- What would a cam like this peak out around?
- So who makes complete turbo systems for LS1 F-body cars?
- Would forced induction systems fit LS2 F-body cars fine?
- alcohol injected
- alcohol injected
- fmic
- Some Head Flow Numbers
- Lowering CR without changing pistons?
- intercooler ?
- How much boost will this combo make? Horsepower?
- Why it's WATER injection
- What is water/methanol injection?
- Need help with Twin Turbo setup
- Need help on LT1 twin turbo setup
- Acura's new Variable Flow Turbo
- Just for fun YSI
- Turbo Expectation????????
- Lookin for Vortech Impeller
- How many psi?
- What to expect?
- Front mount intercooler on LT1 Z28-dimensions?
- LS1 Powerdyne belt size
- supercharging lt1
- S/C Compatibility with SS Hood?
- Some Questions on turbos
- sound clip
- Engine rebuild- Need high output and longevity
- 224 236 114 lsa...looking for vid or sound clip
- Is this a good turbo cam for my set-up.
- runner size?
- What plug gap for forced induction?
- isses with a blower on 90+k mile 6.0l
- What gears do i need ? for 1/4
- sts turbo worth it?
- LT1 turbo kit options? opinions?
- Boost only 1/2 the time?????
- Injector Impedance Converter FS
- 2 bar map sensor questions to help better my tune on my D1SC...
- Tuning LT1 for Supercharger.. which way is best?
- RK sport blowers?
- Collector size and super chargers
- Bunch of questions for my PTK/T70 setup
- FMIC pipes... sizes?
- Conventional vs. Rear mount Turbo...
- 446rwhp - A-trim: What would YOU do next???
- Twin Turbo TPI...Liquid Air IC...pics
- how much boost?
- ProCharger belt/pulley matrix for LS1 and LT1 F-bodys!
- Blower tune help please!!
- Comp XE high lift ques.
- Help!!..sts Turbo...to Buy Or Not To Buy??
- off the wall question about turbos
- Bypass Valve for ATI D-1SC
- Rod diffences?
- what other mods to run turbo on lt1
- 355 guys...What kind of power are you making?
- Cometic head gaskets and FI engine?
- Where can I buy methanol?
- thanks
- Est. my PSI and power...
- ATI ProCharger Price Increase Feb 1st!
- i want to build an 800 horsepower smallblock
- supercharged lt1
- Those with maxed out MAF's in their forced induction LT1 car, advise needed...
- Best plugs with Blowers?
- Best ignition to use for LT1 turbo with stock PCM?
- supercharge, or cam?
- Safe amount of boost?
- Hidden FMIC! 24x12x4" core! Detailed how-to!
- ok...twin turbo or blower
- Goin Turbo.. Got ?'s
- Anyone running dual BPV's?
- Delteq & TRC-1 or TRC-2
- D1SC owners, what piping did you use from the blower to the elbow??
- what piston is this? Large images.
- ati procharger FMU
- Supercharger installed. Whats next?
- My dyno fun today.....
- 420sbc and P600B
- 1000rwhp
- p600 for lt1
- prochareger
- Possible SSAutochrome Spinoff?
- Where do I start to go forced induction???
- Oil leak after supercharger install
- What size piping and WG/BOV
- How many of you guys here with forced induction applications are also running N20?
- What size springs
- Figured out why I don't want STS
- Good of the shelf blower cams
- Just got home from the dyno
- Sell it with or without SC?
- Lt1 Intake manifold
- What blower would be more effective for this application?...must read question first.
- Supercharger vs twin turbos LT1
- Turbo ????
- Exhaust restrictor help
- whew, what a relief!!
- Vortech Strim Question
- Just spun my keyed balancer
- My new stuff is in!
- T04B vs TO4E...whats the diff???
- Worth it to upgrade from P1SC to D1SC?
- valve springs to use with TFS heads and 10psi from turbo?
- Compression for 20 psi
- 4.25" P1SC pulley #
- crank case venting...
- LT4 KM reading False Knock w/ blower?
- STS kit
- Advice on kit on ebay
- this engine good to 10-12 psi?
- How much boost with forged pistons and 11:1 compression?
- map sensor question
- header pics from TT and single turbo lt1 setups
- What do I need to know about changing out my crank pulley for my D1SC??
- Blower cam selection (stock motor)
- Little help please...
- Slipping belt? Symptoms listed below...
- Idle and rev clip of Vortech and CC306
- Sts 4.8
- boost & hold up question
- My New Custom Comp Cam
- Need pictures of camaros with FMIC
- Anybody ever try a......
- powerdyne crank pulley
- guage?????
- T Trim Pulley Combos
- WHat do the turbo guru's think of this?
- Looking for Used Vortech Intercooler - 95 T/A
- How many of you guys have a laptop ready to scan your FI car?
- Vortech race series Bypass valve adjustment?
- Which Meth kit to get?
- Procharger P/S Pump Re-location Kit
- Question about different metals
- Another minor setback
- Solid or Hydrualic Turbo Setup
- 177 weiand
- About to install a Powerdyne - a few questions
- Twin Turbo LT1...This anyone on here?
- S trim pulley question
- LT1 STS turbo kit with Kooks long tubes
- Problem with A&A supercharge kit surge/stumble
- 4.5psi reliability
- What size parts
- Turbo Info Needed
- FMIC on Trans AM's??
- Some pics of some turbo LT1 hotparts
- Tubing source needed
- Good Place To Buy Turbos
- ATI crank pulley on a Vortec kit????
- Check out my new supercharger!
- LT1 Timing with Boost
- MAF High Fail Limit on 96/97
- 8-Rib: 10% belt slip rule of thumb??
- Turbo Headers
- Taika Turbo setup on Ebay?
- XBM Turbos?
- Anyone know of XBM turbos?
- T6 turbos....
- Were is the NOOB section!? looking for some input
- ATI P600B w/twins for sale
- Safe for a few passes?
- Mufflex intake tubing for d1sc
- Low RPM issues
- Video of my car at Idle
- Low vacuum at idle
- Forced Induction Timing Tables
- Question on s-trim pulleys..
- Whats the best way to tune the part throtle
- Blower Belt.... 42inchs 12 rib
- Not one of Prochargers better days.
- Video of my sleeper (its alive)
- Aluminum 3.5" J Bends. Where to buy?
- Who to build my 383?
- Boost increase...share your opinion
- diesel turbo
- Ebay rear mount turbo guide.
- Best DD Blower motor stroke?
- Chain Driven Blower?????
- LT1 blower cam 224/236/114Lsa??
- Issues with SDCE idler pully
- ignition box
- P1SC going in- Fuel pump ques...
- Supercharger noob.
- Check out this ebay true turbo kit!
- TT 67 Camaro build
- Breaking in engine with boost?
- garret a/r 70 turbo
- Problem only at ~3800RPM???
- general timing question
- Help me build a turbo system.
- stock internals vs. boost
- New Procharger F1A just installed and tuned!!
- methanol injection
- help with turbo LT1 suggestions
- Need instructions for installing keyway on stock crank hub
- Motor oil question for you boosted guys...
- How's these specs for a turbo cam??
- I've got my Procharger P1SC for sale on Ebay!
- Why do stock bottom ends do better on n20 than boost?
- Anyone doing their own front mount?
- Which Supercharger??
- Improving vortech oil feed line?
- Lt1 blower pistons.
- kind of plugs in turbo lt1
- Difference about engine being built for a supercharger vs Turbocharger?
- turbo 355 bottom end
- Looking for a TT kit... Silverado
- Pulley replacement - P1SC
- sandblasting pulleys
- ASP 7" Vortech crank pulley and balancer for sale
- Anyone Run Boost Without MSD?
- ANyone got pics of Vortech on LT1 with Front Mount Intercooler?
- How turbo charger works
- Help With STS Turbo
- 2 questions:2 Step on Boosted LT1 / Bottom End Setup
- turbo sizing
- Help, blower belt off alignment 1/32in. OK Or NOt
- Question about boost gain from pulley change...
- Would like advice on supercharging my car...
- LS1 supercharger
- tangential vs. on-center
- stainless steel or coated or..
- 95 M6 LT1 T/A with Vortech V1 charger- clackin/rattling noise from charger unit???
- pics of my setup...
- questions about stuff?
- what kind of gains would I get from 7psi?
- New sponsor
- Loss of brake force with FI
- Good for a turbo cam -specs inside??
- Ohio Forced Induction
- heads/cam/supercharger
- Bro's Project Pics.
- What are you FI guys running for timing chains?
- STS Rear Turbo Questions
- Introduction and my plan
- Changing plug wires with Vortech Supercharger?
- Anybody got pics of Alkycontrol Installation?
- Vortech SC for LT1
- Going pig rich at 2500, need help
- bearing-flange turbo questions (LT1)
- gagues and sensors
- Vortech upgrade/exchange program??
- Goin FMIC on a T/A, couple questions
- Can a stock lt1 handle 9psi of boost
- suggestions on what # injector??
- MSD boost-a-pump?
- set up ??
- 224/224 .532/.532 112LSA good for turbo?
- CC306 w/ v2 Vortech?
