- Anyone Have A Lt1 Edit File For 12psi Vortech W/50lb Inj.
- Best Cam For My Combo???
- TB bypass in SC application
- Holley Stealth Ram MPI
- Start of twin turbo project
- which supercharger comp. cam works best for mainly street, some strip
- Where can i get Internal Powerdyne Parts, namely the Input Shaft??
- Valve cover removable with procharger installed??
- Turbo Sizing
- Ever wonder how a 91mm would fit in a 94 Camaro ? Pics inside.
- Turbo Questions! ?
- This is ProCharger stuff does not make any sense.
- Wastegates - Tial or Turbonetics?
- 4L80 Trans
- What kind of price($$$) for a 383 stroker built for a lot of boost(SC) on an LT1?
- Link to FS powerdyne 7" crank pulley ($155 shipped)
- EGR Block off neccessary w/boost?
- Started Updating webpage
- Vortech crank Pulley?
- Turbocharged/Supercharged L98 Corvettes?
- prochargerpower.com new website
- pro turbo kits.. thumbs up!
- supercharger for 81 z28
- ?turbos (kind of tech) ?
- Vortech YS-trim ???
- WTB: 6LB Procharger pullies
- boost gage
- Blower Cam to pass emissions
- Help on putting crankshaft hub and Hooker LT on
- Overspinning a BD-11A
- bigger boost with bypass valve
- turbo kits????
- Help on LS1 Twin Turbo
- Is Axis Industries no more?
- 355 vs 383 for turbo application
- Anybody knows a good sport at Vortech to talk to ??
- T-trim head unit worth ???
- what sounds better, turbo or supercharger
- To All members!! Need help concerning GWP!
- Polished Vortech Kit on Ebay!
- 450rwhp '90 C4 - what would you do to for the fuel system?
- will a procharger for a rausch mustang fit on a lt1?
- help on installing Hooker LT's
- Ati boost pump relay, gone bad?
- YS Trim information...
- Anyone one here running 8.5 to 1 compression
- fuel pressure
- Supercharger prices that will blow you away!
- Powerdyne ??Help !!!!!
- Not Street Legal (POWERDYNE)
- inter cooler upgrades
- Turbo gaskets?
- IAT Temps
- Ready in two weeks!
- Turbo guys - Heat Management Products
- 20-25#'s or up boost ???
- engine block O-ring ???
- 383 Cam Question
- ATI 8 rib P600B 8# blower belt
- Who makes the best intake gaskets for LT4 heads?
- 396 D1 17PSI A few questions on fuel details inside
- supercharger/turbo ductwork suppliers?
- How much timing are you guys running and how to retard it?
- Powerdyne 4.5 going to 6 question
- Sequential Turbos
- Need to know if this Toulene is pure ASAP please
- question about converting a NA car to turbo...
- Fact fuel pump w/boost pump, replacing fact with?
- turbocharging vs supercharging
- Stock bottom end supercharging Qs
- turbo/super
- intercooler sizing question
- New Best : 5.98 @ 116+ Mph
- Where to get the best price for a D1 for lt1
- fuel pressure regs for high boost applications
- Anyone put in a turbo timer?
- Nitrous problem. Won't rev over 5100rpm???
- GN motor swap starting to shape up...
- Turbo M6 boys - which gears ya running?
- Air flow ?
- Procharger oil change in FOUR HOURS!
- "Which is better?" question.
- How to remove ASR
- Head Gasket Sealing
- quick question for powerdyne guys
- Turbo Headers/Manifolds?
- Paxton Supercharger Questions
- I only get knock retard when I shift hard or punch it suddenly...
- Hey Jordon, How much longer till that beast hits the street?
- Fmu ?????
- Anyone run cogs?
- HP predictions?
- ATI #7 kit what injectors are u guys using?
- TurboCharger Idea
- It's Home!!!!
- Do I Need The Bypass Valve
- T-04 Turbo suitable for single turbo setup?
- CO2 injection
- Grand Prix GTP supercharger
- looking for roots blower on third gen??
- SBC superchargers
- Questions about tuning ATI
- IAT temps NONE intercooled.. please post up
- Where to get vortech aftercooler cheap?
- Turbo Q's
- LS1: twin turbo vs. blower vs. stroker
- new intercooler on its way :-)
- sub 0* water air intercooler coolant
- My V-1 S-trim is a bit noisy... not the whine...
- Is a 218/234 on 112 lsa a decent blower cam?
- Blower vs. Turbo, High vs. Low pressure.
- all people with the twin intercooler ATI
- 60-1 hi fi kit
- do i want one heat reange colder plug with turbo?
- F*ing Crank Hub
- LT1 Whipplecharger Kit from Hesco?
- Difference between Vortech S trim and T trim?
- Inj rails support ? HP
- Exhaust sound for a 383 w/ a Vortech...
- 355 buildup turbo project...questions
- Turbo pics!
- Aftercooler worth it with Vortech?
- Spark Plugs with P-1SC
- Has anyone run a supercharged on alchohol motor with brodix -12s?
- Using stainless Weld-els for turbo header fabrication
- Fuel system
- New turbo kit is out.....
- not that simple, but someone should know
- FAST tuning questions
- Alky Injection??
- turbo prices
- Maxed Out MAF???
- Boost/vacuum readings?
- 39lb/hr SVO Injectors $199 (8)
- Dyno #'s with ATI F1 and Turbo 400
- Turbo or S/C?
- Has anyone changed the location of there Twin Intercoolers
- Kenne Bell Boost a pump and fuel system ?'s...where at? How much? etc.
- explain a reverse rotation blower
- Who has made a Vortech power pipe (solid intake tube) with PVC tubing???
- 1 or 2 intercoolers
- 2 bar map sensor and maf limitation??
- What? F3R is CHAIN Driven?
- Can Toluene and Marvel Mystery Oil cause white smoke from exhaust?
- Lt1 Scanmaster code ?
- Vortech Supercharger Drive Pulley, 2.95", 8-Rib, Fits 1993-97 GM LT1 5.7 F-Body
- primary tube size ???
- Those with Ultra lite or Carbon fiber gages, please help me decide.
- In the middle of Hooker LT install, Need help
- Installing a Powerdyne... a couple of quick questions.
- Stock balancer how good
- Procharger COG Setup
- How Do I Know if my bypass valve is working?
- Procharger crank pulley question
- Having temp probs...
- ATI question
- I just flashed a new prog with burst retard programmed out...
- Anyone Measure Power Gains with Vortech Aftercooler?
- Yet another question on my Powerdyne install...
- Spark Plug Gap with P1-SC
- Forged pistons
- s-trim guys inside please!
- Supercharger tuning
- stumbling in the upper r's
- ATI or Vortech. Please Help me Decide
- Turbo Tune in greensboro Nc??
- Too late to super charge?
- What is the Inlet size for a D-1SC
- Turbo Request Today
- Only seeing 4lbs of boost??
- advance or retard (cam install for turbo)
- Powerdyne BOOST Level ?
- Will the 355 get me there?
- Dyno Techs or Thermo Inclined People IN HERE PLZ
- How much boost on a stock engine...safely!!
- Spark Retard without increase in Knock Count?
- Well, it lives, kinda!
- Ignition Help on LT1 v/Vortech
- Procharger Intercooled Supecharger (Experiences)
- ATI fuel system questions.......
- FAST tuning help!
- supercharger on a stock engine????
- Just purchased D1, have timing question and pulley Q?
- water pump replacement
- Cost of twin turbo
- headers glowing
- Twin turbo update
- Tons of questions :)
- Is there something like too much boost???
- George Baxter's badass blown '97 SS Camaro?
- ATI or 383/427
- Woooohoooo!!!!!!!
- New Vortech and ATI prices for April!
- Acceleronics and 72#/hr are great!
- '04 Lightning intercooling System
- Spark plug brand and gap size with Supercharger and MSD????
- Looking for a head unit
- Ready to install billet hub, but it wont clear
- Building a RACE only Forced Ind. Motor
- Where to get tuning in the south?
- 840hp/770tq
- Superfueler Users
- Can stock bottom end handle this.....
- cut out area between foglights?
- Garrett t04 turbo
- Blower Belt for sale
- autometer fp guage?
- What is your MPG on the highway with 50# Injectors?
- Moving the MAF sensor with an ATI kit? (intake or pressure side?)
- Lt1 Supercharger For $200.00-read This!!
- Best Compression Ratio????
- Help me choose a blower cam and parts...
- Supercharger & Nitrous
- whats the biggest cam that can pass smog
- T-trim vs. S-trim
- How is everyones car coming along this season??
- Selecting a Blower Cam
- What to expect from combo
- how much boost from this setup?
- turbo
- Roots Blower + Nitrous?
- Can anyone here help me get in touch with Shalin Patel?
- Any BOV recommendations?
- New best Powerdyne ET despite horrible traction
- Do you need to add extra oil every change if you are tapping the oil pan???
- Single turbo system progress (pics)
- WTF sucking 255 dry at 5000rpm..I thought this would be good for 500rwhp. Options
- ls1 procharger on an lt1?
- 3/8" vortech mounting plate?
- Any videos-ATI S/C in an LT1?
- Twin turbo picts
- 5.3L supercharger
- 3.8L turbo
- TS04's, 60-1's, 62-1's??
- Roots SC on LT1
- Going to lose cats/will it change fuel del. lean?
- Install Problem
- Removing ASR
- Injectors and HP
- Anyone ever use this intake on thier ATI or Vortec blowers?
- LT1 Turbo Kits???
- Ls1+ati 8#
- BOV valve? Anything special needed or will antyhing work?
- MAF or Speed density for 4.5PSI powerdyne kit
- q. on preping car for sc.
- How do I SUPERCHARGE?
- Help ! LEAN !
- New Lt1 Turbo Kit...
- Supercharging LT1. What all is required?
