Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. procharger install tips
  2. STS System Incomplete???
  3. 3.8 turbo kit
  4. a1000 pump questions?? doesnt add up
  5. p600b p1sc questions
  6. Anyone running a XE 224/236 cam in CA?
  7. sts kit on stock lt1 engine with hot cam -- HELP
  8. Should I procharge or Head/Cam
  9. in need of a stock 10 bolt rear end
  10. Engine Managment System?
  11. forced industion on carbed?
  12. detonation issues with procharger
  13. Which cam?
  14. External oiler for P600 B ?
  15. All members who drivin or has a sts turbo kit on there late model
  16. STS VS. Supercharger.........???
  17. more single turbo C4 vette progress..
  18. power steering and alternator relocation without using stock acc. bracket???
  19. sc/turbo/hc at the same hp level how do they feel??
  20. Quick question about fuel upgrade on sts kit
  21. Stock 10 bolt survives another pounding! New best as well!
  22. Purchasing procharger pulleys
  23. people that had/have blowers on stock bottom ends
  24. my price estimate/plan on bottem end
  25. What you guys think about this kit?
  26. Elbows on Ebay
  27. blower question
  28. intercooler for sale!!
  29. Anyone heard of, or used these?
  30. What header gaskets for FI?
  31. What head bolts with 12-15#
  32. diffuser in TB elbow, any difference?
  33. Scrap + wirewelder = aftercooler tank
  34. i still have pressure in the crankcase... cant figure it out
  35. 89 supra turbo on 94 z28?????
  36. Why do blowers tend to make so much less power than turbos
  37. Heads for 1000+ hp turbo
  38. WTF??? Disappointing track times.
  39. Made a few dyno pulls...
  40. ATI price increase coming soon!
  41. a1000 mounting...where is yours?
  42. Selling Vortech V2 kit w/Aftercooler for 1993-97 LT-1
  43. Turbo C4 Vette progress 4-24-04
  44. LT1 World record Broken again
  45. what would my compression be?
  46. Track today
  47. how much boost with 9.2 to 1 compression?
  48. Oil return on PTK and Phamspeed kits
  49. Alky/Meth install pics
  50. Turbo W/AFR heads Plugs ?
  51. 90° Fitting obstruct nitrous flow?
  52. procharger F/S LT1 p600b
  53. Opinion on Hot parts turbo flange
  54. STS dyno sheets please
  55. ati or vortech
  56. Sts Turbo
  57. Aerospace V-style flanges and clamps?
  58. Ideal Piston reccomendations?
  59. Questions on running a dual walbro system
  60. A/F tuning
  61. Water Injection and Nitromethane
  62. One year left...
  63. Alright what does the STS turbo sound like like on a car?
  64. What does it take to run 10's
  65. msd 6 btm hook up
  66. i need help with intake gasket part #s for AFR 210s
  67. the suggestion from combination motorsports...
  68. i want a 800 rwhp turbo setup
  69. Possible sts kit for sale
  70. Turbo kit for v6 camaro
  71. After over 20k supercharged miles I did a compression test...
  72. What is a electric supercharger
  73. Finished aftercooler box
  74. Keep supercharger or go turbo?
  75. Turbo, Supercharger, Or Nitrous
  76. Detonation on 1 and 2 cylinders
  77. STS kit for sale
  78. Pictures of my twin turbo buildup
  79. For anyone with a supercharger setup
  80. LT1 ATI Cog Kit For Sale With Pics
  81. Limits of the Stock TB
  82. Traditional s/c cam's
  83. Roots blower help - All FI guys inside!
  84. Water injection tuning
  85. Procharger install help
  86. Whats legal in CA?
  87. Some Pic's of versafueler install & Alky install
  88. which way is better to lower compression?
  89. STS + ATI + Twin ICs = ???
  90. LT1 questions
  91. STS GTO at it again...
  92. Can the MSD Boost Timing master be used as ...
  93. STS Turbo on LT4 Conversion w/ Hotcam ??
  94. UPDATE Pic's
  95. p600b on the way out, anyone use f-1c or know where to get it?
  96. Rebuilding my engine. ? on CR without turbo...
  97. What plugs should I run?
  98. turbo oil line
  99. Tracks Results w/ STS Turbo Kit.
  100. 1 cat or 2
  101. Breathers or catch cans
  102. New best
  103. My preliminary head flow numbers (feedback requested)
  104. New to Forced Induction, got a few questions?
  105. Removing T-rex inline pump??
  106. LM-1: Digital Air/Fuel Ratio Meter ???
  107. Compressor overspeed???
  108. ati procharger stickers.?
  109. LE2 with an ati procharger??
  110. Bypass valve
  111. Opti install
  112. Planning a turbo stroker need help
  113. 355/~500hp=how much?
  114. Rear mount turbo dyno results are in
  115. How much boost 396 Powerdyne BD-11
  116. Is a 1.05 ex A/R ok for my setup??
  117. Building a stout shortblock???
  118. 69 camaro turbo setup pics!
  119. D-1 and D1SC pulley the same?
  120. Vortech Supercharger parts
  121. Vortech Supercharger parts
  122. How many miles/long have you had your FI on your LS1
  123. LT's with sts?
  124. What is that largest crank pulley
  125. spark plug gap
  126. T-Bolt clamps
  127. Pic Request
  128. Cam motion Blower Cam
  129. 355 or 383 for supercharger?
  130. New Times W/Turbo Setup
  131. Need some Help witht he Alky kit
  132. Greddy Profec B S2 Electronic Boost Control Settings...
  133. Anyone running A/C with their blown 383?
  134. P1sc or p600b or D-1
  135. pics of my fuel system in progress
  136. Mass air flow and superchargers.
  137. gen 1 blower on lt1
  138. No FMU???
  139. What does the PCV system do under boost?
  140. pics of a ATI pisc twin IC kit on a LT1 please
  141. install turbo for 2000 V6 camaro
  142. install turbo for 2000 V6 camaro
  143. valance air inlet
  144. How to tell if my supercharger is good
  145. Partial block fill?
  146. Blown .LT1_edit file.
  147. RPM limit of ATI P-600B
  148. **PICS** of PTK LT1 Gen2 Kit
  149. STS KIT-- How much rwhp should this combo make
  150. Couple questions.
  151. Problem with blower pulley
  152. Future boosted LT1 here!!!
  153. Will this work? 3.8 to 5.7?
  154. Need timing maps....
  155. power limit of an ported lt4 intake
  156. stock blower question-3.8 blower on 3.4 engine?
  157. First passes with the new 396, need some advice
  158. Horsepower estimate
  159. need help identifying a turbo STS KIT
  160. I need help choosing parts to finish my project. (also tunning for a 93)
  161. Need some HELP & IDEAS
  162. spark plugs
  163. Procharger Rebuild
  164. Stenod performance Twin 60 Build-up...UPDATE!!
  165. 383 or 355?
  166. Boosted stock motor check in
  167. Boost and Fuel Pressure guage install
  168. ATI superchargers on sale!
  169. Jl Turbo.com Recommended
  170. Compression Ratio Q's and a Couple others
  171. Procharger manual
  172. Radiator relocation for turbo car
  173. which is better for my 86 iroc with tpi
  174. Will I blow?
  175. powerdyne
  176. T-trim vs D1
  177. Fuel pressure
  178. Meth Injection w/ 2 core I/C
  179. Who says sts cars cant be quick???
  180. good experience with a powerdyne?
  181. Alkycontrol in, BUT need a new washer tank
  182. forced induction total packages?
  183. what for power are you's making with a 224/236
  184. Anyone need intercooler parts??
  185. LT1 Bumper cutout??
  186. Blow off valves
  187. How thick are Fel-pro 1074
  188. Does the Delteq deliver more spark than a Crane?
  189. car idling low at times, stalls with clutch in
  190. 52cc heads what should i do for shortblock
  191. Happy Memorial Day.
  192. Powerdyne question
  193. procharger head unit noise
  194. Backfire issue- what is it?
  195. Turbo cam question...
  196. In reality how much power can you make with APR head bolts before lifting heads?
  197. Update pix
  198. Hey guys; please defend our website against a few trolls!!!!!
  199. oil return/feed?
  200. Turbo buildup progress pics...
  201. Went to the dyno and got these results
  202. A-pillar removal
  203. Performance parts to pimp out ride?
  204. Cometic Gaskets
  205. Supercharger
  206. wow, I never knew blowers sucked so bad
  207. guaging interest:sts turbo set-up
  208. Header Flanges
  209. Thinking about selling the Bad Boy 398 LT1 ~ 1200+RWHP
  210. F1r
  211. Ebay t70 turbos?? Will it work for me?
  212. Anyone know what this turbo is to?
  213. powerdyne vs custom rear mounted turbo
  214. turbo's
  215. Different sts kit for 93?
  216. Bigger injectors -- reprogram my computer???
  217. procharger p600b
  218. digital 6 and S/C
  219. check this car out
  220. Anyone have/know where there is, a manual for a paxta-map???
  221. snapped an 8rib
  222. Anybody got a 7" crank pulley layiong around?
  223. how much fuel psi should i be running?
  224. Spark Plug Q
  225. is 37mm BOV adequate for T-Trim @ 16 PSI
  226. PTK= Excellent Customer Service
  227. Are stronger springs needed for running 20psi?
  228. sts vs. prochager
  229. T-70 Turbo Guys (or Girls)
  230. Vortech Mondo Bypass Valve
  231. Suggestions, ATI p1sc Must Have's
  232. Reading compressor maps???
  233. 4.17 Vs 4.25 puley D1SC
  234. spark plug gap & high rpm detanation?
  235. boost on an LT1
  236. Gas Mileage with Supercharger?
  237. Is MSD BTM still needed?
  238. I need a turbo Kit
  239. S/C Help!
  240. Does anyone know if a racetronix single hp system with...?
  241. Bypass valve before or after intercooler?
  242. Whats the max boost one should run with the vortech race bypass valve?
  243. Brad Brand intake pipe?
  244. Pro-M Maf
  245. Difference in size of housing with Diff A/R?
  246. Who all makes a complete LT1 turbo kit
  247. Homebrew Alky Injection Kit - Pics
  248. where to buy meth
  249. Vortech setup needs ideas
  250. procharger vs vortec
