wanted- interior pic of cowl hood and dash??
Old 09-10-2007, 11:56 AM
greggy2belly's Avatar
This is an odd request, but I am looking for a picture to work with. I am looking for a picture from the drivers seat or something like that that shows the dash, or at least with the AC and radio panel that looks into a 2" or 4" cowl hood. I know it's odd, but I am trying to figure out where to put my gauges.
I am planning mechanical Fuel Pressure and Oil Pressure inside the 4" cowl hood, water temp and voltage on the A-pillar, trans temp and boost gauge where the AC controls go, and a 5" tach with a shift light, and low oil pressure warning light on the dash.
If anyone can come up with a picture like this that would be awesome.
It may seem like overkill to some, but I am working on a turbo383, TH-400 with a brake, moser 9", and taking out the AC.
Thankss alot,
Greg
greggy2belly is offline
Old 09-12-2007, 07:28 AM
Anyone got anything?
Old 09-12-2007, 06:42 PM
lethal93ta's Avatar
mines 3 inches and its not enough to see in there and even so a 2 1/16 gauge with a mount its to high to fit in there. but yet its high enough when Im sitting I cant see my passange side pop up head light with out sitting up and all but putting my head on the roof. do you have a camaro or trans am? how bout something like what I did
lethal93ta is offline
Old 09-12-2007, 09:23 PM
Camaro. I plan on going with a 4"VFN pin-on hood. I plan on keeping the instrument cluster alone cause I am not too worried about what it is saying. I was gonna put gauges on the pillar, but I forgot it is getting a 10pt. moly cage, so I am just gonna mount them on the cage. I am going with 2 5/8 sport comp gauges for everything and 5" tach with the shift light and low oil light.
That is a slick set-up you have. I was just gonna run a painless box just to put the fuel pump and fan switch on. What all gauges are you running anyways? The only problem I found was they didn't offer the sport comp with a liquid filled boost gauge.
Old 09-16-2007, 01:41 PM
AZ2ENVY's Avatar
Here is a quick pic from the inside of my Camaro . Sorry for the
quality Btw I believe the cowl is 3"
AZ2ENVY is offline
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
RedLineRev
01-23-2003 03:51 PM
2000silverz28
09-07-2002 01:48 AM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: wanted- interior pic of cowl hood and dash??
