- Boost Gauge Line
- electric driven superchargers????
- Anyone buy from superchargers4less
- Car was running, Boost/Vac was backwards, then car won't start. HELP!!!
- Turbo exhaust
- Understanding flow characteristics
- Does this look like a good twin turbo kit?
- Just orderd 15# pulley
- 1560hp LS1 w/ Turbo
- My alky injection
- turbocharger for 86 v6?
- twin turbo for 95 lt1 camaro
- Finaly
- anyone have a sound clip of a 214/224 114 or 224/236 114?
- supercharger tube question
- Another day at the track
- Vortech Supercharger on EBay
- Incrediable supercharger installation rates!
- True or false about a engine built for a Turbo
- twin turbo or supercharger
- supercharger witch one
- Paxton Full Of Water !!!!!!!
- Are stock cranks prone to fail in blown applications?ALSO need advise on cam, piston
- need help with my Lt1 D1 kit
- How do these dyno numbers look?
- Holy crap check out this wideband..
- P600B / Mac Headers/ FMIC: 4" SC Inlet Possible?
- P600B in stock LT1?
- twin intank fuel pump?
- What rods are you big HP guys going with?
- Need some pictures... of
- will a P600B work on an LS1
- How to remove pulley from an S-Trim?
- wanting to go with BOOST...
- Need 1 twin intercooler
- Magna Charger (LS1)
- Pressure drop across intercooler
- would it be ok to supercharge
- What brand evac pump are you turbo guys using?
- It actually runs!
- Raced at the track with the new T/C
- 355 or 383 for a FI setup?
- Full port AI + 8lb Procharger
- what must I do to my engine to handle a supercharger without rebuilding??
- Brad Brand intakes and others
- Cola crank/Edelbrock 18 degree heads
- where to get T-rex inline fuel pump?
- Blower guys... what cam are you running??
- Grand National Owners!
- LT1 head gaskets
- tuning a SC in '93
- Blow Off Valve Audio/Video Clips Wanted!
- Motor shuts off at 6000 rpm
- Callies 383 or Lunati 383
- Pistons for 355?
- Question for you Turbo guys
- I can't decide. Requesting opinions.
- PCM tune for Vortech SC
- Intercooler causing overheating?
- Vortech SC with HOTCam?
- Traction control relocation kit
- Possible scammer lurking
- Vortech T-Rex as Alcohol Injection pump
- Rich Krause
- plug changes
- supercharger for a 3.4l v6
- Which Injectors? and tune??
- New to supercharges
- Should I lock the converter under WOT?
- please help with my fuel problem.
- Got a few questions about the compression with a t trim.
- ATI P600B Parts List? Got a photographic memory?
- How much Rwhp does 8psi of boost give you
- Do i need a breakin period?
- Custom header builders inside--->
- Reputable ATI Procharger dealer
- Back at the track again :D:D:D
- Lets have a picture thread:)
- Something nasty this way comes.... :)
- Quick Question about Procharger + Stock LT1
- Put on P600B Have some ????'s
- where to start w/timing & A/F with SC??
- MAF messager?
- nitrous on turboed engine
- Junkyard twin turbo setup
- Anyone making good power through cats?
- How much will ati fuel pump and FMU will handle?
- LS1 SC questions
- Eaton question
- Any LT1's with a T-Trim and cogs?
- Few questions peicing together my motor. Part numbers and such..
- Where to buy 12rib 42/43inch belt
- Front mounted intercooler?
- Carb+blower+454
- D-1R Procharger For sale
- STS Mag Reviews
- Vortec S Trim blower inlet
- What Blower cam?-not LT1
- Tuning w/ Innovative wideband but w/out O2's
- turbo fuel system
- which pistons for SC motor?
- Fuel system
- Fuel Injectors...
- Target "Boosted" Compression
- Can I Change the pulley without taking the S/C Out?
- calculating heat...
- GM pm rods? or standard rods?
- Innovative wideband ???
- Plug choice
- new to me questions
- Question about force induction - Rebulding the engine NEED HELP?????
- Loudest supercharger?
- crank pulley problem with vortech.....
- Banks Turbo?
- ATI Procharger on L-98
- anyone fimilar with a 15psi ati procharger for lt1
- Vortech Bypass Valve questions
- 5.7 vortec supercharged? reliable
- a-trim any good
- What am I getting into....
- Should a superchager be safe on my engine rebuild???
- Turbo on stock motor?
- Where does feedlin go for boost gauge?
- Nitrous Bottle Placement
- Fuel system questions.
- belt size for vortech s-trim
- few newbie questions....
- 1st *LT1* ATI install,what else needed?
- supercharger mpg
- STS Turbo Kit
- need help with blower motor setup
- Gap at 15psi?
- Strength of rod bolts?
- Input on this 396/T88 Combo Please
- overheating fuel rails
- When is a crank to light for a supercharged application?
- best place to mount boost-a-pump
- Bad News
- all right mr. krause, how much boost for a beginner
- Aftermarket oil pan needed?
- Another Dyno Number question..
- who is using accel with there SC setup
- Question for those running PTE88 turbos...
- Turbo Fbody guys, stop in...
- Electric boost gauge reads boost at idle?
- vortech 5# charger first time blower /expert input needed
- 94 z28 - vortech oil feedline question
- popping from exhaust when boosting, what could it be?
- Help intercooler for a powerdyne
- STS turbo set up
- What does it take to run Turbo and Juiced?
- rskrause. I have a couple questions.
- Supercharging a 1999 Camaro Z28
- Superchager Question on ATI Prochargers
- LT1 Forcefedfab Kit
- Where can one buy a Vortech Aftercooler the cheapest?
- have some questions about turbo build up..
- Best Cam for D1-SC
- hard intake tube for an ati p600b
- Newbie Qs - New V-2SQ kit
- Spray Bars on your intercoolers
- Blow Off Valve VS Bypass Valve
- Good SC Cam???
- Powerdyne vs. Vortech
- Installing ATI 2 core & P600B pulley question...
- Any idea on this setup?
- Anyone ever run or now running a turbo on a BBC ??
- Will my engine last long with this set-up??
- My Twin Turbo Camaro, Weird Problem?
- bypass valve for emissions?
- What msd box do i need?
- go with a 355, 383 or 396
- Single Turbo Kits...
- Hows this cam(turbo)
- Livernois Motorsports Turbo Escalade Video
- Need help selecting programmer for 383 @ 10psi
- Bad coil or gap too big?
- Need help. O2 sensor postition
- Have a grand national turbo question
- vortech v-1 A-trim
- Remove ac compressor insert supercharger
- Whats included in the PTK Hot Parts?
- Can you change impellers in a blower?
- How to tell if bypass valve is leaking?
- 42in. 12 rib serpentine alternative sorce
- Please Help - Thinking About Buying This Car Can Anybody Tell Me....
- MAF codebuster 103......need help
- a thank you to all that have helped and a question as usual lol
- Is this a good cam for a 383?
- Supercharging stock LT1 dangers involved??
- Procharger questions
- Pullies s-trim
- If i was going to S/C..
- 383 Long block for sale..........
- how hard to plumb your own FI tubing?
- Wanna be on Two Guys Garage?
- Turbo good for my set up??
- Serious streetable HP, blower or turbo?
- cheapest rods & pistons for F.I.
- 12psi, no power???
- Boost retard controller.. yay or nay?
- Did search want personal opinions on which LT1 supercharger....
- Ross "down in the hole" pistons
- Boost retard light not on in 3rd gear, why?
- LT1 Methanol Injection
- how to wire a boost a pump
- For those that were interested in the new version of the LT1 PTK kit
- Cam info
- boost tolerance scale?
- stockish sized turbo cam
- Which MIG?
- stock 93 Z28 lt1 ready to be supercharged/turbocharged
- Why is belt not tight?
- Sound clip of 224/236 blower cam. any one have one?
- Snapped crank snout yesterday!
- More Boost!!!!
- why not poly intsead of metal for plumbing???
- I Need A Supercharger. Please Help...
- Wheel hop and suspension
- STS and a muffler....
- custom-built turbo?
- belt question
- 383 with 9.8-1 c.r. to high for 9#?
- Rings for turbo setup
- Pics of hard intake, supercharger, etc. Link works now:)
- STS semi related question
- oil pan punch
- Motor is coming together.. Questions on setup and what else i need..
- Ok I got a question about cats and Turbos
- fuel pump witch one
- Intercooler required.......or better to have?
- What size T-clamps for TB?
- ATI D1 air filter location. Help please
- anyone have pics of
- Supercharging Questions
- Roots type blower on an LT1?
- where to find 8-rib belt?
- someone enlighten me on the world of FI.
- BOV worth my money????
- Help me choose a turbo!!
- Need help picking a pump for custom ice/water setup ? ??
- looking at compressor maps in lbs per minute
- Supercharged guys: What kind of gains did you see?
- amount of psi
- BOV for SC?
- Potentially stupid supercharger question.
- Just got a quote for a vortech install...
- Junkyard single turbo
- Screw Compressors
