Lowered with body kits?? Floor Jack??
Anyone with a Lowered F-Body & a full body kit (front valence, side skirts)??
How do you lift the car? Do you need a low profile floor jack?
Wouldn't you have thought by now they would have come up with something like a electric, or pneumatic powered floor jack?
Or that they would be everywhere by now, & cheap?
Re: Lowered with body kits?? Floor Jack??
Use either plywood or 2x6's to make some ramps to drive on so you can jack up you car. I personally use both- a 'racing' style jack has a low nose on it making easy to get under most cars.
2x10's cut, tapered and stacked. In addition to getting the car off the floor to allow a floor jack under it, also makes it possible to use 10" ramps for heavy duty work.
http://www.injuneer.com/images/photo.../DCP03111b.jpg
If you do the above make sure the ramp portion are adjustable or cut to allow 2x10's under them- otherwise the ramp won't be stable on the ground or strong enough.
I know it seems silly but some people just starting out in auto work might not think about it...for instance- everyone saying jack stands under the axle are always the way to go..until you work on vehicle with a spring-under suspension and you are putting in new u-bolts.
i have no body kit but my is really low....i use the stock jack and then a regular jack..here are the some pics of mine is really low...
[IMG][/IMG]
[IMG][/IMG]
CARiD
01-14-2015 04:00 AM
CARiD
12-26-2014 04:20 AM
