Rear vinyl inserts..
Old 08-02-2007, 03:10 PM
mustangmuncher's Avatar
I just got some smoothlocks, front bird overlay and pontiac vinyl inserts for the back. Front went great, smoothlocks were super easy and fast. When I got to the rear inserts, I just couldn't get some of the letters to line up and ruined a few. So getting ready to order another set, and was wondering if anyone had any tips.
mustangmuncher is offline
Old 08-02-2007, 06:39 PM
stroked 383's Avatar
Use some baby shampoo thinned out w/ water so you can slide them into place. Put like 3 drops of soap into some water and you'll be good to go. Get them positioned then press them in w/ a cloth of some sort to get out any access water....let dry and your done.
Hope that helps
stroked 383 is offline
Old 08-02-2007, 06:43 PM
94_PatriotRed_Z's Avatar
use rubbing alcohol with acouple drops of dish soap in it, the soap will allow you to move it around, and the alcohol will dry it up nicely, and use a cloth or something to squeeze the water out, I found a qtip worked well to get in tight spots
94_PatriotRed_Z is offline
Old 08-02-2007, 08:07 PM
Firebird_fr3ak's Avatar
what i did worked perfectly.
Firebird_fr3ak is offline
Old 08-02-2007, 10:57 PM
Thanks, will give that a try, should work. Should have looked before I gave it a shot.
Old 08-02-2007, 11:02 PM
dangalla's Avatar
using alot of windex should also work for this
dangalla is offline
HarleyZ28
10-05-2015 06:23 AM
birdblack
04-20-2015 04:24 PM
BandDirector Blk98ZM6
02-20-2015 07:42 AM
12-04-2014 11:56 AM
Chrisdude
07-25-2002 05:54 PM
Quick Reply: Rear vinyl inserts..
