LT1 Throttle Body Plate
Without a link it's hard to understand your question. My guess is that they will all fit, you just have to pick the one you like the best. It isn't a performance piece so don't worry about that, buy the one that looks the best to you.
Here they are has anyone switched there's out? I'm undecided which one to get, what do you guys think? Thanks.
LT1 plate
http://cgi.ebay.com/ebaymotors/ws/eB...EF:MOTORS:1123
Z28 plate
http://cgi.ebay.com/ebaymotors/TPI-T...Q5fAccessories
Corvette plate
LT1 plate
Z28 plate
Corvette plate
I replace mine with one off ebay and have been happy. This is the one I bought. It is very high quality. Just remember that aluminum is a much greater heat conductor compared to plastic. These plates will remain hot much longer then the plastic part you remove. Im not sure how this effects throttle body heat but it might raise temps somewhat. But it does look cool as hell!
I made my own at work. Reused the old gasket without a problem. I guess bein a machinist has it's perks.....not really. I sold a few on ebay a few years ago.
The aluminum does get a bit hotter. Can't say how much tho. Need an infrared thermometer.
You can use the stock rubber gasket that comes under the plastic one. Although I reused mine for the time being, im going to replace it soon as the the gasket is getting kind of streched and worn from having 103k
Heat wasn't much of a concern of mine since I switched to a 160t and manual fan switch.
