- Getting knock at wot
- Help me choose a cam.
- Procharger Oil Feed Kit??
- vertical radiator questions
- Intercooler is mounted
- Aeromotive AFPR
- update on my car
- Issus with my System
- Build almost done -- HP/Torque guess
- Spark Plug Issue
- Where to find a stock LT1 crank
- Want to put F1A on this 383, but its 11.8:1 and need heads!
- can you reverse wire a fan?
- My progress pics of the last week
- Afpr
- Test fitted these today...
- High compression and turbo!
- Root cause of throwing belts?
- ProCharger Racers...
- The Super Car!
- Turbo questions. Couplers....
- Need 3.15 Pully Procharger.
- So my car is slower now.
- Turbo and FMU
- Anyone tune with megasquirt yet?
- O2's sensor reading while going WOT
- my turbo lt1 vs stroker supra
- Manifolds
- Anyone running a F-2?
- Manny Kit for Sale
- if you have used a mbc come in!!! Hallman Pro Kit or JoePMBC Pro-Z?
- Stock motor vs iat vs #boost
- Running without the sc belt
- What kind of MPG are you getting with 50# injectors?
- Camaro ls1 turbo kit
- Getting close! (Long!)
- Which H20 pump, CSR or Meziere?
- turbo install, questions
- in 95 camaro lt1 w air buildup
- LT1 SS Impala
- Look what I found in my turbo
- Question for you vertical radiator guys
- Think I ran into a problem (drain related)
- is 106mm turbo over kill for a 383 lt1/lt4
- AFR 227+ Edelbrock LT4 intake gaskets? (F.I. 383)
- Pro charged ls1
- stock tb and sc
- Evacuation Hooked up Wrong?
- Fuel Setups with HP
- Valve springs
- Another vent question
- Which Crank?
- Found my problem (crank case venting)
- how many turbo guys have an oil temp gauge and what temps ar eyou seeing?
- Turbo and Heat Protection
- Will This Work?
- Sneak Peek ! Magnuson LT1
- How would you do it...turbo?
- Now burning E85...
- Started my turbo build pictures..
- Turbo Ls1 Help
- laying over at 5000+ rpms...
- what cid is best for a blow thru set 370 thru 434cid
- 2 bar map sensor part number?
- EGT Sensor?
- Paxton SN2000 on LT1
- Poll: SS and Supercharged
- Is this ABS or TCS ( in my way for procharger)
- Viren Singh is a great guy!!
- Plug above filter?
- which exhaust?
- Procharger guys..Ever try using one of these Air filters right on the Blower inlet?
- noob
- thick copper exhaust manifold gaskets
- Turbo kit FOR SALE!
- APS twin results on 8 pounds of boost
- T 70 on 383
- Reflashing Stall?
- I know this has been beaten to death, but..
- Question on oil pump
- Idler arm? ProCharger
- Is this bad?
- New best at the Shootout
- Platinum plugs
- 3rd gen turbo pics
- D1SC pulley for max boost without overspin.
- inlet temps with air to air
- Help me decide on some Forced Induction combo ideas...
- Thinking about going from F1A to Single Turbo..yay or nay
- My 355 Parts List
- Injector Size For E85
- How durable is your ceramic coating?
- What BOV's are you guys using?
- Third gen supercharged 355 tech help...
- boost guage!
- Turbonetics HP66
- Traction cont relocation kit IDEAS????
- High impedance injecot limits
- should i do it or not?? need help
- procharger bracket
- Age old question (Deciding on piston)
- cross over tube size.does size matter is the ?
- New to Camaros. Supercharger Question
- Lil Procharger vid
- Anyone ever upgrade from an ATI 2 to an ATI 3 core IC?
- Car bucking when going from Vac to boost
- Seafoam Q's
- whatcha think?
- New to the boost game
- Ross Blower Piston
- Turbo sizing for a 383?
- goin boosted
- Turbo Long Block is ready at last
- Ready To Mount Intercooler
- Boost guesses?
- ever foul plugs so bad the car wont start?
- Fuel Pump Question
- Boost guage tap questions
- How much flex is needed for turbo exhaust?
- LT1 caprice turbo build
- Magnuson LT1 First Trials Video!
- Whats limiting my HP/TQ - Intake, Heads, Cam, Supercharger?
- What oil are you guys running?
- Which meth/water injection kit?
- Fast t56 guy's inside
- Those running 'realquicks' log manifold...question
- new to boost
- Boost Guage
- Wanting a turbo need help plz
- this good buy
- turbo guys what speed stall? th400 perfered!
- Kenny Bell 03 Cobra calling out my Supercharged LT1...
- Need to get rid of some turbo parts.
- Boost/pressure closing AC door?
- Some more recent vids of my car...
- Masterpower GT45??
- procharger belt
- Procharger supercharger
- Problems with Procharger D1-SC setup
- Cam suggestions 383 D1sc, AFR 210 LT4s ??
- Wastegate vacuum signal tubing-What are you using?
- Looking for a shop near TN for Superchargerinstall/engine swap!!
- PCV.. .what do you F.I. guys do to keep that from popping out?
- RealQuicks Hotside parts quality...
- Quick quest regarding PCV on Procharger setup.
- Post Pics/Links of your LT1 Intercooler routing
- Countdown for my Turbo LT1 has begun..
- What are these holes in the compressor for?
- How much would this throw off my sound FI tune?
- What gears for F1A 355
- FMIC in the for sale section
- Cheapest Way To ad 5LBS ob boost to my build?
- Turbo Build - Pics & Questions
- Vortech heat exchanger replacement?
- Aftercooler leaks water into intake!
- overboosting like crazy
- trickflow sparkplugs
- which oil scavange pump are you guys using
- Need some help from those with S/C LT-1s PLEASE!
- Finally made a little progress - Now running out of gas
- Driving to dyno tune with new supercharger????
- The future of "LT1 Boost"
- Vortech YSi users, a question for ya......
- 3.5" to 3.0" reducer, where did you find one?
- PTK Install in progress... some questions
- Name that BOV!!
- Small teaser video
- supercharger experts
- intercooler
- Twin Turbo vid, Mid mount near Trans bell?
- Opti vent
- Hp estimate for a fi 383
- i-charger
- help! car died and wont start!!!!!
- Supercharger Sound/whine??
- 1,000 RWHP Twin Turbo LSx
- Holy WOW STS are loud
- Car not boosting, think wastegate problem
- intercooler difference
- Those Running RealQuicks Log manifolds(another question)
- honest fuel milage
- A sad day(parting out my setup)
- Any one need injectors? 65#, brand new
- F.A.S.T. standlaone system for you forced induction guys 4-sale
- Got the car today(FINALLY!) Now, Diagnosis-Advice?
- 96 Turbo ImpalaSS LT1 Video
- intercooler routing
- o2's and maf replacement recomendations?
- differences Between Turbo Trims?
- Speed Density and stock MAP Sensor Tunes
- LT1 2 Bar Map Sensor Part number?
- Weird O2 behavior (and they're new!)
- Question on the sheet metal intakes for the FI cars...
- PCV System Check Valve
- ATI Super Damper Worth It?
- T76 60# injectors at fault?
- Where to put the driver side O2?
- wide band location with twins
- FPR Question
- Who did your tune?
- 5.3 swapped into 96 T/a 56k warning
- Small quarter mile video
- 4 DEG. if Spark Retard at IDLE?
- Double pumper fuel pumps...Pressure question?
- Blower/bypass valve making different noise.
- Finally figured out what happened at the LTx Shootout
- CAM guru's---112 LSA on a 383 w/blower.
- What pulley to make 13-15lbs on a 383 with D1SC?
- Requiem for a turbo LT1
- Procharger filter location??
- Bling Bling! Where to get colored silicone piping?
- Loss..96 TTA vs 07 TT c6...
- Selling my REALQUICK turbo setup
- Anti-Surge system?????
- Found my boost leak
- Should the 45* elbow sit on the brake distribution block?
- Belt Length with SDCE tensioner??
- tuning question (low boost/high boost)
- Got some work done
- Track times for my car
- Max Valve overlap for F.I.?
- need lots of help
- Madman Alt relocation with turbo?
- How about this Lingenfelter cam?
- Will my D1SC get louder?
- Blue Smoke on Decel and Downshifts
- turbo set-up for LT1 besides sts?
- boost on stock crank and rods.
- blowby with sts...poss pcv issue?
- What header gaskets?
- I need a CHECK VALVE, which one?????
- Starting Gap on Autolite 103's for 15lbs boost?
- Castrol TWS Motorsport 10W-60
- Well.. =( car is for sale. Turbo 5.3 T/a
- Help!! Coolant loss and now its found but makes no sense???
- Superchaged LT1 in a 1st Gen?
- Rear mount turbo, and regular turbo ???s
- 3" Blow Off Valve Piping. WTB?
- Finally have boost
- Head Stud sealant??? Help, QUICK!!!
- started a turbo project
- Just dyno'd with new blower
- What PSI spring are you running in your Turbo BOV?
- P600B gave up.....turbo?
- Vortech V2 SQ S-trim on a 383?
- Took the TC76 w/MPS Wheel out for a couple of 3rd gear passes tonight...
- 85mm Ls1 Style Maf 5 Wire Calibration Needed
- Delteq & Rev Limiter?
- Ebay Find
- My formula in GMhightech magazine...
