!!Need iimediate help installing billet grill!!
Old 08-16-2003, 04:46 PM
BradleyPeart's Avatar
Exclamation !!Need iimediate help installing billet grill!!
I purchased a billet grill. It came with four pop-rivets. I removed me ugly stock grill.
The trouble I am having is the pop-riveter's head does not fit between the bars on the grill. How did everyone else install theirs?
BradleyPeart is offline
Old 08-16-2003, 04:49 PM
AW/whiteZ-28's Avatar
Ok I have never seen this but I'm gonna take a guess
I guess you would take the plastic grille off you car and drill some holes in it then pop rivet the billet grill from behind you might try and look for some pre drilled holes in the billet grille
AW/whiteZ-28 is offline
Old 08-16-2003, 05:47 PM
Wrong, the billet grill has specific holes to use the rivets in. I would drill the hole and rivet it from the front, but the attachment on the back of the billet grill (for the pop-rivet) hold both bars above and below it together. So I can't just bend them apart.
Old 08-16-2003, 06:06 PM
Do the instructions say rivet it from the front?
If you can't fit it from the front I would have to say go from behind like this
billetgrille|Plasticgrille|rivetshooting this way <---
that or get a rivet gun with a extended barrel or whatever it's called
Old 08-16-2003, 11:32 PM
Alright, I give, screws with butterflys. Worked fine.
Old 08-17-2003, 01:05 AM
jare23's Avatar
i guess i must have got the ghetto version of the grill. mine came with 4 black tie wraps.lol i thought it was crazy at first but it all looked good and stayed on well until i hit racoon.lol. don't ask long story. but if ur up for going that way it didnt take but maybe 20min. and no holes would be left permanately. just my worthless .02. Later
jare23 is offline
Old 08-17-2003, 03:10 PM
It's not ghetto at all actually I like the zip tie version alot better my friends only took like 5 mins to get put on and ready to go
Old 08-17-2003, 04:20 PM
Won't the zip ties wear out after some time and weather?
Old 08-17-2003, 05:19 PM
Zip tie's last for about 5 years out in the weather I use them to tie cable to the bases of sat. dishes and they last pretty damned long
PROJECT X
04-17-2015 12:13 AM
RedLineRev
01-23-2003 03:51 PM
2000silverz28
09-07-2002 01:48 AM
BadBowtie93Z28
08-09-2002 07:52 AM
Mad_Ice
07-29-2002 09:44 PM
Quick Reply: !!Need iimediate help installing billet grill!!
