- Final touches, almost DONE!
- What Blower for forged 383?
- Heads for LT1
- hotcam and turbo?
- Anyone thinking of making ?
- What did a 383 cost U guys$$$$$
- Little off topic but..
- turbo fitment
- stock bottom end, but hogged out heads?
- Who is upgradeing
- Help with intake ducting ideas...
- ordered a supercharger
- What will stock fuel lines/rails support
- stock bottom end? bad idea?
- Do you need to zero deck the block
- ATI superdamper big block hub vs regular
- Powerdyne BD550 Head Unit
- How much boost can a deltagate actually control?
- Front mounted intercooler
- Where to look for a good supercharger
- LT1 Blower Chambers
- How much to rebuild a turbo???
- is this to big for my motor setup?
- Need Vortech belt size please...
- Turbo photos
- Jet Stream™ Electric Supercharger
- Those with sheetmetal valvecovers and/or breather tanks, need pics of your PCV system
- Custom turbo headers
- Maf on Pressure side of Twin High Flow???
- p600b orange inlet tube
- How fast is you FI 355
- What motor for a Vortec SC?
- New Times for STS equipt Z71
- Question about Turbo Debate I had
- What are some of your mistakes
- Knowledgable blower Guys
- Will this digital wideband work with our FI cars...
- 2.055/1.625 valves in LT1 heads
- Compression ?
- running supercharger oil line?
- PTK Turbo
- Fuel injectors and stock pcm
- Please help me need advice on next summers build up budget
- Finished blower install, ran good till tranny let go
- What do I need done to handle 15 pounds of boost??
- Sts dyno numbers
- Timing
- 355 LT1, should I get the P1SC or D1SC
- Hard Intakes Vortech
- New to Forced Induction
- Best charger for my high mile stock LT1
- new to turbos
- new to fored induction
- Advice on a cheap budget 355 induction set-up
- Please Help. Advice on this set-up 355
- Some updated pics
- ITS GT80R turbo for sale
- Blown 93 Camaro FS......
- Procharger - just change the pistons??
- S-trim and p600b ?
- Cogged Vortech Guys, What Size Pulleys?
- Vacume line blew off the bypass valve.. bad?
- Looking for partner in US
- ASP pulley
- Will this set-up handle 12 pounds of boost yes or no???
- Boost????
- ATI new 8 rib setup results
- Vortech S-Trim, Methanol Injection
- Intercooler on a Trans Am?
- Wtb Blower
- source for single turbo headers?
- Blown Seal?
- How fast with the T56
- 54cc heads with a blower?
- PTK 76GTS track results
- 5 lbs of boost with 10.8 to 1 compression?
- 3'gen 3-core IC dimensions?
- Where to buy missing parts
- bolts on the crank pulley keep coming loose
- Turbo LS1 Dyno Results
- would this fit?
- For Sale Vortech YSI supercharger for LT1
- We're now carrying STS Turbos!
- Price of 355 LT1 = price of 348 LS1... switch platforms at rebuild time?
- what kind of 1\4 # for vortec
- What should I run in 1/4 with this set-up Predications anybody
- Is it possible to get over 600 rwhp on stock bottom end with this set-up??
- Tensioner problems with vortech V2
- Supercharger?
- Lowering the CR
- Where to get Mandrel Bends??
- stock oil pan
- fuel help
- 9.7 @149 6-speed LT1 video
- powerdyne 6#
- Opinions on these pistons/rods for turbo
- Re-Building LT1 7K Sound About Right?
- What to do?
- What kind of combo / horspower can I get with 7k budget??
- what would everybody recomend?
- Stock shortblock with P1Sc how much can it take
- help with guestimate.
- Intercooler Thought
- Help with some boost issues.. Pullied for 14 only seeing 10..
- turbo vs Supercharger in a 355LT1
- 1/2" head stud conversion?
- How do you drive?
- Please post pics of your fuel line routing
- Is this the fastest Lt1?
- Can you safely run an STS kit on a stock low miles LT1?
- Stone Mountain Racing Wastegates?
- Gauges with one ????
- SC tune?
- Double Roller timing chain and ati superdamper
- Pushing the limits, need advice.
- LS1 + YSi + Strut Bar Brace
- D1sc or F1 ?
- pb600 vs s-trim
- 396 stroker or 355 procharged??
- powerdyne thoughts
- Anyone need a small turbo??
- Downpipe Size and Max HP
- how much power can be made with stock heads
- ATI new 8 rib setup Final results
- 9.6 video
- Got boost? Video clip of the 'Bird.
- Turbochargers and heads
- what size injectors
- Video of me hazing the tires at highway speed
- A few questions about pullies and balancers.
- What is a 76mm Turbo head unit worth barly used
- Post pics of blow off valves..
- What kind of numbers can a blown stock bottom end LT1 put down?
- PTK Gen 2 Kit
- What mufflers you running and does your car pop on decel
- What name brand injectors are better for FI?
- Crazy idea, inter/after cooler?
- Daily Driver: Heads/Cam or STS Turbo ???
- Do I need better valvesprings?
- intercooler inlet/outlet
- Total TT setup
- Air fuel for boost and methanol?
- ATI Blower Pulleys
- Twin high flow intercooler worth the upgrade?
- WTB parts
- Which size turbo? Chevy Colorado I5
- tining issues blower vs turbo
- Took a ride in an STS car
- Turbo charger with hot cam
- Do I need a new tune after I drop a supercharger on?
- Whats the smallest 8 rib blower pulley you guys have used with no slip?
- Head gaskets
- My fuel system
- Does anyone have a 12# 8 rib Ati p600b pulley laying around?
- having a hard time deciding which blower cam
- Need Help Asap!!!!!!!
- 615 rwhp dyno vid
- More power TURBO OR SUPERCHARGER???
- Need Blower cam for 800 RWHP Combination
- Supercharged LT1's with a higher stall..question inside...
- A supercharged 350 or a naturally aspirated 415?
- Cant seem to find this belt.. 392K8. Where can I get one?
- Is a supercharger worth it w/my current mods??
- go with cometic or felpro 1074
- Turbocharger?? Need Help I'm lost
- STS Kit do you need a intercooler?
- best sounding blow off valve
- How do you take blower pulley bolt off?
- Need help identifing a turbo.
- How wide is a 12 rib setup?
- Power predictions
- Why are some supercharged cars so slow?
- Siemens Deka Injector size?
- racetronix fuel system question
- Compression/Boost limits on high octane?
- Stumped on Paxton disassembly
- several questions
- Should I sell my LT4 heads for TrickFlows
- Race Gate Springs
- Also in Parts For Sale....Procharger FMU ebay link...
- Can a stock short block take 500hp???
- People with ATI big block hub in here.........
- Blow off valve on supercharger?
- Supercharger or Turbo?
- driver not builder, needs thoughts/answers to ??'s
- Aftercooler replacement water pump?
- Got a question about which cam to use
- 12 rib better than 8
- How much boost on a stock motor????
- newb to superchargers
- whats the max timing i wanna have?
- Gauging interest Got some big injectors
- considering selling my old eaton stuff
- Can you use a wastegate as a BOV???
- Motor destroyed...
- HOW to INCREASE bOoSt
- Is a 48mm tb hurting me?
- Is a BOV open during cruising?
- FMU or Upgrade injectors????
- Keep my hotcam or buy a blower cam????
- Pro Series fuel pump
- STS Turbo Questions/Problems
- Got 6" rods in my car.. Should I have gone 5.7"?
- vortech v-trim ??
- a few questions
- Chain drive for vortechs?
- DIY Rear Mount Turbo - Need some input
- Maxing out MAF sensor
- Heads questions for the pro's
- sts turbo on a stock engine how long will - --
- can u do u both???
- T76 or T88 New set up please advise
- Can I run two 6rib belts on 12 rib setup. Belts driving me crazy again.
- would a t76 work with a T.technology single LT1 kit
- need some pro apinons
- Is there a blower cam out there thats??
- Can someone explain water/methanol injection?
- new Vortech on a 350 TPI
- Wastegate DUnp Question
- My car is GONE.............
- LT1 Paxton questions?????
- Stock Headgaskets with 6#'s of boost???
- Stock fuel pump flow #'s
- Paging Jose from Forced Inductions
- Whats the loudest supercharger they make?
- 1st Supercharger Install
- Fuel pump
- Vortech owners, whats the best method
- Making LT1 ECM "see" boost
- Given my MOds will my car handle a SC
- How much power can a stock engine take?
- What brand forged piston/ring for 12psi, compression?
- Project Turb Hoe
- Turbo Exhaust Gas Temperature
- STS turbos and ATI superchargers - we can help with both!
- Traction Concerns w/Future Setup
- Where to buy parts???
- Block fill, leave main caps on?
- What Size Intercooler to use for a Front Mount?
- Worth running low Z injectors?
- Vortech owners, quick smog pump relocate ?
- EGT Meter Vs Pyrometer
- Blower eng combo ??? HELP
- specs on cc306
- Piston in the hole
- Looking for 550rwhp/500rwtq
- procharged LT1
- supercharger on lightly moded LT1
- tool steel rings
- Oil Consumption
