Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33
  1. Who is running F1 Prochargers on LT1's ?
  2. ATI Hub Engagement on Crank
  3. oil return line pics?
  4. vortec aftercooler question
  5. F.A.S.T users (Roadie, John), the car is running.
  6. 383 what size turbo?
  7. Opinion Time : Upgrade P1 or N2O
  8. mild boost twin t3 ls1? need help info and ideas.
  9. Little Dyno Vid
  10. Procharger "Battle of the Outlaws"
  11. Limit of stock crank & 2-bolt mains?...
  12. 1 7/8 headers too big?
  13. tension pulley for 12 rib belt
  14. Do i need an FMU with a tune?
  15. A/w intercooler water pumps
  16. abs delete with procharger?
  17. Precision Turbos On Sale Again!!
  18. Anybody replace their Bypass Valve with a BOV ?
  19. Couple of Procharger ???'s
  20. Pump gas vs. Torco 114
  21. FMIC Vortech T-trim Camaro setup pics if curious..
  22. procharger plus meth
  23. Intake Temperatures
  24. How do I contact Lonnie Pavits???
  25. A short start up video
  26. STS Tubro Question...
  27. Is my d1sc broken?
  28. Will this EVO beat me??
  29. twin turbo....?
  30. ATI damper/ASP pulley
  31. Final T-Trim/FMIC pics....
  32. what supercharger is the best 4 95z28 !!!
  33. turbo question
  34. New Turbo Junkie, need help
  35. Injector headache
  36. Radiator relocate mod ?'s
  37. 7" vortech crank pulley
  38. boost went from 6 max to 3 1/2 max. What happened?
  39. Adding N20 to my boosted 355..how big of a shot?
  40. procharger piping
  41. Mid mount Twin Turbos.
  42. tuning stock ECM and boost
  43. Who is running a stock cranked stock rodded 355?
  44. Who's run a STS on a box stock LT1/6-spd??
  45. fuel presure regulator ?
  46. i don;t know much about v8's new to them
  47. Supercharged question...
  48. Okay, kind of a odd question about FI, but please step inside to add your 2 cents...
  49. Where's your guys fuel pressure at?
  50. Not making anywhere near the boost I should...ideas???
  51. Ported heads question
  52. Egr Tube
  53. Dual walbro setup
  54. lost boost after intercooler install?
  55. block for boost
  56. Turbo Coupler
  57. R.I.P D1SC.. 56k BEWARE
  58. turbo or supercharger???
  59. 383 help
  60. running maf on pressure side?
  61. BPV question
  62. supercharged
  63. My MAF DIED!
  64. supercharger
  65. plug gap from .38 to .30?
  66. Blown Cometic MLS head gasket
  67. PLugs for boost
  68. D1SC or F1A
  69. New Best!
  70. Blown SC motor - need rebuild advice! - 450hp target
  71. Banks Twin turbo
  72. Breather w/Built-In Air/Oil Separator (Crank Case Evac)
  73. Those who have moved radiator/fans forward
  74. How NOT to modify your turbo
  75. T-trim in the future? Your thoughts?
  76. Returnless fuel systems as opposed to retuned ones
  77. Placement for boost gauge fitting in intake.
  78. Carb'd LT1 Turbo system question
  79. Ponder this air intake idea for a moment...
  80. Intake manifold question.
  81. LT1 turbo setup
  82. twin turbo pics
  83. cam help 224/236-114
  84. TT or buttmount
  85. Drivability & big injectors (questions)
  86. P-1SC with Hotcam?
  87. whats a good turbo cam for my lt1
  88. Running VERY LEAN at part throttle...miss stumble
  89. need a little help on a DIY TT
  90. finally got the car out of the garage after 11 months!
  91. has anyone seen or got
  92. Intercooling
  93. Need help putting together a shortblock for boost...
  94. whats the difference?
  95. Airflow during datalogging with sc unit
  96. Speed density vs maf
  97. Supercharged SS...
  98. Throttle body size and FI cars
  99. where can i find turbo manifold for a lt1
  100. Where to get 10 rib Vortech pulley
  101. Help me out
  102. Just listed PROCHARGER set-up for sale
  103. two new bests
  104. fuel issue
  105. Which retard/ignition box for Boost?
  106. nitrous nozzle
  107. My turbo vs my supercharger. Two different feelings.
  108. Oil in intake tubing
  109. How much RWHP can my 2 bolt lt1 handle?
  110. Procharger MAF massager?
  111. what do you use for.....
  112. thinking about supercharging
  113. How adjust tension on sc?
  114. Powerdyne on a LS1 F-Body question
  115. gear ratio for boost
  116. Crank/blower pulley issue
  117. SDCE tensioner...replacement
  118. Supercharger for 1994 z28
  119. Anyone here of a electric supercharger?
  120. Radical boost spike 41psi!!!!
  121. A Few Questions
  122. Procharged LT1 383, what injectors?
  123. E85?
  124. Powerdyne LT1 pulleys: What's unique about them?
  125. Lookin for a pulley
  126. look what i get to play with....
  127. 500rwhp on 6.5psi... any good?
  128. Forged LT4 385 boost it?
  129. Anyone with ysi or cogs, please step in
  130. need some guesses...
  131. Are 55 # to much?
  132. Bypass valve vacuum line
  133. Boost seems like it takes to long to reach.
  134. Pump Location
  135. Clutch opinions....please feel free to post
  136. Thinking about a turbo kit again
  137. Where else can boost go?
  138. s/c lt1 guys i have some questions for you.
  139. Pulley change to lower boost in a P600B
  140. thinking about supercharging
  141. couple new bests and VID
  142. Need airflow for sc cars
  143. picking out a turbo
  144. F1a LT1 block grinding. Pic needed!
  145. Best Turbo Piston/ring combo for my setup?
  146. National LTx Shootout! KCIR- 4.19.2008!
  147. F1-A in a street car ?
  148. LT1's weakness..?
  149. problem building boost with powerdyne
  150. Single turbo exhaust parts.
  151. Went 8's today...video inside
  152. Need some help on a setup need advice and pics
  153. messed with shift points and got great results
  154. A few questions about FMIC
  155. Teaser vid of my turbo setup...
  156. I have a D1SC with 600 miles on it for sale
  157. F1A pricing
  158. Just got my F1A.....PICS!!
  159. Update on my turbo car's running progress
  160. IAT question
  161. Dyno place needed
  162. Powerdyne LS1 Tensioner Pulley?
  163. STS turbo spool noise...
  164. Supercharger question
  165. Procharger Rebuild
  166. Way to check the alignment of the blower/crank pully
  167. Centrifugal Showdown
  168. Spoke with STS on the phone today
  169. twin turbo or f2 procharger
  170. Looking for anybody running a F.A.S.T on a blown LT1
  171. PTK closed down???
  172. Gotta quick question about turbos on LT1
  173. BOV or BPV? Interesting webpage
  174. Procharger IC pics
  175. LS2 with Magna Charger
  176. A-1000 Fuel Pump Elec Wire Up????
  177. Twin-screw vs Centrifugal
  178. Why so harsh on the LT1?
  179. Question about emissions
  180. Pic of my Hot-parts...
  181. Cold Side-What bends/straights will I need?
  182. MAF location
  183. Fans and Intercoolers?
  184. procharger kit for sale
  185. blowing coupler off of throttle body!!! anyone got a surefire fix
  186. Daily Driver Rear Mount
  187. Gauging Interest: LT1 Turbo Kit
  188. crankcase ventilation help please!!!!!!!!!!!!!
  189. crankcase ventilation please help!
  190. Which parts are "stressed"?
  191. Best heads for 383 twin turbo
  192. Someone may need this
  193. INTMD8's LT-1 twin turbo system and Turbo/Blower long block FS
  194. Turbo Pistons from Eric at Victory arrive!
  195. Good IAT temps?
  196. Is it possable to run 1 ext. + 1 int. wastgates
  197. Slowly but surely.
  198. Got a LT1 Turbo cam you want to swap for a N/A cam?
  199. Spoiled ProCharger P-1SC Model Specification label
  200. Got my intercooler on!
  201. Powerdyne users might want to read. Replaced Filter?
  202. supercharger or prochager
  203. Just about done
  204. LE2 355 with a P1-SC procharger?
  205. Wondering
  206. super charge a stock motor?
  207. ? on differnt CI's for forced induction
  208. Timing on boosted LT1
  209. Has anyone seen these?
  210. Opinions please
  211. Map higher than baro air pressure?
  212. What ignition box to use with Procharger?
  213. Plug Gap And Plug Type For Turbo!!!!
  214. evacuation system
  215. What are you doing for Z28 FMIC airflow?
  216. Getting too old going to a smaller cam!
  217. Supercharged 383s
  218. m6 vs auto w boost
  219. Looking for head suggestions
  220. Cylinder heads for a blown 383
  221. magnacharger on formula
  222. Cartuning v6 Camaro Turbo
  223. Will this intercooler be too big to fit?
  224. couple questions about my build
  225. track results
  226. Supercharger advice wanted
  227. Which is better?
  228. Car as it makes boosts gets slower?
  229. Track results...stock heads/cam T76
  230. Got it running, but have a couple of questions
  231. Anybody with a Procharger/Vortech have any regrets?
  232. How much boost on LE2 kit? Stock internals.
  233. Supercharged LT1
  234. Idle messing with my head
  235. New results. questions on gearing and my mph
  236. Help with roots style sc on LT1
  237. STS Turbo Dealer In BC???
  238. rear mounted turbo question
  239. Help with LT1 Pistion selection....
  240. "Designed for Stock Engine" claims...are they true?
  241. 8-9psi with 10.2:1?
  242. (from VW to V8) need help/info about a paxton LT1
  243. s/c or turbo
  244. What Size Injectors / Washed Cylinders??
  245. Most Popular Radiator for Stand Up use?
  246. Waste gate on a Centrifugal Supercharger with adjustible boost...
  247. How long have you had your boost?
  248. wastegate/bov help
  249. FI Specific trans question
  250. -4AN stainless steel braided the same as SS Hydraulic hose?
