- Catastrophic Opti failure...pics
- Throwing boost on a stock bottom end..
- 80lbs+ injectors
- gains?
- lets build something to kill the z06, viper, shelby, & most anything else!
- Versafueler?
- Trick Flow heads
- tire choice and gear
- NGK iridium plugs are fine for a supercharger right?
- where to get procharger pulleys
- LE1/2 + Supercharger?
- Vortech Aftercooler Opinions
- how much power with a powerdyne???
- FMIC placement in a 96 T/A
- stock crank+boost+rpm=?
- Supercharger and Flows
- High Boost - Forged rods/pistons only
- ATI race BPV or Super Mondo BPV? Which 1 and why?
- new ignition setup and intercooler
- Turbo Exhaust Set-up?
- Partially filled block with Boost?
- Y2k turbo
- sts kit on ebay
- What happens if...?
- Something wicked coming!
- it happened
- dummy turbo???
- Question about building Twin Turbo'ed LT4
- Twin Turbo'ed LT4 Tuning Question
- water pump flow rating?
- 383 Builders, I need Feedback Please....
- Supercharge
- Mahle pistons?
- Wastegate Sizing???
- which supercharger for my car
- Vortech blower, same on LT1 and LS1???
- Building a 355 for Boost?
- questions bout my greddy BOV
- Coating ROSS Blower/Turbo pistons
- question about mains in LT1
- procharger
- ATI Procharger
- home made rear mount turbo kit
- Is 10:1 Compression Lt1 To High To Run Supercharger??
- Head Studs
- Water or Air
- Hi RPM Idle after Boost Application
- Ltx + Sts
- Turbonator
- Monoblade guys
- Blower Advise Please
- JE pistons/rods and turbo for sale
- Procharger D1 Bracket with both Pulleys and Tensioner For Sale
- K&n Cai
- Supercharger vs. Turbo psi
- New ATI 4.5" twin intercoolers
- choosing injectors, suggestions?
- F.I. compression ratio issue
- SN 93 for $100
- ATI compressor maps?
- Compression ratio on blown Big Block Chevy
- T3 turbine housing A/R question
- SN93 power
- 228/232 cam
- Inercooler/methanol injection
- Downside to cog setup???
- 94z a4 rebuild time.....
- I might be joining you guys next season!!!
- look here..
- Quadrajet and blow-through blower
- Lt1 S-trim Guys
- Procharger pulley problems
- vortech vs. procharger
- 908rwhp 908rwtq Speed Inc. single turbo LS1
- Stock heads for turbo?
- Intercooler mounting
- Anyone using ZEX Spark Plugs?
- What boost is needed for 500hp?
- I just bought a 00' Z28, now I'm considering a Cold Air Intake. Suggestions anyone?
- Any air to water cooler guys
- help me select a cam.
- Forged pistons and Forged rods + 12psi of boost
- Turbo i recently got
- Couple of Turbo Questions
- Who really know about wastegates?
- sooo close, twin turbo buildup
- Anyone else have their intake elbow blow off?
- Incon Twin Turbo Kit for sale
- p600b procharger, injector size, spark plugs..
- Is this for real??
- Pistons 2618 vs 4032
- Supercharged 350 to supercharged 383 boost ??? please...
- Who has removed a supercharger?
- A few sts questions
- Any LT1 owners need headers for DI turbo kit?
- Anyone relocate their battery?
- guaging interest ATI P1sc stage 2 kit *NEW*
- Choosing between the F1, F1R, and F2
- want 2 twin turbo lt1
- What distributor to run with FAST on a BBC?
- Header coatings?
- Turbocharing/SC'ing a LT1
- Turbo Lt1
- Merry Chistmas Turbo Question
- Upgrading ATI pulleys/boost...
- Best place to look for buying FI
- Bov Placement...
- D1SC/Engine Trouble Need massive help
- Idles about 2K when moving??
- Sacramento Turbo Tuner???
- Inter cooler tubing
- Long term effects of 8-9 pounds of boost....
- Does a supercharger damage a throttle-body?
- Turbo Newb ?'s
- Newbie to supercharging needs some pointers
- Need advice on my clearances
- New Garrett gt42. Turbosmart Progate
- Vortech & Procharger pulleys
- Turbonator?
- latest dyno results
- Supercharger vs Engine Question
- 994rwhp 863rwtq LS1
- powerdyne or vortech s/c
- GMR speed TT ls1 kit pics
- Dynoed, now have a fuel issue
- looking for used s/c (ATI, vortech)
- Procharger instalation instructions?
- LT1 Fuel System Question
- Vortech aftermarket suppliers???
- Questions about tuning speed density for boost.
- Ati Procharger 2 Core I/C Install...Pics
- Advantage to long tubes with turbos
- Smoke under boost
- FS FAST/SpeedPro ECU
- will this work?
- Spark Plug Recommendations for AFR 195's
- Running Rough
- 94 Z Time For Rebuild And Supercharger ???help People..
- air discharge
- What Air/Fuel Ratio for Supercharged LT1
- cam questions? with boost
- 630 RWHP fuel pump suggestions
- T rex pump
- Looking for markinkc69z
- used s/c
- P600B Install Instructions and Parts List
- I need a list of parts to supercharge my '87 firebird
- Single belt?
- Looking for S-trim plastic blower output to intake tube... Anyone?
- Turbo setup
- Supercharger/Tranny issues
- If anyone is looking for a supercharger
- Powerdyne Owners Within...
- 99 camaro ss
- Which one of you guys is familiar with FI & Alcohol?
- New 42# injectors for sale $300+shipping
- which igniting for p600B
- experienced/educated members of board please lend some intellect. p600b
- Work in progress...long... 56K users beware!
- 6-71/8-71 Supercharger
- powerdyne set up ????????????'s
- tune/fuel delivery for p600b.
- anybody useing a filtermag magnet ???
- LS6 and Super charger.WOW
- Need a complete motor with blower?
- Injector size help
- Road Course Racing with a SC
- stock z wtih sc/pc
- HiTech Dyno just north of Minneapolis. Anygood?
- FMIC - Yes or No?
- Rear Mount Turbo?
- No Slip Procharger Pulley Setup. ASP COG Drive Setup. Fixed Belt Problem
- Max out your 6 Rib Pulley Setup. Procharger 2.5" 6 Rib Pulley
- ProCharger P-1SC-1 install
- Vortech with Crank Trigger ???
- Does this calculation sound about right?
- methanol injection or intercooler
- Procharger In 2000 Ss
- Turbo Street cam choice
- blown 383 cost
- Heads Up. Procharger COG Drive Setup. 6 Hours left..
- A few questions about supercharging
- super chargers
- turbo set up?
- Intercooler mount pics
- Serious question about STS Turbo.
- 75lbs inj 4Sale
- FMU stuck- rebuilt...Question!
- guaging interest ATI P1sc stage 2 kit *NEW* with PICS
- Ignition for high boost
- anyone with a paxton balldrive intested in...?
- FS Twin Turbo headers for LT1 or SBC--CHEAP
- procharger
- I need 30 lb injectors and im a cheap bastard
- head gaskets
- P-1SC vs. D-1SC
- turbo kit design...
- Need input: CR for nitrous & 6 psi
- New cam and heads for S/c or nos
- Where to spray N2O into turbo/intercooled engine?
- Turbo Header question.......
- Custom/modified fuel rails?
- LT1 supercharer questions....
- Problems with headers on STS Turbo setup
- Problem with procharger pulley
- Looking to trade. 2600$ wedding ring set for p600b or V-1 S-trim
- NEED your opinion
- some help
- turbo and tuning...
- d1sc 383 12lbs of boost =....
- Cost of a Supercharger? What goes with it?
- How Much is Too Much HP?
- intake tube
- pro charger
- turbo and rear gears
- Building 69 Small Block to Include STS Turbo (8# boost)
- twin turbo complete kit for sale, CHEAP
- 3bar MAP over 15psi?
- Need Advice on Combination
- D1SC Oil Change
- Vortech & intercooler & pipe size
- Just got a Weiand 142 supercharger, HELP!!!---
- opti spark vacuum lines/pcv, valve cover lines
- what kind of power are you guys making with 76mm turbo
- 94 V6
- lt1 turbo tuning problem?
- Does boost change the basics, like head flow?
- Installing a turbo timer. Need some help with finding the ignition harness.
- Cooler Piping
- aeromotive fuel press. regulator users inside please...
- Injectors?
- supercharger questions
- 4 bolt splayed caps on rebuild
- PTK + Twin IC Pressure Drop?
- Please Help! i need help tonight/noww, installing pulley
- mass air flow
- stock or ported intake manifold(LT1)
- Noob question
- Parts List for fmic
- What turbo kit would you buy?
- water injection
- alcohol injection setting
- Manifold Selection
- Tuning question?
- What gears should i go with
- stock turbocharger
- mass air flow
- Over heating with FMIC
