Wheel offsett help!
Old 08-06-2003, 12:12 PM
airmanb2's Avatar
Wheel offsett help!
Looking at the ZR1 replicas at discount tire direct. What offsett do I need. The 38 or the 56? Thanks in advance!!
airmanb2 is offline
Old 08-06-2003, 12:51 PM
17x9.5" 56mm offset
17x11" 50mm offset
They will fit just like this!
Injuneer is offline
Old 08-06-2003, 12:53 PM
airmanb2's Avatar
where do you get the 17x11's. I only saw the 17X9.5's.
airmanb2 is offline
Old 08-06-2003, 12:59 PM
AFS sells 17x11. Several other companies do also.
AFS
Injuneer is offline
Old 08-06-2003, 01:03 PM
airmanb2's Avatar
any issues with running the 315's in the rear with the 11in wheel, or did you just get the 275's?
airmanb2 is offline
Old 08-06-2003, 01:07 PM
I run 315/35-17 BFG Drag Radials in the back.
NOT ALL 4th GENS ARE THE SAME.
Some people put the 17x11 50mm offset wheels on, with 315's and have no interference at all. Others find they have to:
Cut the corner off the jounce bumper bracket:
Jounce Bumper
Hammer the inner fender liners (add a little rubberized undercoat, looks better):
Hammer
Recenter the body with an adjustable panhard bar.
You may have to do none or all of those... varies extremely from car to car.
Injuneer is offline
Old 08-06-2003, 01:13 PM
airmanb2's Avatar
I have heard those stories before, and I am wondering if it is just better to go with the 9.5's all the way around instead of finding out they don't fit in the process? I am also wondering if my car being a vert will cause an issue?
airmanb2 is offline
Old 08-06-2003, 01:45 PM
Bralgar's Avatar
Check out the chart on the bottom of this site
Should help out.
Bralgar is offline
Old 08-07-2003, 12:01 PM
First, I am just assuming you have a 4th Gen, since you don't have a "signature" and don't included any info.
The convertibles are no different in the wheel wells than the coupes, as far as dimensions are concerned. What is different is some additional reinforcing behind the sheetmetal on the inside of the fender liners that may make hammering a bit harder if you need large movement.
I have been involved with putting a set of real GM Grand Sport offset (50mm) 17x11's on a 30th SS Convertible, and they fit as well or better even than on my Formula coupe.
Injuneer is offline
force10
08-10-2015 08:30 AM
30th Anniv Z28
08-01-2015 10:39 AM
240ssLs3
07-13-2015 05:06 PM
Slayer
07-04-2015 03:06 PM
jasonduaine
06-04-2015 09:29 AM
Quick Reply: Wheel offsett help!
