Dyno numbers for the JY twin turbos
  191. Question for anyone running Procharger F1 on a 4th gen.
  192. Pics of a very nice twin turbo LT1 Impala SS....
  193. Powerdyne 9psi pulley?
  194. What can I do to stop the plastic pipe on my Vortech from popping off?
  195. how dumb would it be to put a blower on an 90k mile lt1?
  196. Twin turbo question
  197. heeeeeeeeeellllllllllllllllppppppppppp
  198. I need to make contact with someone familiar with carbed RAJAY turbo setups
  199. HOw much power does a supercharger give ya?
  200. Rich or any other blower experts ......
  201. What pulley for a 383 w/ ATI P-1SC
  202. Twin Turbo
  203. Are you sure 42" belt is correct length for belt?
  204. breathers necessary on s/c'ed motor?
  205. Video of my procharged 69Z28
  206. Q's About ATI P600B
  207. What do I need to safely run 8# ATI on stock LS1?
  208. supercharger advice!!!!!
  209. Is there a CARB Turbo?
  210. FS: custom CAS intercooler
  211. Turbocharger installed for under $3,000.
  212. Front mount IC question
  213. What turbos are made for a LS1
  214. building motor for 500-600hp
  215. Ok got another new toy to play with :)
  216. need parts for a V9 kit 98 LS1
  217. WTB ati d1
  218. Magna Supercharger for c5
  219. kenne bell
  220. Turbo/Supercharger Help needed ASAP
  221. Info on CR with a YS-Trim?
  222. S/c?
  223. Who has the longest time/miles on their blower set up?
  224. less power with low compression, can it be made up with more boost???
  225. Throttle problems
  226. New motor New Dyno #'s ......
  227. lets talk "keeping things cool"
  228. 6 psi kit on heads and cam engine
  229. 8.97s @ 152 mph
  230. Big enough injectors for my setup?
  231. Big frame (industrial) T-76 for sale
  232. maf massager
  233. Procharger question
  234. Can I vent my bypass valve to the atmosphere???
  235. Turbo guys need this shirt
  236. how much boost with 9.5:1, also need advice on my next build
  237. LT4 Knock Sensor
  238. opinions on pistons for a 355 and where to get
  239. Will these heads work w/ my setup?
  240. F2 Procharger
  241. Best Brand
  242. LT1 turbocharger
  243. a couple recent pictures of my intercooler
  244. Any tips? P1SC
  245. breaking blower belts
  246. Looking for pics of where you guys mounted your BOV
  247. what rings to get file fit? press fit? what brand?
  248. belt problem
  249. Any word from the PTK guys?
  250. help with build up
