Parking Brake lever removal Q:
So I'm trying to retro-fit this parking brake from a 4th gen into my 3rd gen using the whole 4th gen assembly. It would make it about 10x easier if someone could explain to me how it's removed from a 4th gen, or what sensors attach where, and such. A picture would be worth a thousand words too.
Re: Parking Brake lever removal Q:
dont have a pick but it is a prettyy easy removal. take out the consol i think there is 2 bolts then you just remove the cable that comes around the front on the bottom of the handle, there is a little tab that is kind of a pain to bend but if you do it makes the cable a whole lot easier to take off. just take the console out and you'll see, it is easy.probably 9/16 or 5/8 cant remember
also just the one sensor
Sarahrope64
11-27-2014 11:17 AM
Darth Xed
13
07-22-2002 12:45 PM
