Polish top of intake manifold?
Old 05-26-2003, 02:20 AM
Sanger's Avatar
I was curious if there was a way to clean up the top of the intake manifold to get it looking cleaner. A friend of mine said he used a light sandpaper and it came out clean when he showed me. So I was wondering if sanding it, then polishing it would make it put out a little more shine??
Sanger is offline
Old 05-26-2003, 02:32 AM
turbo_Z's Avatar
yes in order to polish that rough of a surface you will need to sand it.
turbo_Z is offline
Old 05-26-2003, 08:31 AM
PoorMan's Avatar
I have a pic of a completely polished manifold if you want me to email it to you. It's awesome, but the shine will dull after awhile. I think it's better to only polish things that can be touched up after you put it back on the car. The fuel rails, throttle body, ect.
I did the common powercoat on mine with rail polish, ect. I have a couple pics in the link. Grime on polished parts looks alot worse than grime on paint. Billit polish and a rag is all that is needed on the fuel rails becasue it's already a smooth surface. The throttle body, ect require sanding first. 200, 400, 600, 800, 1200, polish. The more sanding before polish the better. Try to get the metal as smooth as the fuel rails before appling polish. Just my .02.
Jeff D.
PoorMan is offline
Old 05-26-2003, 10:06 AM
ROCKN SS's Avatar
http://www.netsnapshot.com/pcw/build...UNT=1058&KEY=4
ROCKN SS is offline
Old 05-26-2003, 11:18 AM
Super Moderator
Brent94Z's Avatar
I'll move this to the Appearance Section.
Could go in the shown and shine forum too but there are a number of guys in the Appearance Forum who know quite a bit about polishing parts.
Brent94Z is offline
Old 05-26-2003, 11:44 AM
Mindgame's Avatar
Lots of work getting a nice polish cause you have to remove all the casting flash first. Then you'll need to seal it so it doesn't oxidize..... perhaps clear anodize or powdercoat.
-Mindgame
Mindgame is offline
Noer
02-28-2015 11:29 AM
alex5366
02-17-2015 08:12 PM
CARiD
01-27-2015 06:27 AM
Elcojoe
11-17-2014 10:27 PM
07-04-2005 05:00 PM
Quick Reply: Polish top of intake manifold?
