Sring/Shock Combo..
Sring/Shock Combo..
Well in the market for new shocks and while im at it i would like to lower the car. i dont want it slammed to the ground..i just want it to sit a little bit lower and eliminate some wheel gap..im would like to see some of the setups everyone has on the board..and where they got it from..thanks
The suspension sub-forum is probably your best bet. Also, a search will give you plenty of reading and visual material.
You would probably be best served by the Bilstein kit. The shocks are valved to match the springs if I remember correctly, and it is a moderate drop in ride height (~1 inch). Otherwise, you may have to get the shocks re-valved to match the difference in ride height of the car to avoid early failure.
It has been a while since I have seriously read up on this stuff, so I may be wrong. A search will set you free!
Nitro Dave
11-30-2006 03:06 PM
