Ominous glow mod on my 02 SOM SS
Re: Ominous glow mod on my 02 SOM SS
Don't know about Ohio - but know in some states that will be very illegal to use on the road - if it's for display and parking lot shows, it certainly sets you apart from others! Good luck.
Looks good!! I had a blue light in my scoop a long time ago before I got into a debate with highway patrol about what's legal and what's not. I did my research before I even did it and technically I was right but he was the one with the badge so off came the lights I fought the law and the law won
Towards the end of the write-up there is a link to Ozium for the led's. The first set they sent me were broken....about 3 of the 9.5 inches didn't work. They replaced them within 3 days (great customer service!). The best advice I can give you if you want to do it, is to use a wire coat hanger & make a small loop at the end to run the wires. If you don't loop the end, it will get hung up as you try & snake it through the air duct. Also, to remove the hood scoop grill, just gently push it inwards. Good luck. It was real easy. The only thing I don't like, is it kind of makes a mess under the hood. I need to get some wire loom to hide the wires.
Thanks it looks great, I read your posting on the other site, and have a suggestion. If you run the wire into the car you can put the led's on a toggle switch and hide the wiring more.
Also you can quickly switch off when you see 5-O if its illegal where you are,
and it would solve problem of having to have lights on at same time
You know, I did think about that....but kinda pussed out. As it sits, I can remove the wires in a matter of minutes (And I did pick up some wire loom last night) & since it is wired into the dimmer, I can use that to turn them off if need be. I passed my second cop last night, with no second looks or issues....so, I think I am ok.
Took care of the wire mess....
And sat at a stop light.....on the other side was a cop. He got a good hard look at my leds & waved to me as I drove past.
Sent from my SCH-I800 using Tapatalk
CARiD
07-07-2015 08:19 AM
