Putting on factory ground effects spoiler
I just ordered a factory ground effects spoiler from x2jesse1x and was wondering if there was anything special I needed to know before I attempted to put it on. When it gets here I am going to go to Advance Auto or Autozone and gets some 3M double sided tape (yall know the stuff) but is there anything else besides cleaning the area with alcohol first?
Looks like you have to drill holes to install it I really hope I dont **** it up. Anyone have any suggestions on what kind of bit to use? I thought it just went on with 3M double sided tape.
its was a joke, don't use liquid nails.....
I can tell you how to get you bolt holes in the perfect spot. Take a pc. of paper and make a long strip. Poke a nail thru it and stick it pointing up inside of the bolt hole.
Make sure the strips are long enough to come outside the perimiter of the spoiler. Sit the spilor in place and tape down the strips of paper. When you remove the spoiler your nails will be right where the hole needs to be
10-31-2016 11:09 AM
