Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33
  1. Paging "mzgp5x"
  2. Need some advice for a buddy. stroker supercharged LT1
  3. Advice for 383 supercharged build.
  4. lt4 vs lt1 block for fi
  5. Just a smidge over 9.0 CR... Should I worry?
  6. inexpensive BOV
  7. PT88 dyno (900+hp)
  8. FI with KB118030-8, -22.00cc pistons?
  9. Hey guys, need some info on a couple turbos
  10. Need opinion on cam
  11. Can I make 1000 horsepower with an F1A
  12. LS1 Powerdyne Supercharger
  13. Where did you get your t76 gts?
  14. Jeezus - What kind of turbos are these?!
  15. 8 rib horsepower capabilities.
  16. ok high power opti cars come in please. what ignition box?
  17. Any interest in 3rg gen fbody kits?
  18. Turbo Tuning
  19. Is an intercooler really necessary?
  20. Got the TV75 in place
  21. LTX turbo cam for big power, non street car!
  22. Where the hell is everyone getting there pistons from?
  23. Some last minute decisions to make
  24. Dyno #'s:Bolt-on; cam; s-trim LT1
  25. 95z28_m6's Turbo build
  26. Procharger for V6 3.8 Camaro?
  27. critique my cam!
  28. how much diff will twin logs flow over tubular headers?
  29. vigilante torque converter 3800k+ w/ SC
  30. good info on water injection
  31. Absolute best heads money can buy????
  32. whos running solid mounts?
  33. bigger turbo than PT88?
  34. Help picking Cam????
  35. And the build continues (small update)
  36. Boost controller?
  37. What TC for procharged 383.
  38. Heads/cam + STS
  39. Modification to FLX 220 fans for fitment?
  40. My flex coupling imploded
  41. Everything is starting to fall in place
  42. Head studs or bolts?
  43. Thinking about FI for the LT1
  44. How do I go into "suck side" of blower
  45. Am I lifting my heads? More drama with the T/A!
  46. Compression Ratio???
  47. Thermal coating - tell me about it
  48. cam for a turbo?
  49. Need help tuning, i think
  50. Turbo maxed out. few math questions about injectors
  51. Need help with IC
  52. Pratt & Whitney
  53. What plugs for my trick flow heads
  54. LT1 Supercharger cam suggestion
  55. 10.1:1 Compression with 12lbs
  56. Anyone running the AEM Tru-Boost Controller?
  57. searching for big power boosted build thread
  58. How would you build my LT1?
  59. cam swap while apart?
  60. LE2 and Vortech
  61. Is my FMIC causing overheating?
  62. Where to buy JGS wastegate springs?
  63. Boost Kills... Hemi carnage pics to enjoy....
  64. ? On DP routing
  65. getting ready to order pistons
  66. Anyone use the new 79lb high Z injectors?
  67. Check out the new guage placement
  68. Turbo Cam Advance
  69. Blower cam specs.
  70. Paxton sn 93
  71. Air to liquid IC ?s
  72. JMD turbo kit?
  73. Getting hot after sts turbo
  74. supercharged lt1
  75. lt1 intercooler piping ???
  76. Anyone know the MAF limits on the LS controller?
  77. Switching to ms2 extra
  78. UP YOUR DRAIN HOLE!! BB vs Standard Bearings
  79. Anyone have a ZZ502 calibration?
  80. Need a second opinion
  81. Stutter issue
  82. Recommendation on plug for SC'd 496BB?
  83. Rear mount turbo questions
  84. blowby question
  85. I just ordered Dart Pro1 Heads
  86. Vortec boost issues..
  87. Looking to route my BOV exhaust to the ground. Suggestions?
  88. thick walled hotside piping
  89. fuel for boost?
  90. How much boost with my setup??
  91. Boost question
  92. Anyone use MSD 6AL-2 box on turbo motor?
  93. Need help on set-up 15psi of boost
  94. exhaust wrap on hotside question
  95. Large single vs twins
  96. A2W vs A2A
  97. verticle radiator ?! line from the back of the head?
  98. Merging!
  99. upgrade: S400 t6
  100. Turbo or Supercharger
  101. Anyone with subframe connectors and the STS kit?
  102. Next step??
  103. Injection Fluid - Pre Compressor?
  104. Blowby? / possible blown intake gasket
  105. Vortech Boost Problem *HELP*
  106. took out the LT1 Boost Turbo T/A for Maiden voyage
  107. back pressure vs cam anyone tested?
  108. Anyone ever... (stock bottom end question)
  109. PT88 74 camaro hotparts pics
  110. T-64 Turbo RWHP on LT1?
  111. Brace or support for turbo??
  112. Yay! Milkshake!
  113. Which header gaskets
  114. What pistons for 62cc heads
  115. 1st Gen Camaro w/lt1 Supercharged.
  116. What do we think about Flatout head gaskets?
  117. Blower pulley change? vortech
  118. "Splash D-Icer" for meth injection?
  119. getting front off for meth kit???
  120. Running without boost for a few weeks now
  121. ATI D-1SC 12 Rib Idler Pulley Bearings - Bad Design?
  122. A couple of question`s!
  123. I have a dumb question about my turbo....
  124. Procharger tuning questions?
  125. Couple quick questions on turbo build
  126. How much would my kit be worth?
  127. Spark Plugs
  128. Pics and vid of my new YSi setup
  129. Look what the delivery guy brought me.
  130. Am I too lean?
  131. im back for a couple more questions before i finish my part list
  132. Turbo's are fun
  133. WTF now.. DTC 43, car runs like crap after converter swap..
  134. getting ready for the s/c
  135. Pics of my trigger wheel and pickup
  136. ati fan modification question
  137. p1sc help
  138. p1sc help
  139. I have a D1SC with 826 miles on it.
  140. what to do now...
  141. I don't know what to do.
  142. adjustable bypass valve
  143. reamo04's dyno graph
  144. Truth of Reamo04's dyno graph
  145. Adjusting part throttle Air fuel ratio
  146. who bought jims old kit
  147. How Much Boost (LT1)?
  148. Toughts on this Rotating assembly
  149. Vortech head bolts stripped from the factory...
  150. Ram air on a speed density system
  151. IAT Gauge?
  152. STS Question?
  153. In case you big HP guys are interested in the McLeod SFI bellhousing...
  154. P600B idler pulley bearing replacement
  155. I'm stumped-Is the motor gone??
  156. going from 12-15psi on a p1sc..
  157. Help!! Ram Air Box Fitting Problems
  158. mustang dyno and dynojet hp comparison
  159. Do you add some color to your meth?
  160. Help me plan a fuel system for 800hp
  161. turbo LT1 build
  162. v8 turbo question
  163. O-ringing... heads vs block.
  164. 7000+ RPMs + stock PCM ?
  165. Evacuation or PCV through the exhaust
  166. well wtf, how do i fix this
  167. LT1 Booststreet Testing...
  168. boost gauge
  169. C16 or pump 110?
  170. post pics of your passenger side logs
  171. Who do you trust to work on your car??
  172. What do your timing tables look like?
  173. crankcase venting
  174. 383 + D1SC or (F1C) = 700 RWHP?
  175. What would you do?
  176. What do you look for in a Cam for Forced Induction?
  177. P1sc 8 inch crank 3.4 blower
  178. Can slipping tranny kill boost?
  179. Let's play the guess my rwhp game!
  180. Help D1CS car is running bad
  181. pistons? rods?
  182. First time to the track with the f1a
  183. greatly disapointed with dyno number :(
  184. Who has passed the tailpipe emissions test with a blower
  185. <10.0 A/F Ratio - How much on the table?
  186. Help me plan my motor
  187. Greddy boost controler
  188. Closed or Open Loop. Pros and cons of each
  189. How restrictive is my flowmaster with D1SC
  190. what fuel pressure?
  191. Turbo and engine temps..what do u guys do?
  192. My 00 WS6 Buildup
  193. Quick Spool
  194. Finally got some street time!
  195. turbos
  196. vented crankcase pics!
  197. Dyno Disapointment
  198. Hands in Pockets tuning fires up its MegaSquirted LS1
  199. Seimens High Z 60# inj for sale..
  200. wireing dual fuel pumps
  201. New Project... How about some input on setup...
  202. spark plugz
  203. front mounted innercooler?
  204. I used to have a plan.....
  205. breaking a vortech x trim motor in with out the belt
  206. Boost Bypass Question... Please Help!
  207. STS turbo and cats?
  208. What pistons should I run?
  209. Single plane blow through power range?
  210. How To Remove Pulley
  211. Pulley Key For P600b
  212. Cold air kits comparison
  213. IAC Relocation, worth the hassle?
  214. MSD6 BTM needed?
  215. whats the best next step?
  216. Anyone have the ATI 4.5# non-intercooled kit?
  217. water/air intercooler???
  218. Whats the least I need to do to make a car handle 8#?
  219. help on procharger set-up
  220. Using Summit WB O2 sensor with Meth???
  221. How much boost can my setup handle?
  222. How high to spin boosted 383?
  223. rings for my 355 kb pistons eagle rods 6psi
  224. Can a D1 Unit be Sneeked by CA Emissions?
  225. What ait cleaner fro LT1 D1SC twin IC?
  226. How much SC IC boost can a stock ls1 take?
  227. Budget Minded 500whp (LT1)
  228. Running Crappy
  229. How much boost does a D1 with a big pulley make on a stock size engine?
  230. Finally got a WB O2 sensor...
  231. h-beam rods
  232. Is my belt slipping? video inside.
  233. Between P1SC and V2-SQ, Which Produces Less Heat Per # Boost?
  234. Single Plane or Stock intake on LT1?
  235. Heads and cam to make 600 or more to wheels
  236. Need advice: go from S-trim to YSI or to turbo?
  237. Carbureted Turbo 383 build
  238. Fastest STS turbo LS1?
  239. Mass air meter for a turbo
  240. Just to make sure I have it all right
  241. How much water alky to run
  242. Someone Please Send Me a Clean '95 4L60E .bin
  243. Do Most Use Some Type Of Boost Sensing Timing Control?
  244. What Tables in a '95 PCM Actually do Anything?
  245. How much Boost Per RPM? (6# Setup).
  246. procharger or turbo
  247. Which 2 step!!!!
  248. Can Jet TunerCat for ODB2 Fix MAF HIGH Freq Error?
  249. What oil pan are you guys using?
  250. Does P1SC Need to be taken off to change its oil?
