t/a door panels in a camaro
Old 02-14-2005, 09:59 AM
3800rs's Avatar
Question t/a door panels in a camaro
so as the question asks how do you go about doing it with new whiles and screws ? some say you dont even have to cut but i figured i'd ask here
3800rs is offline
Old 02-15-2005, 12:04 AM
Z95m6's Avatar
Re: t/a door panels in a camaro
http://www.ls1.com/forums/showthread...hreadid=321627
It took me 2 hrs to install mine. Wiring the mirror switch up is a B!tch. It took me longer to wire up the mirrors than to install the panels. Actually it was a B!tch to install my entire TA interior but it pays off nicely everytime i sit in my car, the dash lights red, the door panels flow well with the car and the
TA seats hug my ***.
Z95m6 is offline
Old 02-15-2005, 03:06 PM
3800rs's Avatar
Thanx. How Did You Do The Mirror ?
3800rs is offline
Old 02-15-2005, 03:19 PM
CamaroBoy96Z28's Avatar
Someone posted a wiring diagram a while back and thats what I used. Have to search for it. T/A door panels are great and yeah takes no more than 2 hours. I have some not so good pics in my sig.
CamaroBoy96Z28 is offline
Old 02-15-2005, 08:53 PM
3800rs's Avatar
i started today got a few q's. 1st the left screw i had some trouble getting it in the spot, and there is also like a screw hole at the bottom of the pocket of the door. did anyone screw something in there ? thanx
3800rs is offline
Old 02-15-2005, 09:01 PM
ProjectCamaro's Avatar
Here's a walk-through I created to show how to do it.
http://www.projectcamaro.com/tadoorpanels.htm
ProjectCamaro is offline
Old 02-16-2005, 08:37 AM
Kataklysm's Avatar
WHy not buy a t/a or firebird if you want the interior? Just a thought.
Kataklysm is offline
Old 02-16-2005, 09:50 AM
3800rs's Avatar
thanx for the walk through. only reason for putting in firebird door panels is b/c i have tweeters and dont want to drill holes in my panel again or buy the pods for the mirror.
3800rs is offline
Old 02-16-2005, 11:16 AM
Z95m6's Avatar
Obviously because some of us like the looks of our Camaro's more but we think its easier to add TA interior rather than buy a Bird and put Camaro body panels on it.
Z95m6 is offline
Old 02-16-2005, 11:43 AM
3800rs's Avatar
thanx cobra
3800rs is offline
Old 02-16-2005, 08:26 PM
3800rs's Avatar
ran into a lil problem today thought i finished the driver door but all the way to the left going down the side it wont stay on all clips are mint. do i need to put the screw in that points straight down inside the pocket to fix this and how can i do that ? any other suggestions ?
3800rs is offline
Old 02-16-2005, 08:49 PM
Z95m6's Avatar
i'm only running 3 screws in mine. The two in the door handle area and the one in the pocket. I drilled the fourth hole in the arm rest, i just haven't put the screw in yet.
Z95m6 is offline
Old 02-17-2005, 07:31 AM
rlax31's Avatar
same here, except i'm not even using the pocket screw, no problems
rlax31 is offline
Old 02-17-2005, 09:39 AM
3800rs's Avatar
which 1 is the pocket screw ? the one that goes straight down ?
3800rs is offline
Old 02-17-2005, 09:51 AM
rlax31's Avatar
yes, the one on the bottom...in the pocket...it the pocket screw
rlax31 is offline
Quick Reply: t/a door panels in a camaro
