SS spoiler LEDs OUT
SS spoiler LEDs OUT
Just put my 00 ss spoiler on my 95, yes it tripped the ABS light, but I'm concerned about it having 6 leds burned out. Do I have to get a new third brake light? Does anyone no where I can pick one up because this isn't an SS vehicle? Part number? Thanks!
Patrick
Patrick
Originally posted by Green G0blin
no way the led light bar is 35 dollars, its 125 or so from year one.
Guys I just went thru this and here is what is fact. I bought a used ss SLP OEM wing for a 2000 Camaro. The Light had been painted on. ( Overspray) I checked around and noticed a link on some board that a guy had a wings west SS spoiler and the light had SLP moulded into the plastic. So I called them and talked to a guy @ wingswest. The light is exact. right down to the correct numbers that are moulded into the light. The only difference is the light does not come with the GM plug. Pay 125$ if you like, but don't say that I did not try to save you a few bucks. PS the OE light had the same import label that the wingswest light had. I think they are getting them from the same supplier.
Or if you felt handy with a razor knife and a good soldering iron... get some Solder wick, and just replace the LED (s), but the best bet is to replace all of them because the ones you'll find are NOT going to be the same ones they used.
mlopezart
09-08-2015 12:15 PM
Henson071
08-04-2015 09:32 AM
