Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Other questions....(STS related)
  2. What to expect, supercharged 355???
  3. 2 bar map sensor -will it work?
  4. Installing p600b need injector/spark plug advice...
  5. Will a f1 procharger fit a lt1 f-body?
  6. supercharger
  7. ATI twin intercoolers for LS1 fit LT1???
  8. question reguarding vacuum lines on a p600b
  9. Procharger H.O. Kit w/ P-1SC
  10. Procharger and Vortech's Discharge point the same way?
  11. air to liquid, aluminum cooling tank question
  12. ati procharger, 8 #'s good?
  13. Most accurate boost guage...?
  14. injector help please
  15. Question About 04 Cobra With The F1a Procharger
  16. Opinion: ATI Procharger on 96 LT1 with 100k
  17. Get away with 38lb injectors on 8# ATI no FMU?
  18. New Blower/N2O times from the Impala
  19. Homemade Turbos? Possible?
  20. Lets help me pick a cam!
  21. Fuel pump
  22. JL Turbo
  23. Just scored a T-trim aftercooled
  24. Opinion about my headers
  25. Fuel question
  26. Are the Intercoolers for procharger the same on lt1 and ls1??
  27. Vortech S trim on a stock LT1??
  28. Oil return, oil level sender hole
  29. What Do I Need To Run 8 Psi?
  30. Will this change help, hurt, or neither???
  31. who makes a good fuel pressure reg?
  32. procharger belt size
  33. Intercooler for Powerdyne Supercharger
  34. P600B pulley removal on car?
  35. blow off valve recirculate or atmos
  36. ati p1sc w/ twin intercooler
  37. Dyno'd my vortech yesterday
  38. the car has finally left the building heh
  39. time to change to a turbo cam... (which one)
  40. Importance of mandral bending in FI setup?
  41. procharger belt #
  42. Procharger setup with front mount
  43. How much do I have to do?
  44. as my Buttom end getting rebuild...i got a few questions
  45. 12second3rdgen
  46. Stock Engine W/ Turbo
  47. Anybody have the MAF after a front-mount?
  48. water pump for the vortech aftercooler ??
  49. Feelings on 304 vs. 321 stainless for headers
  50. boost question
  51. "Safe" to drive 200MI w/stock injectors & 8#Procharger?
  52. 93z chip tune before start up help help
  53. inter cooler for 5-psi vortech
  54. Ready for a blower!
  55. Fuel system and boost/methanol questions..
  56. Wich one is the better Supercharger: Vortech or Powerdyne?!?!?
  57. 396 stroker procharged??
  58. 3rd Gen's with Intercoolers
  59. Which is the better supercharger: Powerdyne or Vortech with intercooler
  60. What IATs are you guys seeing?
  61. Banks Twin Turbo Setup NOW for Sale
  62. 55lb injectors too much for my application?
  63. Need recomendations for Fuel Injection system
  64. Ideal budget bottom end.
  65. Blower belt and Smog test?
  66. oil leak
  67. Proper 8 rib belt for Procharger
  68. LT1 Turbo Kits?
  69. cylinder heads
  70. To o-ring or not?
  71. Driveability of 383 Blower Motor without a Blower?
  72. Installed Procharger supercharger belt/pulley squeek...driving me nuts!
  73. Paxton kit on an LT1?
  74. Spring loaded tensioner for ATI TPI-89
  75. Custom Supercharger??
  76. ???What would you rate this setup???
  77. Paxton supercharger kit on an LT1
  78. Question about 355 procharged??
  79. Paxton's NOVI-2000, good enough for 700rwhp?
  80. what type pf plugs for SC?
  81. Eaton M112 VS Vortech
  82. MSD 6BTM please help ...
  83. Cheapest FI stup?
  84. Need 7.0" crank Pulley
  85. i keep blowing oil from my breather...
  86. Cam for emissions
  87. Is 10mpg reasonable with D1sc after tune?
  88. what size injectors for a S Trim on a stock motor?
  89. Prices on Procharger Setups???
  90. Powerdyne Question
  91. what is everyone running and for how long
  92. Engine life on 8 lbs of boost.
  93. Best way to change pulley's
  94. ATI to turbo
  95. Anyone here have a lt1 blown or not 396 stroker??
  96. compression with a 383 and P1SC
  97. Injectors and spark plugs question ...
  98. Oil leak at P600b head unit from oil supply?
  99. those who made your own log style headers
  100. dsm bov
  101. What Timing controler should I use? Help!!!!
  102. Stock ATI BPV broke, what are my options for a replacement?
  103. Vortech photos
  104. Will a P600B work with this big stroker I have?
  105. Is more boost always better??
  106. feed line bolt in pan has a leak
  107. Modding the fuel rail
  108. Looking for BIG power from a 396. Here is what I have ... what do I do now?
  109. A Peak Inside The Engine Of The APE Shop Car
  110. blower installed need help
  111. Cam Choice for a Turbo LT1
  112. platinum plugs and procharger
  113. Vortech Oil feed
  114. ATI 4.1" Blower Pulley For Sale
  115. Holset turbo for my lt1
  116. FMU Questions
  117. LS1 Procharger Dyno Sheets.....I wanna see em
  118. ATI procharger 8rib 12 LB pulley for sale....p600b pulley
  119. P600b Just got ALOT louder whine?? What gives?
  120. ok... i have about had enough.. vortech people inside!!
  121. ATI procharger p600b FMU for sale...
  122. Can I drive the car w/scharger belt off?...ie natural aspiration
  123. Relatively stock LT1 w/superchargers.....post dyno #'s
  124. after blower install car sputters
  125. Anyone have bearing # for tensioner pulley on p600b setup?
  126. Need help identifying injector rating. Another ? also.
  127. Realistic expectations and suggestions?
  128. PCM Programing Questions
  129. Are my plugs to cold?
  130. Dyno results
  131. Blown 1996 355 Z for sale.
  132. What Cam!
  133. What should I build to put a 15 pd procharger on???
  134. any have extra..
  135. Whats the highest boost I can do a 355??
  136. More than 11psi with an S-trim?
  137. Anyone else carry the ASR relocation kit so I can put my t trim on?
  138. Considering Twin Turbo's
  139. how much hp with a stock lt1, low compression, forged internals and turbo?
  140. blower oil feed line
  141. supercharger inlet
  142. Procharger twin intercooler pics
  143. Need help with tune....injectors 99% duty Cycle....
  144. Going to be selling my twin turbo setup, can someone measure under there hood?
  145. cam question
  146. Powerdyne S/C
  147. Vortech T-Trim For Sale/Trade
  148. Are blowers that inefficent?
  149. ATI Procharger 12lb pulley 8rib For Sale..Ebay Link
  150. LS1 cam for sale
  151. Where to get belt for blower?
  152. Where can I buy Supercharger Pulley's?
  153. preference?
  154. check out this compressor map and tell me if it'll do
  155. Holset turbo question
  156. Need more fuel..read why.What pump do you guys recommend....
  157. Seriously considering either a supercharger or turbo. Need imput
  158. turbo mounting flexibility?
  159. Couple SC questions
  160. Turn up the boost???
  161. Tunning the computer on 95 z28
  162. Selling my Vortech S Trim
  163. T76
  164. plastic panel in front of radiator and condinser
  165. bought a T76 but exhaust side looks huge, can someone confirm?
  166. Silly Question
  167. Turbos & Surge Valves
  168. STS Turbo Results - 101 hp gain
  169. How do you afford these mods?
  170. need T88 help
  171. Front Mounted F2 On The APE Shop Car
  172. any body with a 93 camaro
  173. msd boost timing master/need help
  174. Building a 383 need help quick parts are in.
  175. T-trim versus T-76
  176. false knock???
  177. eh question on emissions
  178. Locked up Turbo...
  179. Winterizing a supercharged vehicle
  180. Octane boost Good or Bad
  181. Strange turbo...will it work well?
  182. Heads and FI
  183. Cometic .125 gaskets, 48# injectors enough?
  184. Turbine housing A/R ratio question
  185. My Imala did 632.7 rwhp 690.6rwtq :-)
  186. what turbos do you turbo guys run?
  187. sts it turbo?
  188. New set up, need help
  189. check this out
  190. UPDATE!! Fuel issue solved....dyno numbers @ 8psi
  191. Project Front Mount!
  192. Head porting...
  193. How can you tell A/R ratio
  194. Lower CR on stock bottom end (LT1)...
  195. Finally rebuilt!
  196. Proper oil to run with vehicle
  197. blow by question
  198. weight and stall speed with turbos
  199. So close yet so far away......
  200. ProCharger D1X ?
  201. Installing Aftercooler this weekend - got ?
  202. What would be a good blower for this setup???
  203. Whats the difference between Super T70 Turbo and Garrett T-70
  204. What brand STB with Aftercooler
  205. Felpro 9966 headgasket?
  206. power coolers?
  207. Getting Closer
  208. Do you guys think people would buy complete GT40,GT42, T70, T76 turbo kits for $4000?
  209. Selling D1SC setup and LTs for LT1
  210. How to measure blower pulley?
  211. How much RWHP to run 91mph
  212. Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
  213. Reichard Racing Ultra Grip pulleys
  214. put me over the 500rw mark
  215. Can I rebuild my supercharger?
  216. Approximate cost for just parts?
  217. Need help with building a boosted Little M engine
  218. Vortech How much boost?
  219. Sts Kit Questions????
  220. Where to buy rubber couplers?
  221. Question for turbo guys?
  222. Vortech Ultra-Grip Pulleys & Blower Overspeed
  223. Vortech aftercooler installed now ss hood won't close.
  224. ? about Procharger intercooler
  225. Carb enclosure?
  226. Easy Question about intercoolers..
  227. pump gas + boost, what is the max?
  228. thinking about going FI
  229. Garrett GT40 & GT42
  230. LT1 Turbo Headers Done!!! **PICS**
  231. Stock Hub double keyed.. will it hold? YSi-trim
  232. Eaton Root style Blower coming soon...
  233. OK guys, school me IAT, boost, O2
  234. would 30#ers be enough for this ...
  235. whats the best heads for a procharged 355
  236. Supercharger tuning questions please...
  237. Vortech loosing boost
  238. 166k miles on lt1 is Supercharging a bad idea
  239. fuel pump install???
  240. Checking Options on Forced Induction
  241. Eng combo & help with missing parts
  242. STS 1/8 mile times
  243. PTK LT1 results for those that were interested
  244. Overlap? Search didnt help...
  245. Went to Dyno today, # seem high for stock heads and cam
  246. 9.8 @ 149
  247. Experiment results with modified inlet pipe
  248. Turbo LT1
  249. Spark plug question
  250. would 150 shot be enough?
