Tailight's fill up like fishtank..
Do ya'll ever suffer from this? When it rains my tail lights fill like fishtanks! I had one so full that it was way over the bulbs, and they still worked!!! Lol.
I ended up drilling a few small holes in the corner of the lense to let the water drain out as I have replaced the bulbs about 5 times due to this...
Where exactly do they leak in at?
Permatex® Clear RTV Silicone Adhesive Sealant
http://www.permatex.com/products/Aut...ve_Sealant.htm
The lens is separating from housing... Just needs to be sealed...
I had this same problem about a week ago. It was where the lens meets the reflector at the top , all I did was drill a small hole in the bottom of the housing with the taillight out and if you notice when the light is out there is a place under the tail light with a groove. I marked this spot to drill the hole so it would have room to drain out. Easy Fix but still had a couple bulbs to replace.
