Side moldings
Old 08-21-2009, 05:25 PM
revolution79z28's Avatar
Side moldings
What is the best way to remove these side moldings on a '93 Z28? Does anybody have pics of it done? Will I be able to buff the glue of the body? What do you guys suggest? Also, I still have my stock salad shooter wheels, and I was thinking about sand blasting them. What do you guys think about that? I painted them a couple of years ago but the paint was cheap and is peeling off right now, so I figured that sand blasting them would make them look alot better than they do now. I just wanted to get some opinions about it. Thanks again guys.
revolution79z28 is offline
Old 08-21-2009, 06:49 PM
shock6906's Avatar
I've heard of people using floss and "walking" it down behind the molding. You can use something like "Goof Off" to get the glue off of there. For the wheels, sandblasting them will probably help get a new coat of paint to stick better. I'm not sure what color your car is, so I can't suggest a paint color. Personally, I like the salad shooters in silver. I think they just look cheap in black.
shock6906 is offline
Old 08-21-2009, 07:42 PM
My car is red and I thought about black paint but I went with silver but the paint didn't stick we at all. What about just leaving it bare after I sand blast it? Or would I run into problems with discoloration later?
Old 08-21-2009, 08:00 PM
johnny6's Avatar
I just slowly peeled mine off then i used rubbing alcohol to remove the glue, took me a whole 30 minutes.
johnny6 is offline
Old 08-22-2009, 02:49 PM
silentsprintero's Avatar
+1, but I used that and tried bug and tar remover, both worked fine. Under the emblem, however, is tough to get off of my car. I need a wheel eraser by 3M to get the residue off.
silentsprintero is offline
Old 08-23-2009, 12:01 PM
I'm just removing the moldings because they are starting to look really bad no matter what I do to clean them. The emblem is staying.
Old 08-23-2009, 09:35 PM
shock6906's Avatar
You must not have cleaned them very well before painting, because they should accept paint with no problem. If you don't paint them after blasting, they'll look like s**t in a week.
Old 08-23-2009, 10:15 PM
Roach02's Avatar
i agree
Roach02 is offline
Bobczar
10-23-2015 11:22 AM
Fastbird93
07-11-2015 04:37 PM
Boss002
07-09-2015 03:33 PM
Patricklt1
04-24-2015 06:29 AM
TransAm4utoenv
08-28-2002 11:06 PM
Quick Reply: Side moldings
