Ls1 Engine Covers
Old 04-24-2007, 04:39 PM
Mikey83z28's Avatar
Ls1 Engine Covers
Do any of you have the engine covers that were made for the LS1. like the ones that say corvette on them. I got a set but I dont want to paint them till I know that they will fit on my car. any help would be great and pictures would help a lot too. thanks a lot
Mike
Mikey83z28 is offline
Old 04-24-2007, 05:11 PM
Loochy88's Avatar
you will need the style with two slits on the driver's side for the fuel lines. if you dont have both cuts you will need to make the second one yourself. i also had to enlarge them a bit to make them fit. i also had to cut off part of the back of the passanger side for the pcm wires to fit in. some people end up cutting the back of the driver side as well (for the AIR?) you need to remove the throttle cable bracket near the rear of the driver side frc. you also need to cut a spot for the oil dipstick, i made some room for the trans dipstick, and you need to cut a spot for the throttle cable bracket just behind the tb. its quite a bit of work, but they look nice once installed. i also filled the vette lettering and painted them.
Loochy88 is offline
10-31-2016 11:09 AM
Brake_L8
01-20-2015 09:44 AM
Jazsun
12-29-2014 12:14 PM
Caps94ZODG
22
07-30-2002 08:45 AM
Quick Reply: Ls1 Engine Covers
