- not junkyard turbo, but not 1000hp either
- Anyone looking for some Vortech LT1 blower brackets?
- 72# injectors and OBD1 PCM for sale
- Best emmissions legal blower cam?
- Brand *NEW* 50lb fuel injectors $400 obo shipped
- Losing fuel pressure
- What is the best supercharger?
- For Sale: LT1 Vortech T-Trim Kit and Aftercooler Kit, All New in Box
- routing your pcv
- High RPM sputter with procharger
- Lunati Pro-Mods or ...
- PLease help with ATI tenioner issues and belt issues! Need information
- 52cc Heads + S/C=??
- LT1 ATI Twin Intercooler Limit
- 97 z with procharger, acts like timing is retarded
- Forced Induction.com??? Warning!!!
- Need help finding a dyno tuner for my supercharged LT1, please help!
- GMR Twin Turbo or STS rear mount?
- What does it take to upgrade my 95Z to a 2 bar map sensor?
- Finished pics of LT1 turbo hotparts
- Garrett Twin T3 turbochargers
- Need help with set-up to reach 550/650 with STS
- fitting question
- Who sells low compression short blocks ready to go?
- Safe Effective Compression Ratio
- Anyone need a 2 bar map sensor?
- BG King Sumo pumps?
- P600b ?
- New 383 Vids
- My Dual Walbro pics...
- Inlet elbow
- How to figure boost from hup and blower pully size? Whats your psi and belt size?
- Mileage on Vortec Superchargers???
- Autometer Wide Band A/F meter....
- Boost on New Motor?
- STS soon need opinions
- Stock MAF sh*ts the bed after procharger install
- Cometics leaking, couple of questions
- Anyplace where i can buy Vortech SC parts ????
- ATI damper and crank hub
- Building an LT1 for boost?
- How much is my cam hurting me???
- 355 LT1 Turbo initial dyno numbers
- Idle questions on new 383 and more boost,cam surge or misfire?
- Are D1 and P1 s/c pulleys interchangeable
- supercharger help please
- Best rings for 15-20 psi
- 111 deg LSA cam and blower ?
- Finally got my car back. Is it normal to be running a little warmer?
- front mount intercooler routing...
- water tank dimensions???
- problem after fmic
- Large (FMIC) ###
- Over sping A Vortech Blower ??
- Boost and cranksase ventilation.
- Dyno results are in for my car. D1SC owners, MUST READ!!!
- Fmic Pix....
- F1 blower Guys
- best way to remove blower pulley while on bench?? Help
- What's missing? Vortech V-9
- D1SC and ATI Harm. Balancer
- WOT...Scanmaster shows 7 degrees of retard...
- disc, f1, or best vortech s/c
- Cooling setup for blower applications.
- "reclocking" a Vortech
- Just the right turbo?
- Hello all...'87 Turbo Buick owner here
- best fi set up for me
- MAF Translator Pro
- carb, TBI, or MPI
- Rear Mount Setup Less Than Impressive
- TTI LT1 single turbo kit..anyone with info inside please
- Any source for big block turbo manifolds?
- turbosynergy
- Whats any one's opinion on the GMR Twin Turbo setup for LS1 Camaros?
- Hats off
- who sells check valves?
- Proflow ?
- blower and exaust turbo
- Rookie Here
- Which turbo is better?
- Comparing Setups
- Valve cover idea
- Forced Induction spark plug options
- 224/236 low lift or high lift?
- Who rebuilds superchargers?
- budget rebuild....forged pistons and rods enough?
- Need help with this 3.8L supercharger kit asap I plan on buying it tonight.
- What to do After some Boost
- 95 Vortech S-trim on a 93?
- Fuel system questions
- So...I think I f'd my second shortblock in 3months...
- Silverado twin turbo package???
- Ok turbo project under way..what do I need and what can I sell
- boost and map sensor
- Need a 2-step
- Ross vs. JE/SRP pistons for FI
- High Octane
- Headers and Exhuast on rear mount turbo?
- alcohol injection helpful on low boost
- What # injectors do I need?
- need help !!!!!! Maxing out MAf
- Powerdyne blower with SS hood?
- FI and torque converter stall spped...
- Real Dyno numbers for LT1's?
- What plugs do you guys reccomend w/STS
- another rear mount on the market
- Intercooler for a twin-turbo LT1?
- Procharger making some power
- help
- Picture of my FMIC for 97 TA
- vaccum line questions
- keep blowing off piping...any tricks
- Need to find a good inlet tube for my D1SC...
- Powerdyne on 93' Z
- to much boost? head gaskets went..
- Fuel for turbo..420lph in-line with 255lph?
- PICS of Broken Ringlands Inside...
- Air filter for ATI - K+N part #
- Fi + Dod?
- Thinkin about 98+ front end swap(more air for intercooler)
- witch one
- T76 or bigger?
- Ever have a Autometer/or any FP gauge up and die?
- turbonator?
- Just a general Turbo question with 93 octane
- Turbo build! I'm I headed in the right direction?
- Pistions and heads need replaced
- Roots Blowers?
- Has any one had a Valentine one go crazy with their Forced Induction car?
- Budget rebuild with boost..
- what should i do
- Misfire and too cooled of a plug ??
- 9# Pulley For Powerdyne
- STS turbo question...
- 2 bar MAP program
- which charger
- What CC pistons/headgasket to use with LE2 heads/turbo?
- Powerdyne and belt slippage
- which intercooler to get ?
- water injection or intercooler?
- have a few questions about P-1SC on LT1
- Questions on new Setup?
- alternator relocation w/vortech s/c???
- Best Pistons Available for FI?
- Bigger then a T76
- protoype 4" elbow
- blow by.. rear seal reverse instal.. anyone?
- Vortech V-1 R-trim questions...will it fit/bolt up?
- new track results
- Finally Dyno #'s inside
- radiator catch can
- Anyone running Wiseco pistons?
- CALL911 blower car down again ...
- Best place to buy Vortech Supercharger?
- fuel pumps ... what are you using?
- what should I do for a cam? t76-10/14psi
- ATI Super Dampers ...
- Which 76GTS for a PTK kit???
- Superchargers and Turbos Available At TBYRNE Motorsports!
- New project.... should be interesting twin turbo...Z
- D1 oil return.
- Should I buy QTP long tube headers if i will be getting a turbo system?
- new F.I?
- How long did your stock bottem last on Forced Induction?
- Anyone have any pics of Mondo Install?
- Paxton mounting bracket for LT1
- My experience with ProTurbo.
- tuning with ls1edit help?
- Anyone with T-rex pump that comes with vortech kit....quick question
- My front mount
- more picture requested... head unit to FMIC
- Procharger oil leak
- Will a Tial 38mm WG be big enough for a T76 with 10psi
- Where did you guys buy your ProCharger / Price?
- Lifting heads or blown gasket???
- Off the shelf pistons....
- Video of my Car (LT1, 383, D1SC) on the Dyno...
- Questions about turbos?
- will the turbosmart ultragate 38mm fit on ptk?
- GM (vs) Felpro 1074 (vs) Cometic head gaskets
- What Kind Of Couplings Are You Using On Your Blower?
- What would make more power and throtte response?
- Where you able to drive home once your stock bottom end let go with FI?
- Blower Motors Finished (PICS)
- Vac lines-inlet question ( bare w/ the dummy)
- How much power is too much for the street.
- Powerdyne Photos
- What do you think about this LT1 turbo cam.
- GBA turbo timer???
- setup guidance needed
- 94 Z28 turbo
- whattya think of this idea
- head and boost...is it worth it?!
- BigStuff3 still in business?
- Question on a cam motion cam! need help!
- Should I get methanol imjection?
- A Litle Info Needed On Turbos And Superchargers
- Vortech rebuild
- Dual Intercooled Procharged 8psi Reliability?
- Paxton rebuild .
- Ntercooler???
- P600b that new and been sitting for 5 years
- F-Body water/air intercooler for sale
- 6 intercooled psi how much hp????
- F1 blower or NX with D1sc for Trans am
- Crankcase evac. What did you guys do?
- Piecing together a kit.
- 52mm or 58mm on my setup? What do you guys think?
- innovative T-76 with a .81 A/R?????
- Car won't start after Powerdyne install
- Cast aluminum 180 degree elbow for LT F-Body?
- Ok so How about this turbo cam?
- is this a good turbo headgasket?-cometic
- FMIC with fan???
- sts turbo dual exhaust
- Max boost with a s-trim
- Rear mount turbo
- 93-97 firebird nose for FMIC...
- Turbo Technology
- ECU control with FI....
- alky/meth vs intercooler
- First rearmount turbo in the 7's
- Single or Twin Turbo?
- LT1 D1SC Help!
- Twin Guys in here please...
- How much fuel pressure
- procharger plus nitrous
- why retain heat
- Powerdyne's Website
- question about wastegate/boost (for my buddy)
- Which is a better cam for my STS??
- MAX power from a D1
- OK..i ordered this cam...
- Blower piston part number?
- Horsepower TV Installing A C6 STS Kit This Weekend!
- Do you think this cam is hurting my power for my Blown LT1?
- $2400 For used P600B ???
- using 93-97 impact beam on 98+conversion with IC
- Vortech FMU Question
- looking for boost options
- Crane HI-6TRC boost retard ignition
- Turbo Charging 95z28 Camaro
- Looking for opinoins on this
- for those with custom turbo kits
- How low PSI can you pulley an D1SC down too?
- Would 30SVO's with FMU work?
- Turbo Hotside
- HUGE STS Turbo Sale + $400. In FREE Upgrades!
