Projector Lights?
Old 11-25-2002, 01:46 AM
4S Concepts SS's Avatar
Projector Lights?
I was wondering if there are projector lights for the LT-1s? I think they would look really awesome if they filled the entire black area with a projector light assembly. Any out there?
4S Concepts SS is offline
Old 11-25-2002, 12:40 PM
Paul 94Z M6's Avatar
as far as i know, there are no kits available.
i bought some Hella's and built my own setup. i'm pleased with the results and lighting is much improved!
http://home.earthlink.net/~dyankey/images/front2.jpg
Paul 94Z M6 is offline
Old 11-25-2002, 05:32 PM
Z Power's Avatar
Paul, I got a question for you. How much has the lighting improved? Would you consider fog/driving lights necessary (as they are with the stock lights if you want to see anything) with these? I'm going to do a similar site up to yours but I was thinking of incorporating a fog light into the area of the headlights (similar to the vw style i guess is the best way to describe it)
Eric
Z Power is offline
Old 11-25-2002, 05:43 PM
ImportKILLER's Avatar
Thumbs up
Geez, makes the car look like a smiling crazed ****. Very cool!
ImportKILLER is offline
Old 11-26-2002, 11:59 AM
driving lights are not a necessity as with the stock lights. the improvement in lighting is HUGE. the projector lenses provide a very uniform and strong beam.
i do plan to put some driving lights back on the car, mostly to help out in bad weather.
i think you will be hard-pressed to find room to mount the high, low, and a driving light all in the headlight area. i considered the same but when it came to mounting it was tight (and i cut out a LOT of stock material. it would be possible but difficult...
oh, and thanks for the complements!
Old 11-26-2002, 01:54 PM
sullyz's Avatar
Paul, what's the part number of those lights? Are they still available and how much do they run? I've been thinking of using the PIAAs, but yours look pretty good as well.
sullyz is offline
Old 11-26-2002, 04:13 PM
Z Power's Avatar
You can get the lights from here
Z Power is offline
Old 11-26-2002, 04:51 PM
sullyz's Avatar
Thanks, but which ones are they?
sullyz is offline
Old 11-26-2002, 05:46 PM
they are the hella 90mm
you will have to fabricate fully custom mounting surfaces for them
QuickSilver02
04-07-2015 11:12 AM
dluna333
15
03-13-2015 12:30 PM
Jlo
02-03-2015 09:41 PM
squarehead
01-15-2015 07:02 PM
Quick Reply: Projector Lights?
