will 1995 t tops work on a 93?
i recently picked up a t top conversion kit for my 1993 camaro z28
i got everything from two different people,
1 guy i got everything but the t tops and headliner (came from a 1998)
the other guy i got the t tops from (came from a 1995)
will the 1995 t tops work with the 1998 brackets??
it looks like the pins are smaller then the hole that the bracket has, i just dont want any vibrating and noisyness when i do this,
and im also looking for a pair of t top locks with atleast 1 key, or if you have a pair of locks with no key ill even take those if theyre free,
Re: will 1995 t tops work on a 93?
They should work, as far as I know all that stuff is pretty much the same. Post a thread about this in the parts wanted section as well, you should be able to get your hands on a set of locks there. Hope this helps.
10-31-2016 11:09 AM
07-04-2005 05:00 PM
