Pedals for the camaro like the ones on corvette???
Old 05-19-2003, 08:34 AM
Highlander's Avatar
All I have seen are like overlays or something... I want the complete pedals in aluminum.. where to get them?? Pics?? can the corvette ones be installed???
LMK
Highlander is offline
Old 05-19-2003, 02:16 PM
iamsparc's Avatar
I wouldn't mind knowing this either. I don't really wanna do an overlay either.
-Mike
iamsparc is offline
Old 05-19-2003, 02:29 PM
Highlander's Avatar
Exactly
Old 05-19-2003, 04:57 PM
TK 14 SS's Avatar
Try this...
Sullivan Racing Products (SRP)
Troy
TK 14 SS is offline
Old 05-19-2003, 10:58 PM
djk19's Avatar
Those are overlays as well.....
That is an overlay kit too. The whole pedal assembly in our cars work but just get the jobh done. there is so much slack in my pedal assembly it sucks. I allways wanted a tight throttle feel. The arms on my neighbors veete are fully aluminum as wlel as the small beefy pedals. As if they were one machined arm/pedal piece of billet aluminum or cast at that...
djk19 is offline
Old 05-20-2003, 05:58 PM
97droptopZ's Avatar
i dont know what the vette ones look like but mba has some although 120 bucks is a bit expensive
http://www.mbaproducts.com/interior.htm
97droptopZ is offline
Old 05-20-2003, 11:17 PM
Highlander's Avatar
THey are overlays
Old 05-20-2003, 11:41 PM
97droptopZ's Avatar
no... take a look at the more detailed pics on that page, it shows how the original pedal was removed and that one was put on. plus, i would think 1" thick overlays might be a bit uncomfortable
Old 05-22-2003, 02:44 PM
iamsparc's Avatar
Red face
NO, those ARE overlays. They bolt on AROUND the old pedal. I mean...you may actually take off the old rubber portion of the old pedal, but that's it, if that.
Someone really does need to make an entire pedal replalcement or some way to get a tighter feel out of these pedals...
-Mike
iamsparc is offline
Old 05-22-2003, 03:34 PM
djk19's Avatar
Right on. Thats what I'm saying. And it doens't look like it would be that big of a deal. LOKAR sells a nice billet gas pedal so an assembly that would just bolt into a stock camaro could be easy to make....
djk19 is offline
Old 05-23-2003, 09:20 AM
Severous01's Avatar
go to the junk yard and pull the pedal assembly from a vette...bolt it up and then youre done. it all has the gm hookups.
Severous01 is offline
Old 05-23-2003, 11:27 AM
Highlander's Avatar
That is all I wanted to know.. my car says corvette on the brake callipers.. It has original ZR1 wheels with Corvette centercaps... now it will have corvette pedals.. jaja.. the corvette wannabe
Well.. I think the camaro is the paupers corvette.. I think
Old 05-27-2003, 04:02 AM
brokenz's Avatar
Have you done this? If so what year was the donor? You sure you are still hitting 100% throttle opening? This really sounds interesting to me. I love pulling parts off of wrecked cars.
brokenz is offline
Old 05-27-2003, 08:01 AM
97FormulaWS-6's Avatar
Uhm... I'd like to see someone remove a Vette setup.... And attach it to a camaro... seeing it's a DRVIE-BY-WIRE system... which means the gas pedal doesn't even connect to the motor....
It could be done.. but it's take someone whoe has some pretty good electronics knowledge to do the conversion. Not to mention either modifying the Vette TB setup, or making a custom drive setup for their own car.
Hmmm... sounds like a possible future idea....
97FormulaWS-6 is offline
Old 05-27-2003, 08:03 AM
Highlander's Avatar
All you want from the vette is the clutch and brake... the accelerator is the regular one...
Quick Reply: Pedals for the camaro like the ones on corvette???
