- programming my 91???
- BAP vs Twin in tank.
- install the DFI or stick with lt1 edit?
- D1 blower and CSI pump. Do they fit?
- Question about P600b install!
- Twin fuel pump pictures
- Turbo technologys LS1 turbo kits any good?
- Stupid "How much hp..." question inside, beware!
- Belt slip... please help, oh wise gurus
- Supercharger+headers
- All using low impedance injectors
- Tuning for boost, timing/fuel, also wideband Q.
- underdrive puley/balancer and SC question
- SC and nitrous, is it safe?
- Turbo 101
- Pro-M MAF
- does any one knows if ati refunds the money if i get back the Supercharger?
- induction/ram-carbed
- Procharger pulley size?
- High impetance 60&75lb injectors
- Cryogenic cooler instead of intercooler?
- Source for rubber couplers?
- Great heads, quickly?
- What Fuel Presure should I be Seeing??
- Dyno Graphs
- Breather or back into intake?
- No more proturbo kits
- Installing NX kit next week advice needed
- what crank pulley are you guys using?
- Ls1 Procharger Question
- Cool install
- procharger help?
- 1000hp Lt1
- knock retard on a turbo
- how much power can I produce with an LT1 Edit running speed density?
- LPH to lb/hr convert?
- Anyone need a front mount IC?
- procharger oil restrictor
- moving mass air meter!!
- paxton msd 6-btm for sale
- should i
- update on our kit
- Pod Gauges, who makes nice looking units?
- PCV oil seperator
- First Dyno #s and Converter taking a dump.
- where to buy 12 rib
- Hypertech Maf table vs. Stock??
- Reality Check Needed!!
- Boost gauge question
- pyrometer on cyl 7,8 = no burn??
- where does the maf go with the sts kit?
- Will EGR work ok under boost?
- Which plugs to use w/ Supercharger
- boost gauge connection..
- maf to pressurized side
- blower forsale ati lt1
- rskrause....need suggestion on blower cam, long but detailed.
- Alcohol Injection
- Need help Powerdyne People??????
- Bracketry costs
- who has a boost gauge? help me!
- woohoo, my turbo showed up
- Alcohol Injection Results
- HT3B turbo information
- Will this cam work?
- Could use some thoughts on T-70 setup:
- which one??
- 2 psi then nothing WTF??
- Anyone boosted with nitrous?
- How much psi will this push?
- cheapest, best, most power blower?
- Turbo or Supercharged
- 1000hp C5 Vette
- LT1 Supercharger
- 383 Question?
- blower pics needed
- Is it possible to use the hooker y instead of the mufflex y with their 4 "
- monoblade sticking problem
- Turbo guys, your going to LOVE this....
- Turbo boost controllers
- Cam/blower Question
- Dyno blues
- New turbo #'s and pics
- powerdyne ...tensioner q
- Some S/C Parts Questions
- Best fuel injection system for centrifugal supercharger???
- 6btm and autometer tach
- MAF location and boost.
- Couple of Supercharged LT1 ?'s
- T or TT?
- Need a little help with twin turbos
- lookin to get a supercharger
- Sound clips of mondo BOV?
- 55# injectors
- blower heads
- Newbie, Turbo questions
- paxta-map fueler calibration?
- Oil drain mounted below oil level w/scavenge pump?
- Ribbed-belt slippage estimate - calc's within
- Blower or Juice (that is the question)
- Loading up at low rpms!!!!
- Power Estimates.. i know everyone hates these threads but..
- Where to buy cog setup?
- MAF on pressure side
- MAF readings under boost and at idle?
- crankcase ventilation on boosted engine...
- Vortech questions
- superchargers and cam combo's
- TUrbo HEaders...
- fuel injectors
- Help...
- JE Pistons
- P1SC...pro and cons
- Superfueller injectors... (?s & WTB)
- got any turbo LT1 videos?
- Kenedy Dynotune
- making more power using fmu than with bigger injectors?
- What radius bends for piping?
- all 3192/3196 users
- ATI intercooling questions
- ATI Procharger on ebay
- FS: 3.125" vortech pulley
- Which FMU for twin turbo?
- crank/pulley belt part number for 6psi powerdyne
- 2 fuel pumps or only 1
- Newbie ?: How will Powerdyne affect stock reliability?
- boost gauge hookup??
- How do you clock a Vortech blower???
- New Motor loading up - Overfueling - Please HELP!!!!!
- H2O injection...
- Methanol Injection with S/C
- FDelphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence?
- Put a blower on a '95 Z28?
- New 5# ATI supercharger (LS1)
- go get a blower or to not
- which fuel pump will work ?
- Dimensions of largest possible air filter w/ vortech blower.
- is this a good buy
- At what point are head studs necessary?
- Surging during cruise (CL)
- too much of a pain or not ... ?
- Measuring pulley??
- WTB good used Vortech or ATI
- Timing Question on Vortech Setup.
- Whats wrong with my car (White smoke)?
- Supercharger guys... Got your stock Crank hub laying around?
- Source for 4 bolt main caps
- Blitz IC pics
- pulley on paxton hard to spin??
- 240 datsun lt1 turbo buildup... ?????'s
- Paxton Charger Installed - What Upgrades Do I Need Now!? HELP HELP!!!!
- Changing from 30# to 42# injectors??
- Front mount intercooler on a trans-am...
- Anyone spraying a boosted motor?
- Can I run a 4.5psi SC with little problems?
- AFR target w/ 25# Boost
- 115 or 116lsa for 224/236 xe high lift?
- Proper comp. ratio for pump gas turbo motor?
- To O-ring or not to O-ring, that is the question
- Jet-Hot coatings for turbo manifolds, housing
- New STS Turbo Install
- Stutter at 5000 RPM and I'm supercharged
- Found cracks in torus, best way 2 weld?
- ATI car won't stay running
- FMU Removal.. (?)
- Supercharger Help
- MAF pressure side=rich?
- Car smokes out the breather but.......
- Post your boost and kind of fuel
- Supercharger with innercooler
- A little Help Please
- Does runner length matter with forced induction?
- Vortech Oil Feed Hose
- ATI Mustang question
- Turbo charging
- A WORKING Electric Supercharger!
- Connecting the BAP to the electric WP
- V-1 vs. V-2...whats the diff?
- Would you buy a used P600B w/high miles?
- Vortech Aftercooler question
- STS Kit
- ls1 turbo
- Best price for CP pistons? Thoughts?
- Any one fimilar with ATI PROCHARGERS???
- strim pulley r&r
- Spark plug question
- can i calculate boost from pulleys?
- any trouble shooting pros need help
- engine rebuilt for boost
- Dissappointing results.
- New Boost Gauge = Fuel Efficiency
- Piston Tech
- Pictures of a supercharger motor build up
- Where can you buy procharger pulleys?
- pcv again
- Turbo Technologies Kit
- belt size vortech 3.125
- PTK has released some pricing and info on the LS1 F-body kit..
- No boost after intercooler install...
- Whats a good turbocharged engine Combo?
- Oil return hose help
- any pics of Vortech Mondo valve installed ?
- 12:1 compression to much for a 12psi procharger?
- Can anyone help with what I think is a fuel problem??
- dosent anyone run this pully combo
- Where is this oil leak!!!!
- what SC kit has these install symptoms
- Need new motor Please Help!!
- Anyone need a check valve
- garret twin turbos. question
- stock lt1 shortblock and strim 6psi dyno within
- LT1 turbo cam choice
- guys w/a4 and supercharged inside please
- Serious buyer looking for good used S-Trim
- is this fpr good for forced induction?
- Hotcam/Supercharger?
- Turbos not draining fast enough?
- More airflow or just a thought...
- Air Intake Question?
- procharger 8# on stock engine
- supercharger???
- is this turbo too small
- Mechanical problem preventing my car from making boost...
- Looking for Advice on Intercooler - Buy Vortech or Custom?
- Bottom end questions .
- Supercharged 3.4?????
- need help..
- what fuel injector size should i use?
- How much power should i expect from a supercharger?
- LS1 SUPERCHARGED leakin oil from unknown spot PLEASE HELP
- vortech 6 pound reliability question need help quick
- odd sound
- supercharging a v6
- Vortech oil line restrictor
- Oil Out Of Dipstick ?????
- Need help with Accel Injectors
- suggestions, crank pulley bolt loosening:LS1 D1sc
- Stock MAF or MAF ends?
- superchargers
- Emissions Legal Turbo Manifolds
- supercharger
- Advanced??? Blower questions.....
- ATI intercooler question
- Injector question
- Compressor Maps?
- what heads are best for supercharged engine?
- some set up questions for the experts out there....
- Heads and cam
- Greddy BOV + Vortech Supercharger kit = whoosh sound?
- Dynamic compression vs Static compression
