- Compression with Stock Bottom and 64cc Trick Flow Heads?
- need help...timing,race gas 12psi...
- Anyone running a 218/230/114 lsa have an idle clip?
- Running rich...getting annoyed lol
- Baseline 8psi dyno numbers in!
- spark plug heat range gap and brand
- Pushing my tune up harder
- made the leap!!! (F1A)
- Riddle me this
- bypass options...
- 3.12" vortech pulley for sale for LT1
- Thoughts on feeding a PT6776 into an s-trim on a 396
- Bearing change in Procharger for more RPM??
- Do I need a FMU with 48 injectors and only 6# boost?
- so i checked my ring gap......
- finally dyno'ed my car! ltx, s400, th400!
- Single 255lph + meth for 550hp crank?
- Powerdyne Question
- Timing retard accessory for MSD ignition
- Stock damper + thunderracing keyed hub
- LT1 turbo project
- SC IC Routing With ABS and AC???
- Is there really a market for a TT setup... give your opinions
- Metal in oil
- FMIC With In and Out on Driver's Side?
- SC MAF on Pressure Side after BOV?
- air to water I/C heat exchanger mounting???
- LT1 Boost New Pricing for the rest of the racing season
- Can Vortech V1/2/3 be Clocked for Intercooler on '97 Camaor?
- Pro ram intake?
- Article: Carbureted and Turbocharged LSX in 1993 Camaro
- i love my F1A!
- LT1 Supercharged Blow off valve
- WATER injection nozzle size?
- finally did some test and tune with my camaro! ltx, s475!
- Article: Show n'Go, Mark Koehler's 7 Second LSX Firebird
- 255lph pump confirmation
- Patriot Gold Extreme spring kit overkill for this setup? If so, any advice on cheaper
- vac lines way outa wack?
- Have you guys read about APS Turbos?
- short video of my car idleing
- Bought a Turbo Corvette, selling my Supercharged Trans Am
- Meth question...
- F1A on LT1 vids :)
- Boost + trick flow head LT1s, what springs are you
- HELP! Lt1 D1SC is is miss firing after 4600rpm
- Article: Steve Turley's 1998 Camaro runs 7.59@197MPH
- Need 60# Fuel Injectors
- Vortech Exchange Run Around
- Used turbo's
- what head gaskets for the high boosted guys?
- 229/245 114lsa cam for turbo; what do you think?
- 12 rib became a 10 rib :(
- how much power will i make?
- Throttle body question for supercharged cars
- quench and turbo?
- 1st Shakedown Pass in the Turbo Z28 LT1
- What is a good low boost supercharger for a stock motor?
- sts thoughts and opinions.
- SRP pistons for boost?
- I will never buy another Innovate product... ever
- Couple ?'s
- New to boost idea, couple of questions
- Budget forged motor 500RWHP Goal
- 93 lt1, P600B@8psi, hotcam: how much spark advance?
- Considering winter project (turbo related)
- Turbo'd TH350 owners using Vigilante TC
- How much to be gained?
- car is running
- will boost retard commanded by a MSD-6BTM show up on a frame scanner?
- Turbo + TH350 + Footbrake = What's your 'leave' technique?
- Lincoln Pro Mig 180
- Header Gaskets For Turbo
- Larger valves on p&p heads?
- pacesetter midlength for turbo headers?
- Gonna get rid of my f1a
- Boosted 396 help
- knock retard
- another 85 camaro build...but this one is mine!
- Got boost again....
- LT1 Boost Shop Car Kit for sale
- Why come we dont pull vac on PCV hardline?
- rebuild LT1 or go to 5.3
- If anyone is running a Vortech S/C and looking for a Brad Brand tube.....
- Procharger - 8lbs Stock Engine
- How hot is the supercharger supposed to be???
- sjm belt size
- How Much does a tight LSA REALLY affect a boosted motor
- Valvetrain questions with boost
- new times, 6.2@112 in the 8th!!!!!!
- Well I didn't break a piston
- A little surface rust in #4 cylinder...
- Aftercooler watertank in TRUNK
- Got me a new toy for the shop
- 76mm A/R Question?
- MP70 vs S400
- F1R or F2 under '69 SS hood?
- 20*F IAT AWIC @ 80*F Ambient
- Aight....
- Anybody going to run TTT5?
- Drove to the track, ran 9's, drove home
- poor boy wants to go fast and needs help
- Not an LT1 Pulley?
- Ordered the 9" housing today - What gears?
- Quick turbo question
- dirtydaveW new turbo header flanges :)
- Cheap turbo kit on ebay...any good?
- Installed 2nd BOV
- where can i find the intercooler i want?
- s trim pulley
- thinkin bout goin to the ltcc setup! anyone heard anything bad/failures?
- Custom LT1 sheet metal intake manifold for forced induction?
- Engine Build... Need Help.
- ok lets talk air filter (p1sc) guys
- My Ported Victor Jr vs. Ported LT1 Manifold results.
- Newb to Chargers: a couple of questions
- meth location
- Finally Got Boost!!!!!!!!!
