Where to get smoked corners
Ive seen the front corner blinker blackout covers but i dont want those. What i am looking for is 2 new smoked corner lenses. The whol fixture not just a cover or spray. I dont want the clear corners because i dont think they would look good.
SOOOO, anyone know where i could find a pair of them?
Re: Where to get smoked corners
Are you sure? will i still be able to see the lights no problem if i put a moderate coat of nightshades on? Where do i get it just the local auto store? and is it called "nightshades"?
Go to my cardomain link for the 93 3.4 and on one of the pages I have before and after shots of when I did the Nightshades tint. They're still visible and effective in both day and night. You can put more or less coats on depending what you want, mine are pretty dark so you might go lighter but I wouldn't reccommend much darker. Yes, it is called Nightshades though, I got the can from Parks Auto Parts. You might be able to get it at Advance or AutoZone. Google it and I'm sure you'll find it.
A distinction needs to be made: the smoked corners on Ebay have the inner housings smoked, but still have a clear lens. Doing the Nightshades will smoke the outer lenses. If you apply nightshades over the top of the stock yellow turn signals, when light shines through them or if looked at from certain angles, the yellow will still shine through.
You're better off just getting the Ebay ones.
Johnny6: Do you have any link for those model???Ive been searching for those this model for months on ebay but the only model that i could find was the standard clear one.
Thank you
Thank you
I searched around ebay and i guess there aren't any for sale right now, i do have the link to the seller and his ebay store you could send him a message and see if he's got a set http://stores.ebay.com/Eurosport-Garage
http://cgi.ebay.com/ebaymotors/93-02...spagenameZWDVW
Even though they are 40 dollars, and it looks like its missing the little side small bulb insert, i dont know
http://cgi.ebay.com/ebaymotors/93-97...QQcmdZViewItem
Notice they are "black housing" meaning the inside is black and the outside is clear. So it's basically a "clear corner" but with a black housing. I belive that is what you are looking for.
Someone on here did his front turn signals with the niteshade stuff. It didnt look good when they lit up because niteshade has a redish tint in it because they are made for taillights.
