Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Who here has ordered a ptk kit?
  2. Wide Band Commander any good?
  3. F/S Custom blower cam
  4. pulley combo
  5. What Gears To Get??????
  6. Bran New CUstom set of ROSS FI pistons For Sale *pics*
  7. FS PTK gen2 turbo kit LT1
  8. Those who have used superchargers and nitrous, which did you prefer and why?
  9. What fuse to use on inline fuel pump and MSD6BTM?
  10. My PTK T88 SS
  11. Can too much timing retard case misfires?
  12. Vortech Trex Pump
  13. supercharger question!!
  14. Used Turbo Source?
  15. Question about t-rex pump for vortech and meth/alky
  16. 97 WS6 Trans Am 3 Core Intercooler Location?
  17. Vortech Sucks!!!!!
  18. Pt88 Lt$
  19. Lt1 STS owners a couple of questions for buddy.
  20. Turbo Questions
  21. Powerdyne question
  22. How much boost with aftercooler
  23. 94 lt1 vortech T-trim oil pan fitting
  24. Maxing out Maf sensor
  25. Supercharger Computer Tuning
  26. STS block tapping....
  27. more pics of the buildup
  28. Running rough...FMU went bad?
  29. Looking for companies that offer front mount turbo kits for LT1
  30. Rebuilding engine for the future
  31. Fastener and injector question.
  32. Looking for a new Forced Induction moderator or two...interested?
  33. Open the combustion chamber?
  34. Boy, did I pick the wrong turbo cam
  35. Relocating the waterpump?
  36. Blown dual intank fuel pump folks..........
  37. Programming out hesitation on tip-in? (big injectors)
  38. Head flow #'s for boss' 67 camaro 383 T74
  39. Could this 90* hold up "suck side"
  40. Piston Rings For Fi??
  41. Cprrect me if i'm wrong on this compression ratio calculation
  42. LT1 Vortech guys inside Please
  43. Those with Mallory's hyfire VI map sensor inside please
  44. green air filter?
  45. Piston Rings For Turbo
  46. where can i find....
  47. wanting to trade nice fast seadoo for sc. kit for lt1
  48. Choking Off the Power
  49. car bogging in mid range
  50. FS: Vortec S Trim SC Kit-LT1
  51. More TQ. w/ 598 cu in & 6 Lbs or a 509 & 8 Lbs???
  52. Exhaust questions
  53. Turbo for LT1
  54. STS Turbo in rear?
  55. T- trim w/ Aftercooler for sale..
  56. Supercharger/Motor Suggestions
  57. New price for t-trim with everything that you could buy for a supercharger
  58. Best pistons,cam for a turbo application
  59. Help on selecting a ATI Pro Charger.
  60. Supercharged 383 Stroker
  61. Looking for Lonie Pavte?
  62. SS progress pics
  63. STS Turbo
  64. Mounting the Crane Hi-6
  65. Remote Turbo Setup?
  66. ic core's...
  67. Keyed hub and balancer question
  68. Check this out
  69. procharger question
  70. Is this a good turbo cam
  71. Turbo LT1 - Check it out
  72. kb-121 hypers
  73. A/F Ratio vs. Boost
  74. Any tips on oil changes?
  75. Lt1 roots supercharger
  76. Convince me to go fi
  77. another procharger question
  78. I just received my custom cam from More Performance
  79. 8 rib blower belt
  80. D-1 and coil location.
  81. will alky injection prolong cast pistons life?
  82. Cons to using methanol
  83. New best
  84. T70 O trim way too small???
  85. Ok whos using a D1-R on a LT1?
  86. Small nitrous shot or alky/meth injection
  87. 8 lb's with meth. injection
  88. new times, hot cam procharged
  89. Anybody rebuild their own supercharger?
  90. Coolant temperature for blown motor?
  91. Going Batty with DCR
  92. Bad Oil Leak In Turbo...... Help!
  93. Well I decided to Sell the D1 Kit i have so if anyone intrested...
  94. with turbo....
  95. Dissappointed in Aftercooler during Summer months
  96. Could use some advice (exhaust)
  97. how hard would it be?
  98. Bosch BPV question after MAF relocation.
  99. In & out fitting, Vortech ques?
  100. Turbo people - what kind/size wastegates & blow off valves are you usin?
  101. how much boost
  102. 03 cobra versus LS1 single turbo!
  103. bosch #42 injector part #???
  104. Blow Off Valve for procharger on 95 z28
  105. New 383 wanting to S/C
  106. procharger
  107. more pics of the buildup ...dual walbro pump pics
  108. where to get a alky kit ??
  109. boost guage operation ?
  110. Breaking in motor with D1SC
  111. fluid dampener, spacer for pulley
  112. Lt1 supercher?
  113. Can anyone identify these intercoolers?
  114. Proof STS and rear mounted turbos work
  115. FMIC on LT1 TA
  116. Blown Blower questions
  117. thinking of superchargeing t a
  118. Idea?
  119. ATI bypass valve (vent to atmosphere only) questions/info
  120. Direct Driven Supercharger?
  121. Those who liked this turbo system...
  122. Proper Bypass Valve operation.
  123. Quick question(not very technical)
  124. Lets talk FI tuning: Speed density for LT1
  125. running a MAF under pressure
  126. mixing and matching Vortech to ATI ???
  127. Turbo folks, explain me this ....
  128. Single Turbo Setup Question
  129. Desperately seeking TUNE for a 383 Vortech Supercharged Motor
  130. Need help with damper problem.
  131. twin turbo
  132. Z28 DIY Turbo Build - Pics
  133. Supercharger or Turbo
  134. Want to supercharge but....
  135. Looking for supercharger asap
  136. Guess on how much HP this combo would make?
  137. Injector/ fuel delivery requirements
  138. ls1 sts on lt1 Z
  139. From Eaton M-112 to Twin T3/T4 turbos
  140. Any thoughts on this?
  141. The right supercharger
  142. Fuel question
  143. Timing question..
  144. Monitoring for Knock
  145. joined the FI group
  146. Has Anybody used a MSD crank Trigger with a Procharger?
  147. I got this idea for a turbo with longtubes...
  148. fuel system for STS
  149. Is this a decent blower cam for a 355?
  150. Water Injection Questions???
  151. Informative Turbo website
  152. Procharger P-1Sc install ?s
  153. Turbo Engine Buildup
  154. FMIC now or later
  155. finding aluminum or S.S. intercooler elbows and pipe???
  156. Holley Stealth Ram IM
  157. Concerned about cam bearing wear (pics inside)
  158. lowering compression
  159. More new pics of twin turbo buildup, getting close!!
  160. Severe Backfire due to Methanol???
  161. Question for Rich Krause.
  162. Smoke when boosting?????????
  163. ATI radiator fan spacers?
  164. FMIC install on lt1 Z
  165. Dyno results ! Now what ?
  166. Possibly adding an S-Trim - pan tap question
  167. Limit of Alcohol Injection's ability to control detonation
  168. cutout with a sts turbo kit??
  169. STS Turbos will be 50 state legal!
  170. which type of forced induction??
  171. TURBO INSTALLED!!!!! V6 is ready.......
  172. Just broke in new motor and have some ?s
  173. Guide to FI shortblock buildup - shortblock questions
  174. fuel question for turbo
  175. Pump gas runs
  176. pic of a turbo installed
  177. Turbo question
  178. Looking for pics
  179. Anybody running a High Compression Forged LT1 Supercharged setup ?
  180. Any vids or sound clips of a Vortech S or SQ S trim?
  181. Opinions on PTK turbo kit
  182. Question About BOV FOR turbo systems
  183. Will a Supercharger blow off valve be heard with...
  184. 5psi, fmic, what upgrades
  185. Stock 48MM TB vs. BBK 52mm TB
  186. Timing Curve Characteristics w/ Turbo Engine?
  187. head gaskets
  188. Cam
  189. what size is the oil feed plug on lt1 blocks?
  190. Changing direction in F.I. Cam/ heads upgrade (request advice)
  191. fmu
  192. how much more daily driver friendly is boost over n/a?
  193. Anyone using a 1LE elbow on a s/c setup
  194. Stenod Performance Twin Turbo Formula Videos!!
  195. 1985 Camaro z28 supercharger/turbocharger HELP!
  196. S Trim Guys
  197. Which crank for blower?
  198. turbo project(finialy got started)
  199. Supercharger information sites?
  200. Fmu Kit
  201. 87'CAMARO Vortech Supercharger
  202. torque converter for twin turbo
  203. When i floor it, it stumbles!!!
  204. help needed
  205. SUPER fitting
  206. How much boost do you typically loose....
  207. Would someone make a guess how much boost...
  208. Turbo questions
  209. Another question.
  210. stock turbos that could fit a 97Z28?
  211. fuel pump ?
  212. I've decided to go with this cam...what do ya'll think.Particularly Rich
  213. A Vette, but TURBO..... :D New Pics
  214. When does the SC actually start too make decent boost ?
  215. need help
  216. Got a couple of questions......
  217. 224/236 low lift on a 112 vs 114
  218. injectors
  219. Good for a laugh! 65 mustang TT project.
  220. Why does idles hunt from 500 to 1200?
  221. does anyone use the turbanator?
  222. Turbonetics vs. Garrett T-Series
  223. Stock Pulley
  224. Which keyed hub for Eagle crank?
  225. changed direction(goin stealth)
  226. Cog Drive with fluidamper?
  227. aeromotive question
  228. LS1 ATI Procharger Kit for Sale!!!
  229. Water-to-Air aftercooler. Thoughts for vortech guys.
  230. Can I hang around here?
  231. How much boost can a -34cc piston take??
  232. Smog Help
  233. 500rwhp what would it take?
  234. new to Forced induction... got some questions?
  235. Head Gasket help?
  236. Timing help
  237. Injector Size?? Need Help
  238. What valve springs do I need?
  239. how much can a 4 bolt block take?
  240. Need advice...want a turbo setup
  241. vortech and intercooler
  242. Kenne Bell Twin Screw LS1 supercharger
  243. Will 987 springs handle this cam?
  244. What compression ratio do you want with forced induction?
  245. twinturbo lt1 solidroller
  246. Lopey idle on a turbo car...is it feasible?
  247. Interesting day on the dyno and alcohol injection
  248. Best Springs?
  249. anyone ever hear about a rootstype supercharger for lt1
  250. Need turbo LT1 pics
