Removing Rear fender on 94 Chevy camaro Z28
I have tried to find out how to remove the right passenger rear fender because it was hit and dented in by previous owner. i want to remove it and fix it up but am having a hard time finding out how to easily remove it? i would really appreciate it if anyone could help me out, thank you.
Re: Removing Rear fender on 94 Chevy camaro Z28
couple cases of bear, then make friends with a good body man.
I have done it on a 69 camaro and it is no picnic. drilling and spot welding and a lot of new language. But in the end it turned out spotless.
yeah. you'd have to cut it out, or drill the spot welds out and take it off. i had the same thing happen on the drivers side only i ran into my own car with a semi truck. try looking up something on youtube. i've seen it before. you use a can of duster and a hair dryer or heat gun and it pops right out. i had my friend help me pull the dent out with a stinger. which means grinding down to bear metal and repainting when finished. Good Luck. you could try to find the pictures of mine. https://www.camaroz28.com/forums/sho...d.php?t=777144
Keep in mind that the rear quarters are structural and if you cut one out, it may be smart to tack weld a steel brace in so the unibody doesn't deform as a result of cutting it out.
fpete1992
12-11-2014 03:51 PM
ChrisFrez
12-07-2014 06:01 PM
12-04-2014 11:56 AM
NewsBot
12-03-2014 12:30 PM
