Wheels height question?
Old 12-01-2002, 12:27 AM
sleeperZragtop's Avatar
I'm going to an 18" wheel on the rear of my Z, but I don't want to have to any computer editing. What would equal in diameter to a 275/40/17? If I went to a 285/35/18 would I be ok. What would be the height difference?
sleeperZragtop is offline
Old 12-01-2002, 12:35 AM
Team Untouchable's Avatar
a 275-35-18. That'll do it for ya.
Team Untouchable is offline
Old 12-01-2002, 12:42 AM
..thank you, that's all I need to know...but if I did go to a 285 it wouldn't hurt, would it?
Old 12-01-2002, 01:31 AM
No it wouldnt hurt considering the difference in the sidewall for the 275 vs the 285 is barely anything. THey may rub on the front though. Just look out for that.
Old 12-01-2002, 01:43 AM
..it would be just out the back, but thanks for your replies and input...
Old 12-01-2002, 12:44 PM
KevinAce's Avatar
I just bought some 245/45/18 all around for my 99 3.8L, and was told they'd fit fine.
I believe you can go up to 285's in the back, or even 295's without rubbing. As far as height goes, I was told by a number of people that going over 18 can be risky (some guy said 20's would fit).
KevinAce is offline
Old 12-01-2002, 01:07 PM
...Nice
Old 12-01-2002, 02:40 PM
To answer you question....
The stock tire size (245/50-16 or 275/40-17) works out to about 25.65" diameter.
A 275/35-18 is 25.58" diameter..... causing the speedo to read 2/10 mph high at 60mph.
A 285/35-18 is 25.85" diameter..... causing the speedo to read 1/2 mph low at 60mph.
Niether of these speed errors is worth "reprogramming" unless you just happen to have a HPP or LT1_Edit handy..... .
All of the dimensions are "theoretical", to the extent that there is a little variation from manufacturer to manufacturer, and even within different tire lines from the same manufacturer.
Injuneer is online now
Old 12-01-2002, 02:55 PM
...that's exactly what I was looking for, I do however have a HPP3 for my A4 issue, is there a setting on the HPP3 for 18" wheels? on the rear ofcourse.
Airplanedoc
02-01-2015 07:14 PM
30thZ4C
Wheels and Tires
01-29-2015 06:03 PM
cmdeshon
12-12-2014 10:51 PM
ChrisFrez
11-30-2014 08:41 AM
redzed
09-04-2002 06:22 PM
Quick Reply: Wheels height question?
