Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Supercharging LT1. What all is required?
  2. Inline fuel pump NOISE?
  3. Anyone use MSD boost a pump?
  4. Oil in ATI intercooler??
  5. TurboTec RW#S w/T76 and....
  6. Running 42 lb injectors, is a PCM reprogram necessary to get it to run right?
  7. Procharger question.
  8. Propane = richer?
  9. YS Trim induction pictures...need help!
  10. Racing a turbo car…
  11. New Best for my Powerdyne
  12. Daily driver LT1 with froced induction???
  13. nitrous express n-tercooler kit?????
  14. new intercooler pix posted
  15. Twin Turbo+TNT=Crazy?????
  16. Important advice for those with Vortech's and shorties
  17. Problems with Aeromotive Adjustable FPR? Anyone else have this??
  18. Can you manipulate the pully combos to start making boost lower???
  19. Question about single turbo setups...
  20. Question on Performance of 8psi
  21. Gapless rings for a supercharged engine?
  22. Max boost from a P1SC on a 383
  23. Supercharger for third Gen
  24. Cam with Supercharger Help!
  25. CW or CCW rotation?
  26. have had blower on car for 3 years need some advice for stage 2 rebuild
  27. FAST tuning
  28. Two serious questions, need help please.
  29. 383 Advantages
  30. Help LOW BOOST !
  31. Knock retard gurus, please step inside
  32. Thoughts on Paxton SN-93 Supercharger?
  33. Recomendations
  34. Is this OK?
  35. Any setups like this for LS1 Camaros?
  36. Anybody know what's up with the BMR Fabrication 4th gen 8 sec. turbo F-body project?
  37. Need help w/ Propane injection.
  38. ARP head studs on LT1 question ???
  39. 42# vs 50# high Z injectors for drivability?
  40. At what boost level is O-ringing the block neccessary?
  41. I think I may be close to joining "The Club"
  42. Another dyno disaster........questions...
  43. Are these specs good as a blower cam...
  44. Accel 36lbs. Injectors fine???
  45. Mondo bypass valve flange ?
  46. Another new best for my Powerdyne SS
  47. v6 turbos...
  48. LS1 and Turbos...
  49. who uses powerdyne supercharger on their LS1
  50. t-bo on a ls1
  51. Turbo Tech kit, what BOV??
  52. Turbo cam?
  53. Building A Shortblock for a Blower
  54. Improvements to Vortech Aftercooler?
  55. How fast does my car have to be before....
  56. ATI Install
  57. Supercharger??
  58. Updated LT1 single turbo pics
  59. Supercharger help!!!
  60. someone tell me about the ATI procharger
  61. Where to start to learn about turbocharging?
  62. What shold Fuel Pressure be set at with a stroked/blown LT1?
  63. RKrause ... you have mail
  64. Exhaust gaskets (Jordon???)
  65. YS trim and brackets and vortech Aftercooler
  66. Piston selection for 350-355
  67. F1 R on LT1.......
  68. For sale : Polished Mondo Bypass valve
  69. What sized screw fitting is going into the fuel line T-Block?
  70. Finally they updated the build-up on the BMR project car....
  71. Will a GMAF make any diff on boost?
  72. Miss and SES light at 4800 RPM
  73. Should I or shouldn't I.....
  74. functional air scoop with SC?
  75. Writing Report on Superchargers: Need Help
  76. Tune Time
  77. ATI in-line pump
  78. Big injectors
  79. CR on a 383
  80. Tapping tank?
  81. Fastest on a p600b?
  82. Racetronix Twin in-tank pumps
  83. Supercharger Question / Dilemma
  84. Check this out - Negative supercharging
  85. Inline Pump Q...
  86. Help! Rattling sound from procharger p1sc at idle?
  87. Solid Intake for D1SC
  88. Who is using a MECHANICAL FUEL PRESSURE gauge???
  89. Supercharger Application
  90. 6lbs
  91. Couple of weird knock questions... this post will become useful.
  92. T88 turbo Q's
  93. Fuel pump?
  94. roots supercharger app?
  95. 3.42 to 3.73 worth it on Supercharged Z
  96. Exhaust Gas Temperature
  97. Need source for silicone hose connectors
  98. Need FAST Program for 83 lb injectors
  99. Can I get some links to the Walbro fuel pump installs???
  100. How are emissions affected with FI?
  101. Looking for reccomendations for FI piston rings
  102. what will i need to do??
  103. Best price on a Walbro 340M??????
  104. low-cr 383 LT1 pistons
  105. Slight High RPM break-up! Is it MSD BTM TIME?
  106. whats the cost of having a tech install a supercharger
  107. 2 weeks and almost 2k miles...
  108. Composite head gaskets?
  109. PTK kit has arrived
  110. Anybody have a 6# vortech with my mods???
  111. How do you make sure a vortech pulley is tightened???
  112. Supercharger special!
  113. What clutch you running?
  114. Tubing question
  115. anybody have experience with magnacharger for ls1 c5.
  116. Anyone running SPEC stage 4?
  117. Has anyone fabbed up a solid intake tube for VORTECH S-trim?
  118. P1sc Oil Change Questions
  119. My Project is almost completed.
  120. How much fuel pressure S-trim
  121. Dyno results are in!!!!!
  122. Where to find 4" tubing
  123. If I were to stumble across $8000-$9000
  124. New Motor
  125. Blower belt?
  126. Who uses copper head gaskets?
  127. D1SC guys...need some info
  128. low oil pressure after s/c install
  129. Knock retard from blown header gaskets?
  130. Weiand 6-71 Street Supercharger
  131. Good price for Procharger
  132. fuel rail pics with -AN fittings
  133. Vortech Aftercooler guys.. chime in
  134. Powerdyne pulley?
  135. My project is getting boost, What do I need for fuel?
  136. Whats needed for a 12rib setup?(procharger)
  137. TBI+supercharger?
  138. 95 lb/hr injectors are streetable!
  139. Aftercooler Water Pump
  140. Just got a turbo
  141. Car still running hot!?!?
  142. Rochestor(sp?) 50lb injectors?
  143. What happens when the MAF Maxes? Symptoms?
  144. Who runs an oil cooler
  145. FMU working?
  146. Who has delt with SD-Concepts
  147. New Powerdyne 6 psi install w/pics
  148. ? on a 383bottom end we just put together
  149. gen 6 dfi help?
  150. procharger?
  151. Vortech pulleys and boost... Need advice
  152. Finally got car back...
  153. turbo cam for sale
  154. Fans for intercoolers?
  155. S-trim guys- with in please
  156. Car whacking rev limiter.....
  157. New Pictures of PTK's Turbo Kit
  158. Just bought two Rajay turbos and installation kit for sbc, will it work on LT1?
  159. Well looky looky what I found...
  160. My Orange tube replacement...Pics inside!
  161. Never let a new motor overheat
  162. Entry level blowers or turbo kits
  163. ProTurbo kit installed on LT1
  164. Anyone use an engine tie down chain/strap?
  165. After S/C install motor quits after 4k RPM Help!!
  166. Question for you blown guys
  167. Anyone use the Tech Edge Wideband?
  168. Please help with engine rebuild!!!
  169. engine layout and tune please :)
  170. Any Pros and Cons with using Toluene?
  171. By-Pass for 6PSI Pulley........
  172. Twin screw supercharger
  173. Turbo Selection Help
  174. How much timing are you guys running at WOT?
  175. anyone have one?
  176. 383 LT1 w/ P600B & Nitrous
  177. Supercharger Videos/Soundclips
  178. Why no noise?
  179. Knocking on 6th gear
  180. Turbo cam?
  181. Single turbo setup is up and running.
  182. wtb procharger for 93 z28
  183. I'm hitting a wall at 4800RPM???
  184. blower for my 91?
  185. Anyone Successfully Running An STB W/The Aftercooler Setup?
  186. blower cam
  187. Billet 4130 LT1/4 balancer hub
  188. Ignition break up under boost
  189. Blower Piston / Wrist Pin Question
  190. FINALLY some more updates on the turbo car
  191. interesting info for anyone running accel fuel injectors
  192. Looking to upgrade to d1?Quick!!
  193. anyone use PVC pipe for a hard pipe (procharger)
  194. My near future plans - will I get to 550 rwhp???
  195. Some Supercharging Questions
  196. Vortech pulleys 6.66 / 2.95 how much boost do you see with them
  197. Will a Volvo Intercooler work with a S-trim
  198. More air to the rad by removing fog lights?
  199. Can someone tell me a good s/c set up!
  200. Is this possible????
  201. Car cuts bad after S/C install help!!!
  202. Will the NOS Fuel pump from holley work with a Vortech S-Trim??
  203. Electric Supercharger kit?
  204. Compression ratio question
  205. ATI ProChargers ???
  206. Need your advice please
  207. Building LTI turbo, need some info
  208. anybody who has put a turbo where is didnt belong please inside.
  209. Lt1 + Vortech....?
  210. Can i take blower belt off and floor the car?
  211. t-25
  212. Eaton M112 LT1 Project near completed.
  213. Mods to d1sc to make 15lbsof boost on built motor.
  214. ????'s about procharger
  215. PLEASE help...safest tuning for s/c
  216. Boost Controller For-sale
  217. Need ATI 2 core specs
  218. Cog pully set up forD1SC ?
  219. Fuel management with LT1 turbo set-ups
  220. dual spal 11" fans?
  221. Newbie advice on Procharger..
  222. Rear End for Twins
  223. Twin turbo car finished!!
  224. Boost Gauge Question
  225. what injectors for boost????
  226. spa dual gauges
  227. Compression Ratio Advice
  228. D-1sc kits
  229. Oil leak with high volume oil pump
  230. Aftercooler dyno numbers and other stuff
  231. Eaton RUNS!! LOUD PROBLEMS WITHIN..
  232. Any safe/easy mods for supercharged 3.8 GM motor?
  233. SC Engine rebuild
  234. Oil feed line
  235. How's this for a reliability check
  236. An impressed newbie
  237. Pulleing up the S-trim.. what would be the gain.. or losses???
  238. Anyone need turbo headers for your LT1?
  239. post your 0-60, and 1/4 times
  240. weird problem
  241. *drools*......this is just plain sick
  242. 5% off superchargers until 5/27!
  243. Aeromotive fuel pump? Or Weldon? Or?
  244. What kind of ignition systems are you guys runing with 9psi+
  245. Need BTM Installation Instructions
  246. vortech belt length
  247. what do you guys think? 406smblk forced?
  248. Holley Pro-Jection + Procharger?
  249. Valve lash adjustment and Timing questions
  250. Tuning a blower motor
