Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33
  1. New FMIC Pictures
  2. Boost w/ cam... Q
  3. How is this cam
  4. Have le1 heads + cam, want 450 rwhp
  5. Is this a good deal for a YS trim Vortech?
  6. Sound clips of Vortech race bypass valve??
  7. Third gen procharger fuel help
  8. Fel-Pro 1074's good enough for my application?
  9. Pro Charger P-1SC or D1 for my application ??
  10. quiet bov or bypass valves
  11. Do I want SP or should I keep the MAF?
  12. Need measurements from 95 crank hub to machine ATI damper
  13. How much u willing to pay for 1200hp turbo kit? Maybe for sale
  14. Looking down the road
  15. Heads, Pulley, Aftercooler, Head Unit?? Which option?
  16. Hub centric spacer needed?
  17. Turbo cam
  18. Win some cash!
  19. powerdyne supercharger pulley needed
  20. need help with blow by issues..383 BAND AIDS?
  21. Anybody use a Trickflow Elbow?
  22. Timing at wot..table is set at 20...datamaster shows 24...
  23. What stock heads for blown 383 project?!
  24. LT1 castings.
  25. D1SC with stock bottom end.
  26. Whistling after Motor/pulley swap.
  27. need fast help crank snout
  28. Max Power w/ Stock Unported Heads?
  29. Upgrading Ati by pass valve?
  30. forecedinductions.com wtf???
  31. what to expect RWHP??
  32. procharger systems(LT1)
  33. turbo vs. supercharger(LT1)
  34. basic FI questions
  35. Where to get P1SC pulleys?
  36. SDCE questions
  37. Vortech V-1 S trim vs ProCharger P1SC
  38. S-trim T-trim Noise
  39. lt1 tuning
  40. Putting my car on the Dyno this weekend...what will it make?
  41. Paging Roadie or 97WS6Pilot
  42. Ati procharger should i retain egr and emissions
  43. Running Rich & Crappy
  44. Oil leak/AFR Heads and LT4 Valve covers
  45. tensioner pulley size needed for powerdyne
  46. D1SC on 383LT1
  47. Twin Turbo Selection, Please Help!!!!
  48. Couple ?'s regarding vacuum lines & S-trim after AIR removal
  49. Pistons for boost, JE vs SRP
  50. F-Body turbo kit for sale
  51. DIY Turbo Kit Finished *PICS*
  52. What A/F Ratio should i tune the car for ON methanol.
  53. motor break in...
  54. Procharger crank spacer
  55. procharger pullies
  56. eboost users step inside.
  57. Just got on the dyno with my boosted 355
  58. My Powerdyne with 1LE sway bar?!?!?!
  59. Qtp 3" Elec Cut-out & Tube W/switch!!!!
  60. Guestimates on Power
  61. 10.8:1 CR + s-trim maxed out
  62. Bang for buck with boost?
  63. Where to go for forged bottom end?
  64. intake tube vortech
  65. procharger intake
  66. Well, my Z will soon be back out, and re-tuned on the dyno...
  67. What fuel pressure regulator are you using?
  68. Vortech Guys needs some help
  69. Post your front mount pics, WITH BUMPER INSTALLED
  70. roller rockers???
  71. How important is DCR
  72. Dynamic Compression Ratio for Boost
  73. Cutting the honeycomb for an intercooler...
  74. Track Boosting Problems
  75. STS turbo
  76. front mounted turbo/supercharger
  77. I Just Finished On the Dyno, Need Help!!
  78. "beginning to consider" questions
  79. Free Shipping On Precision Turbos...
  80. Max HP on optispark (OEM, MSD or other)
  81. What kind of numbers?? Maxing out stock injectors using FMU
  82. when should you o-ring your block
  83. where can i get a t-trim rebuilt or find a reasonable t or ysi for sale?
  84. difference between Vortech's YSi-trim (V7 vs V24)
  85. FMIC or stay w/ Aftercooler
  86. 87 octane in a blower car??
  87. T5?
  88. will 1/4 mile times drop a lot with boost?
  89. quick ?
  90. Increase 1LB of Boost = ?RWHP
  91. Can stock lifters handle boost and higher spring rates?
  92. Piston, ring and bearing info please...
  93. meth injection
  94. air to water questions
  95. Where should I buy my new ATI system from for a 06 Vette?
  96. ls1 turbo kit
  97. Consensus on MSD 50# injectors??
  98. Z28 LT1 Turbo set up question
  99. Tell me your thoughts!
  100. Post your turbo set up
  101. boosted Summit Federal Mogul rebuild kit...
  102. Supercharger questions
  103. My Turbo LT1 Set-up Pics
  104. P600b
  105. air to water or methanol
  106. Blower Cam selection
  107. Which Electronic Boost controler?
  108. Need help picking a spark plug for my AFR 180 heads...
  109. Ported manifold on ati p600b with 12 psi?
  110. what spark plug for 9psi supercharged LT1?
  111. Question: stock vs ported/aftermarket heads
  112. Gates Belt Part number needed for D1
  113. Help me build a boosted 408...
  114. A couple supercharger questions...
  115. Stock Motor=Worth It?
  116. Another blower on stock engine thread...
  117. Do it your self Water/Meth. inj. info wanted
  118. Two pistons broke on supercharged '96 SS. Why?
  119. Vortech owners
  120. Need 2 Pick A Cam Need Help!!!!!
  121. Water/methanol users....
  122. When to activate closed loop?
  123. ATI just spun off my keyed balancer..help!!
  124. On a hot day, what temps are you guys seeing?
  125. Need some detailed
  126. FI O2 sensor failure.
  127. Dyno'd the Z today...
  128. What's a BRAND NEW D-1SC head unit worth??
  129. Cam selection, need help!
  130. Anyone running ysi on t-trim kit bracketry only...no BB hub?
  131. Low boost with T-trim, any ideas?
  132. Can somebody answer this question about a vortech crank pulley?
  133. Cometic Lt1 Mls Head Gaskets .51 Thick????
  134. Head Studs A Couple ??????????????
  135. Unable to track down odd noise from SC drive?
  136. O2's & Ext Wastegate Placement Where?????
  137. Oliver ultralight billet rods?
  138. Methanol injection users, need your assistance...
  139. Bov Mounting!!!!
  140. Cam suggestions for maxed out D1SC
  141. Timing, how much is everyone running?
  142. Finally! 1 yr later. She's alive!
  143. STS turbo kits are they good?
  144. Threw a blower belt today, anyone know how install a new one with a SDCE tensioner?
  145. Running Rich, MAF, Intake Leak, maybe just burn it!!
  146. Thinking about selling my setup..
  147. Method of Pulleying Blower for Boost
  148. ATI Procharger cooling fan??
  149. BLMs stuck at 128/128 in closed loop, no correction!
  150. New guy, w/pics
  151. Need a good TUNER Recommendation in my area...
  152. Car running HOT with A/C on
  153. bypass to blow off valve
  154. Boost Controller Problem
  155. Looking for a YSi head unit cheap as possible!
  156. anyone have photos of a procharger installed on just the engine?
  157. By Baby don't like the heat..
  158. Vortech Head units???
  159. Need info on the Vortech V1 supercharger
  160. Setup Dilema...your thoughts???
  161. Anyone have instructions for ls1 procharger
  162. Finally got my car to the track for the first time with the supercharger and slicks..
  163. Anyone tried this???
  164. Supercharging a OBD1 Speed Density car...
  165. Relocating MAF question(s)
  166. How well will a fresh LT1 hold boost?
  167. need help with single turbo LT1
  168. Dual INLINE walbro pumps
  169. Need help from Machinist on the board for ATI hub
  170. AEM injector driver EST Grounded code?
  171. iroc w/procharger help
  172. ATI Pulley Size
  173. Front mount intercooler with a camaro bumper...
  174. More questions regarding Crankcase pressure?
  175. Vortech V1 no boost
  176. FI camshaft
  177. 383 short block
  178. p1sc vs. d1sc, streetability and a/c
  179. Big filter guys...quick question
  180. My blow through 86 Z28
  181. Vortech rebuild
  182. Need to know of some good vendors
  183. turbo pipe fab?
  184. Turbo oil return lines
  185. Minimum mods to supercharge???
  186. Supercharged LT1 vs APS TT C5
  187. edelbrock LT1 RPM airgap intake...?
  188. Engine is toast
  189. T88 turbo kit
  190. Its running again!
  191. It's almost done!
  192. Turbo install *nightmare* PTK / PTS LT1 front mount
  193. Do I Need Cut Outs?
  194. how much RWHP to go mid/hi 8s...
  195. F1A In The Mail
  196. Will my methanol injection clean like seafoam?
  197. Msd 6btm
  198. Ported Intake on FI LT1
  199. Another F1-A has arrived
  200. boost a pump for a dd?
  201. boost gauge mech or electric?
  202. ATI questions...
  203. Gear choice with turbo?
  204. Need opinions on fans for 95 formula lt1
  205. ATI Twin Intercooler Setup
  206. electronic boost controller
  207. BOV Recirculation causing MAF probs
  208. fuel system question for 383/Ai TFS/F1A
  209. Any roots style blowers in the works?
  210. I'm really digging my alkycontrol
  211. Turbos for LT1
  212. Overspinning the blower, how much is too much?
  213. Water/Meth Injection Nozzle Placement Question???
  214. What makes COGs UN-Streetable?
  215. Neep part number for Powerdyne large idler
  216. Boost on a stock bottom end with alcohol/water injection worth it?
  217. 97 Vortech install problem - Please help!
  218. 383 s/c
  219. Supercharger IAC reading?
  220. Lets Look at BLOWER CAMS Guru's
  221. Needed:
  222. WB users I have a question
  223. Spark plugs
  224. Whats up with SD-Concepts?
  225. what are you boosted guys running for exhaust?
  226. Finally
  227. Anyone interested in an Aftercooled Vortech Kit for LT1s?
  228. Another Turbo Cam Question.
  229. Need Belt Size for Vortech
  230. 383 SC issue
  231. Another one going turbo
  232. do I have a blown head gasket
  233. Help me pick a supercharger kit?
  234. Stockers to Pusher electric fans
  235. Vortec issues....solve this mystery!
  236. How do you tell a T-Trim from and S-Trim?
  237. What kind of average milieage are you guys seeing in your FI F-bodies?
  238. Mufflex intake pipe and twin highflows
  239. its official, I'm joining the ranks of the boosted
  240. Anyone using LT4 head gaskets?
  241. Spark Plug Question
  242. Meth/Water Injection or Intercooler ???
  243. boost and a 50 shot?
  244. intercooler on a 69 camaro?
  245. Need some thoughts out turbos and piping
  246. What is stock pulley size for P1SC?
  247. adventuring in turbos.
  248. Is it safe to boost...
  249. centrifugal vs. roots
  250. Ross Pistons
