Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33
  1. engine break-in, with or without boost?
  2. Single T76 LT1 Just Back from the Dyno-
  3. Which plugs do I have?
  4. LT1 turbo oiling
  5. LT1 injector size to run a turbo
  6. VRE 383 Turbo LT1
  7. Whos built a DIY A2W intercooler?
  8. what to do with Optispark vent lines?
  9. Bottom end and internals for 600+hp D1SC.
  10. Where would I find this?
  11. Help with LT1 smog pump removal.
  12. Pulley swap question
  13. Well Guys...
  14. FMIC vs Meth vs Both???
  15. Head selection for D1SC 383???
  16. STS install questions
  17. New Install Quest?????????
  18. Boost question???
  19. Starting Build,Questions so i get it right the 1st time
  20. What type of spark plugs for a turbocharged car
  21. Ebay wastegate - I think I am forcing it open
  22. 383 stroker.... s/c ?
  23. LT1 Eaton M112 dyno and site update!
  24. BMR's 8 second turbo camaro "Radiator relocation and and bumper support fab
  25. Hows this fuel press on new charger???
  26. Yet another turbo LT1 project...
  27. Has anyone used the lingenfelter 100mm MAF?
  28. Help--No Boost
  29. Switchable tune from E85 to pump gas.
  30. stock map. How does the pcm add fuel for boost?
  31. Turbo LT1 for sale in MI
  32. blowthrew carb help
  33. Info on Weiand 142 LT1??
  34. When is an aftermarket radiator needed?
  35. Rear mount trubo @ ypipe?
  36. Intercooler piping for RealQuicks Log setup
  37. Fuel pressure regulator for eaton s/c setup?
  38. no boost with Vortech
  39. Reducer (4" oval to 3.5" round)
  40. Mustang for Breakfast, SuperBee for lunch and Evo for supper :)
  41. Anything wrong with this D1SC?
  42. yet another problem on my turbo build!
  43. Open chambers on lt1
  44. MP 122 Blower
  45. Ac
  46. new setup cost...what do you think?
  47. what would you think
  48. Stock "high" Compression + Boost + E85 =?
  49. Turbo questions
  50. Anyone supercharged and converted to a single plane?
  51. Help with F1A 355 LT4 build
  52. water meth question
  53. back up and running
  54. P1 problems
  55. Opti Venting With MAF on Pressure Side?
  56. Supercharger dampner???
  57. Turbo Intake Elbow - Suggestion Needed for Tight Clearance *pic*
  58. ATI bracket compatibility ?
  59. Dyno tune for Procharger????
  60. turbo soon...
  61. 406 871 Weiland Blower.. E85 or Meth???
  62. Gt4082
  63. Supercharger question?
  64. Got tuned!
  65. O ringed or not?
  66. Ysi Remotly streetable?
  67. STS low spooling
  68. Oil pump
  69. My Kit is HERE!!!
  70. LT1 Boost back in business!!!
  71. HELP! need advice from forced induction GURUs
  72. Turbo Flutter
  73. How much boost to run with LS3?
  74. Paxton Supercharger with Long Tubes
  75. fuel pump stuff
  76. BOV setup procedure
  77. 4" Dryer Hose - Where to buy?
  78. 383 w/ t-trim
  79. You must check this out!!!
  80. LT1 Boost looking for suggestions
  81. Plug gaps - Don't be afraid to close them.
  82. eBoost2 Boost Controller.
  83. New owner of my car taking to track saterday...
  84. disappointing numbers
  85. Looking for a budget 355 rotating assembly...
  86. Replacing meth with denatured alcohol
  87. Lt1 Boost twin turbo Build Up
  88. My car vs a 2000 MTI 382 with a 200 shot?
  89. Looking for low 12's with supercharger
  90. Boost w/ 11:1 CR
  91. Cam questions for lt1 w/d1
  92. Is this a good deal?
  93. LT1 Boost Complete Kit pricing!
  94. New to the FI area, and had a few questions
  95. D1 procharger intake dryer hose
  96. Anyone ever damage a brake booster?
  97. where did you buy your f1a?
  98. questions on 600b
  99. LT1 Boost Budget Kit Build
  100. comp cam 292xfi
  101. Turbo 383 cam help...
  102. D1SC pulleys hitting fan motors. Need advice!
  103. Need Some Help!! For my F.I after dyno.
  104. Joining the Turbo club!!
  105. Back from Tuning and car is acting strange! Help!!
  106. well... finally got the front mount bolted up with a little bit of piping set-up
  107. ProCharger video challenge
  108. Slight issue--trick flow elbow
  109. Best cam for a t3 turbo lt1
  110. who has experience with EGT?
  111. Mufflex...just made my purchase
  112. larger crank pulley, boost change?
  113. what about a t70 in a 5.7
  114. So many intakes. Which one?
  115. MP T70 owners - has anyone maxed one yet?
  116. Mechanical boost gauge people
  117. STS With LongTubes
  118. How much power should I make with this set-up
  119. lt1 turbo cam
  120. my adventure to lt1 boost
  121. My car was on the dyno again yesterday...
  122. FI, meth, and tuning question...
  123. how many guys making 800+
  124. cast manifold turbo guys
  125. Procharger with crane 227 cam
  126. October Special on Turbo kits!
  127. Is this going to kill my forged 383??
  128. Whats better Speed Density or MAF
  129. need instrutions for ati procharger install
  130. Any expirence with the S380 BW turbo?
  131. Best mods for a supercharger?
  132. LT1 timing for turbo
  133. LT1 P1SC boost limit?
  134. Ignition troubleshooting
  135. Fuel Pressure Guage Installation
  136. Hit the dyno again
  137. Turbo in...:)
  138. LT1 short block. 2400 OBO Built, all forged, boost
  139. Will this work good for a procharger?
  140. LT1 Boost Shop Car Build thread
  141. Project BoostedROC....Iroc383LT1 Turbo Build.
  142. "How To" Mount Intercooler
  143. New cam spec'd sound good?
  144. Turbine Coatings - Any that work?
  145. oil pan questions for my D1 383
  146. Where to buy intercooler?
  147. how to figure out boosted compression
  148. Building another LT1...which pistons this time?
  149. What thickness head gaskets should I get???
  150. Would it be possible to fit two Turbonetics GTK-550 in a 4th gen engine compartment?
  151. Any interest in S400 Turbo kits?
  152. what are others doing to vent the crank case?
  153. Twin Turbo LT1 kit question
  154. vortech crank pulley depth
  155. Pics of vetical radiator setups please.. Griffin 25241..
  156. What header flanges?
  157. .96 ar T70 f/s
  158. Question regarding loss of coolant on my Turbo car...
  159. Turbo oil restrictors causing smoke?
  160. Video from the 1/8 mile track
  161. pretty nice tt setup on ebay
  162. TC78 97 Camaro in For sale section
  163. Those of you running oil scavenge pump or alky kits...
  164. New build plans....
  165. Looking for a donor car for a TT setup that keeps all factory accessories
  166. Well a lil update
  167. 5W-30 or ?
  168. Oil port for turbo AND Oil cooler?
  169. Huge Savings On Turbo Kits for Xmas!!!!!!!
  170. Pulley size vs. rpm
  171. Replacing Head Gaskets this morning. Question though....
  172. Intercooler for STS kit -- vortech aftercooler??
  173. Few Questions about my fuel
  174. LT1 Boost, need info guys
  175. Intercooler, Alcohol injection or both...
  176. 78# High Z or 96# Low Z?
  177. How much power?
  178. Supercharged LS1 T/A fuel system
  179. Bringing back my old formula
  180. finally got my headers finished
  181. exhaust for a turbo??
  182. good LT1 turbo topend?
  183. upper rad. hose clearance
  184. LT1 Boost TT hotparts for sale cheap
  185. tubing for headers
  186. Upgrade S-Trim to Si-Trim (just a new impeller) or go to T-trim?
  187. Recommended coolant pump for air/water intercooler?
  188. Cam Help Please
  189. my turbo build!! solid roller 383 and GT42
  190. forged 355 supercharged trans am almost complete
  191. Vortech belt tensioner?
  192. injector size ?
  193. Dyno Numbers!
  194. What is the difference between.....
  195. -3 or-4 oil supply line???
  196. 7.0 to 7.65" Crank Pulley with 4.0" Blower Pulley
  197. 1/4 mile track video
  198. supercharger
  199. What size injectors for 6lbs of boost?
  200. A couple twin 255 questions on my layout.
  201. Going twins, couple quick questions.
  202. Stock crank limits?
  203. Short Block For ~700RWHP?
  204. T76 vs F1/F1a
  205. throttle body elbow hose
  206. My 10# 355ci build
  207. Whats Needed in a 650+hp FI Setup?
  208. Vortech Clearance
  209. What heads to pair with this shortblock??
  210. Where to find overdrive crank pulley for vortech?
  211. Max hp with a p600b
  212. 600b and cam swap
  213. This is the friendliest forum on Cz28.com...
  214. Who wants to know how much power 1 5/8 turbo headers can make?
  215. Msd btm?
  216. Freezing temps = 22psi !!
  217. anybody with 5" downpipe?
  218. premade logs for you DIYers
  219. Mahle pistons?
  220. Where to find powerdyne bracket
  221. okay....tunercats tune for 8-12PSi..help
  222. yipee! look what showed up today
  223. Post your turbo/blower head unit pics!
  224. who is running ltx shootout?
  225. What's the Difference??? TC vs T Series Turbos
  226. Will a loose rocker net higher PSI???
  227. Cloyes DR, ATI BB Hub, ASP 7" 8- rib pulley question
  228. MSD 2 step "stutter box" backfire!
  229. Starting to think about a trans....
  230. Fastbird93's Single Turbo Build Thread
  231. FS: Turbonetics T-76
  232. Thinking about a cam swap, thoughts?
  233. Another Turbo Cam Discussion
  234. Monoblade... anyone?
  235. Anybody with either 88mm turbos or any T6 turbos?
  236. DIY turbo shield
  237. boosted lt1 paxton
  238. Some up and coming dyno tests
  239. Almost Time To Be Rolling Again!!!
  240. S or T- Trim vs P600b
  241. Fluidampr damper with a blower?
  242. Help with pvc - Oil everywhere etc
  243. Oil type and Oil cooler?'s
  244. 262/266 630/630 114 lsa
  245. Just a heads up... GP going on for LT1 Boost Sales
  246. Is it worth it to get a tubular K-member?
  247. where to get dport header flange?
  248. Question about boost.
  249. turbo consistency?
  250. LS1 Turbo Setup
