REALLY good bug remover?
Re: REALLY good bug remover?
If you have a TON of tar and bugs, try spraying some WD-40 on the spots before you wipe them off. The only problem I found by doing this is, you then need to clean off the oil from the WD-40. But a little car detailer from mothers, or Zaino works well for that.
Coincedentally, WD-40 also works well for removing cunks of rubber after doing some track runs on slicks, or a big burnout.
BTW, you might consider moving this to the show and shine forum instead of the appearance section.
Fbodfather
25
06-21-2002 04:12 PM
