Serious "bling"!! New engine powder coating
Old 04-18-2007, 09:22 PM
12SCNDZ's Avatar
Ok, this engine is stuffed with some serious internal parts, so I wanted it to look good, as well. The intake, water pump, and alternator have all been powder coated with 2 stage candy purple over a bright silver base. It's pretty expensive, but I wanted something different. The powder was done here. http://www.eastcoastpowdercoating.com/
12SCNDZ is offline
Old 04-18-2007, 09:26 PM
nick3's Avatar
looks really good
nick3 is offline
Old 04-18-2007, 10:14 PM
83tpi_3rd-gen(sri)'s Avatar
thats some nice looking stuff right there.
83tpi_3rd-gen(sri) is offline
Old 04-19-2007, 06:36 AM
shock6906's Avatar
Looks great. I love the valve covers too.
shock6906 is offline
Old 04-19-2007, 10:17 AM
danhr's Avatar
would you be offended if I made love to your throttle body?
danhr is offline
Old 04-19-2007, 10:35 AM
blown383's Avatar
Looks REALLY good! If you don't mind us asking... how much did it cost you to powder coat? I can't imagine in costing more than chrome plating everything.
-B
blown383 is offline
Old 04-19-2007, 10:50 AM
bmwmcars's Avatar
wow, nice looking motor
bmwmcars is offline
Old 04-19-2007, 11:59 AM
12SCNDZ's Avatar
-B
Because of it being a candy color, it cost me a little more. Most of the cost is eaten up in the labor involved in masking everything up. The intake was $125, the water pump was $75, and the alternator was $50.
Frank
12SCNDZ is offline
Old 04-19-2007, 12:06 PM
2000GTP's Avatar
That is one gorgeous looking motor Frank.
2000GTP is offline
Old 04-19-2007, 12:11 PM
12SCNDZ's Avatar
Thanks for the compliments. Just so everyone knows, it aint just for looks. The specs go a little like this:
355 with Hard Block short fill, zero decked
Ross flat top Nitrous pistons
Manley 6" 4340 H-beam rods
King bearings
Sealed Power file fit rings
Polished and balanced 3.48" stroke crank
LE3 heads with 2.05"-1.60" valves
GM 847 cam
Morel link bar hydraulic roller lifters
K-Motion K-800 springs
K-Motion 10* titanium retainers and 10* locks
COMP "Hi-Tech" pushrods
COMP "Pro Magnum" 1.6 roller rockers (7/16" studs)
Lunati timing chain with Cloyes O/S bottom sprocket
Moroso oiling
all ARP bolts
Ported LT1 intake
Holley 58MM throttle body
GM opti with MSD cap and rotor
Recetronix 37# injectors
Taylor 8MM wires
MSD 7AL-2
MSD "Blaster" coil
Fluidampr balancer
We're gonna throw this in a 3300# '93 Z with a full Spohn/AJE/QA1 suspension, and shoot it with a 200 shot.
Frank
12SCNDZ is offline
Old 04-19-2007, 12:32 PM
danhr's Avatar
well that's crap... that is the exact same setup I had built for my car.... but I had to sell it because I needed money.... that and I only had le2 heads...
did you opt for the forged eagle crank or is that the stock one?
danhr is offline
Old 04-19-2007, 12:36 PM
Moshbmx1's Avatar
B-e-a-u-t-i-f-u-l
(sounds slow)
Moshbmx1 is offline
Old 04-19-2007, 01:08 PM
blown383's Avatar
Frank
Thats a GREAT deal... I had my alternator, waterpump, accessory bracket, and all of the associated bolts chromed for $275.00.... if I had the intake manifold done.....I would have been BROKE!
-B
blown383 is offline
Old 04-19-2007, 02:56 PM
ZBLKHELLRZR's Avatar
That's sweet man. Where did you get those valve covers? That's the 2nd set I've ever seen and still can't find them.
ZBLKHELLRZR is offline
Old 04-19-2007, 04:20 PM
12SCNDZ's Avatar
GM Performance Parts. They're made by Proform, and come polished, chromed aluminum, and black crinkle. Mine are chromed aluminum. They'll run you just shy of $200
Frank
12SCNDZ is offline
Quick Reply: Serious "bling"!! New engine powder coating
