will 97 interior pars fit a 94?
Old Apr 11, 2012 | 08:29 PM
Rij1's Avatar
I'm looking to replace parts from a 97 to my 94. I'm wondering if the window motors, door panels and dash will fit. also if there are parts that wont fit.
Old Apr 11, 2012 | 10:13 PM
greenformula94's Avatar
Re: will 97 interior pars fit a 94?
yup only diffs were the steering wheels and gauge cluster i beleive, but they are still the same shape, just digital versus analog
Old Apr 12, 2012 | 07:10 AM
blackbirdta's Avatar
window motors should swap, door panels I believe are the same, but '93 to '96 dashes are different from '97. '97's had the '98-'02 LS1 dash. Also early '97s have a non digital odometer while later ones are digital. They can and have certainly been swapped, but you should research that more before jumping in. If you're just looking for a quick replacement you might not want a '97. Then again there won't be much "quick" about a dash swap anyway..
Old Apr 24, 2012 | 10:50 PM
FuryZ28's Avatar
Everything transfers...in fact, even the 98-02 interior parts fit perfectly, save for the dash (unless you completely replace the entire dash. I have a 93 Camaro Z28 and I replaced the interior (save for the dash) with a 00 Camaro SS interior.
Old May 27, 2012 | 12:03 AM
aznmike's Avatar
yeah everything will work i have a 94 camaro and i swapped the dash to a 2000 dash the only thing is you have splice the wires for the newer dash and if youre using a v6 gauge cluster everything besides the rpm gauge wont work. itll have to be the lt1 cluster for everythinng to work right. ls1 cluster wont work at all soooo if its a 97 lt1 car youre good
RUENUF
May 25, 2016 08:10 PM
Fastbird93
Apr 9, 2016 07:01 PM
RUENUF
Mar 13, 2016 03:39 PM
cmsmith
Mar 24, 2015 02:28 PM
Jan 23, 2015 01:13 PM
