Removing old vinyl overlay
Old 04-22-2009, 02:46 PM
EnFuegoZ28's Avatar
My Z28 had a rear CAMARO vinyl insert when I bought it. The problem is it is old and falling apart. It is flaking pretty bad. My question is how do I remove the rest without damaging the panel?
TIA
EnFuegoZ28 is offline
Old 04-22-2009, 07:54 PM
yy
yy's Avatar
What kind of adhesive or tape was used to apply the ovelays? I'm sure there are better stuff out there but try WD-40 on a small area. It usually works well without damaging the paint. I would let it soak for several minutes and then gently scrape it off using your fingernail or a hard rubber object like those used by window tinters. However, be sure to remove all the shiny nonporous parts first and then apply the WD-40 on the leftover adhesive.
yy is offline
marlar98
09-19-2015 07:53 AM
RX Speed Works
09-11-2015 03:31 PM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
08-05-2015 08:35 AM
30th Anniv Z28
08-01-2015 10:39 AM
Quick Reply: Removing old vinyl overlay
