white faced gagues
white faced gagues
I want white face gagues on my 96 SS.. who makes the best ones? I only want the Tach, Speed-O, Temp, Oil Press., Batt., and Fuel gagues white.. not the odometer and the panel that shows up the Skip Shift, Low Trac., etc. Lights. any help would be appreciated
I'm guessing you want the MacEwen Guages then. Do a search on that to get the URL, I can't remember it. I installed a set and swapped out the backlighting...not bad at all...MAJOR improvement. They are a bit pricier than the other types of guages overlays though...the other ones that go around the odometer area and up around the indicator lights are reverse indiglo and stuff...(I wonder if you can cut those parts out and it still work?!?! Those are like 30 bucks and comes with everything you need to wire it up. The Macewen is like 85 bucks...nothing to wire so it's just overlays.
-Mike
-Mike
